Question about Panasonic Televison & Video
Does a CT-27614A need a digital converter for antenna?
Hi, I have a CT-27614A Panasonic made in 1999.
Will I need a digital converter box for the antenna hookup?
I do not use cable or sat.
Thanks.
Will Panasonic Trinitron Color made in nov 2000 need a converter? I have cable, and do not have an antenna.
Thanks.
  • 57 Answers
According to http://www.dtv.gov/consumercorner.html#faq9
I hope this soultion is helpful.
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Posted on Feb 12, 2009
Do my panasonic hdtv 1080i need a converter box in order to work?
None of the newer style TV's need a converter box because all the tv channel tuners use a digital signal. The tv signal in the air is now digital when using a tv antenna.
Sep 13, 2015 | Panasonic Televison & Video
Hooked up a HD converter box. Lost TV
The issue should not be with your TV, I would be with the digital converter box or more than likely with your cable feed from your antenna. If you purchased a cable with connectors already on the wire, maybe the wire is okay. If you installed your own connectors on the cable, if they are twist on connections, you need to be sure that the outer braid makes contact with your connector. Double check your connections to and from the converter box as well to be certain you have not confused the antenna in and the TV out. I hope these tips help.
Oct 11, 2017 | Panasonic CT-27E13 27" TV
How do I get my Panasonic CT-26WX15N to accept digital signals?
If you are using an older tv then yes you need a digital converter box to convert digital to an analog signal the TV can understand.
Oct 06, 2012 | Televison & Video
I have a Panasonic pvq-M2508 (made in 1998)I have a Magnabox Digital converter box. The Panasonic has an antenna. I cannot get the box to recognize any stations. I go through the wizard setup and...
Can you list exactly how the converter, antenna and TV are connected? The converter should be connected directly to the antenna and the output of the converter to the TV. The TV should be set to either channel 3 or 4 if you are using the 'F' connector on the back of the set.or line if you are using the RCA connectors on the front.
Verify the connections to be as above and update this if you still have a problem. The set should be compatible with the converter. I have one here in the shop that works fine.
Dan
Nov 07, 2009 | Panasonic PVQ-M2508 25 in. Combo
Analog or Digital?
This TV is analog and will need a converter box when Analog TV is turned off in 2009.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 10, 2008 | Panasonic CT-20D11 20" TV
Digital Converter Box
Hi William
You TV is able to receive Free to air Terrestrial Analog broadcasts by just connecting the antenna. However if you wish to receive Digital Terrestrial broadcasts (DVB), you need to obtain a digital receiver for Terrestrial Digital Broadcasts. It can be easily connected to your TV.
Nov 11, 2008 | Televison & Video
Can't tell if we need converter box for a Panasonic TV CT 27SC14J
this tv does not have a digital tuner. so, if you used an antenna to get off air channels, you would need a converter box. however, if you have cable or a satellite dish you will not need anything.
Oct 15, 2008 | Panasonic CT-27SC14 27" TV
Panasonic ct 32sl14 flat screen tv
Sorry no, it does not have the correct tuner, however you do not need a converter box if you are connected to cable or satellite
Jul 17, 2008 | Panasonic CT-32SL14 32" TV
Open Questions:
Televison & Video Logo
156 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
