Question about Hannspree HANNslounge 32 in. LCD HDTV 32
When turned on, no picture, sound or response. LED is OK
I can turn on the set with both the powerbutton on the television and with the powerbutton on the remote, but that's as far as it goes.
I hear something click inside when powering on, the LED turns from red to green. The screen slightly flicks juuust a little, then it's total darkness. I can hear a sublte buzz from the inside though. Doesn't help to unplug/drain circuit. The buttons on the panel doesn't respond nor does the remote.
Any ideas someone?
  • Anonymous Mar 10, 2009
    The same problem with mine. Ideas anyone pls?
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
Posted on Dec 19, 2009
The TV clicks on and off several times before it finally comes on, some times 15 mins.The screen has green lines and pink pixel type lights.
Posted on Feb 12, 2009
Why does my TV have no picture but still have sound? Its a LG LED Tv Model number 42LS3400-UA prod code 42LS3400-UA.APHLJD Serial number 2101NBSB2837 When turned on there is sound but no picture.
the picture board has gone faulty
thee are two system boards in the set --one for sound and one for picture
if you have the number from the board you want to replace try e-bay --circuit boards for your tv and see what comes up
Feb 22, 2016 | LG 42LS3400 42" Class FuHD 1080p LED LCD...
No picture sound ok rca 46la45rq
Sounds like backlight is dead. Shine flashlight on screen. Can you see video slightly. Replace inverter or some sets have inverter as part of power board. If led set replace led driver board. Also that may be part of power board.
Mar 31, 2014 | Televison & Video
I've got my Dish cable to show on my Sylvania SDTV CR202SL8, now I need to know how to get my Playstation 3 to show on the tv. I don't have the original remote, so I'm using the Dish remote.
your ps3 is probably sat to HDMI or SCART, to change this: turn off your ps3 and hold the powerbutton when your turning it on. this will cause the ps3 to change between HDMI and scart, thats probably why it wont find a source.
Sep 24, 2013 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
How to reset cod for toshiba tv
As far as the set goes almost any older Toshiba set will use the same code for its remote this one does--if programming for something else Google the model number of this set and the remote being used and look for a owner "manual".
For use only with this set you should be able to find any number of used remotes on EBAY etc.
Apr 23, 2012 | Televison & Video
I am a technicien, i 'll like to ajuste the convergence for tv sony kp-46wt500 ,but i dont have the code to go in the tv (service mode)
With set off and using the original Sony remote:
Display, 5, vol up, power
Buttons on the remote will let you cycle thru the menu to the convergence adjustment--do you know what buttons to use and what they do?
Mar 20, 2012 | Televison & Video
Just bought a second hand philips 20hf5474 with universal remote but no user manuel. cannot get into menu to set channels, clock etc
Hello philbarbara:
Here is the link for the manual for your Television:
"CLICK HERE"
It looks like this set has a lock for the menu which can be accessed only with the remote. Hopefully its not locked out.
But it also looks like you have buttons on top of your set. In which case you should be able to access the menu button from there.
As far as your universal remote goes, you might need to try a different code in order to control your televisions menu settings. Some codes only control on, off, volume etc. If you put the right code in your universal remote you should be able to get all of your remote functions.
You also might want to try watching out on Ebay for your remote that goes to your particular TV set. That would be the easiest way to solve your problem.
With the manual link I've provided for you, you should be able to solve this dilemma your in.
If this helped just click the thumbs up.
Your FixYa team member, Peter N.
Mar 26, 2011 | Philips Televison & Video
The volume on my tv goes down all by itself. I turn it up and it goes right back down to 0. With remote or manually, does the same thing. Also, can't turn tv off. have to unplug it to turn it off. Any...
Try taking the batteries out of the remote or taking it out of range from the tv. Then try turning the volume up on the Tv manually. If the volume continues to go down on its own then it is a problem with the tv set itself. If the problem stops with the remote out of the picture then it is a remote problem. As far as powering the unit off may be a similar issue. If there is an on/off button on the tv and it works to turn the power on but not off then it is a tv issue. If the remote turns the tv on but not off it may be something as simple as the wrong code being programmed into the remote(universal remote) or if it is the factory remote it may be an issue with that. You could try getting a new universal remote that works with your unit.
Jul 09, 2010 | Toshiba 32A33 32" TV
Hannspree HANNslounge 32 in. LCD HDTV 32 Logo
1,307 people viewed this question
Top Hannspree Televison & Video Experts
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
