Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
How do I delete an old backup from WD 120 External Drive?
My computer does not recognize the WD anymore. I need to find it and delete the old backup so I can put an undated backup on it from my desk top computer.
  • Anonymous Feb 22, 2009
    My external HDD also has become unreadable by XP. I was defragging it when it hung up and I'm sure that's why it won't read now. I'm looking for a utility that will boot, find the HDD and format it.
SOURCE: wd anywhere backup wont allow macbook to shutdown
I couldn't stop it from backing up, so used "force quit" from the activity monitor. It was still running a background service (WDMemeoAgent?). I stopped that from an icon left in my tool bar. I don't think I use it since it estimated 30-40 for the first backup of my home folder and it wouldn't allow me to pause or quit.
Posted on Jan 26, 2009
SOURCE: My I Mac doesn't recognize the WD 500GB external drive anymore
it must be initialised /mounted 1st for osx
Posted on Mar 08, 2009
Suricatta
  • 92 Answers
SOURCE: WD External Drive-USB recognize, but no icon, can't access
1. Right click on My Computer > Manage;
2. On the new window click on Disk Management, on the right side, right click in the USB Volume and chose "Change Drive Letter and Path..."
3. In the new window click on "Add..." to assign a letter to your USb drive.
Best Regards
Posted on Jun 24, 2009
bschilz
  • 2049 Answers
SOURCE: WD External drive not recognized on computer
If the drive was running when it fell, and it doesn't have a head locking mechanism (or was in mid-read, or mid-write and the head wasn't locked down) then your disk may have experienced a head crash. The read/write heads float over the surface of the disk. If they slam into the disk, they will make a divot, boucne, make another divot, and continue bouncing until the kenetic energy is dissipated. In the places where magnetic material is removed, you won't get any data back. You may be able to recover data elsewhere, using a recovery company, but it won't be cheap. If your data is critical, you have a good chance of recovery using a service such as Seagate Recovery
http://seagatedatarecovery.com/ They recover data from all brands and I have used them They're very good, but very expensive ($800 range)
Posted on Aug 08, 2009
  • 109 Answers
SOURCE: Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Posted on Feb 06, 2010
WD External Hard Drive Passport Ultra Beginner's Questions
Usually with an external hard drive it's not necessary for it to copy over an existing backup or at least you can program your PC not to do this. What will happen is you will have several different copies of backup's and you will have to decide if you want to erase the others and keep the most resent one. Yes your file will be saved withing the backup but if you change the file name it will file this as a new file
Sep 28, 2015 | Ultra Computers & Internet
My WD Elements SE External drive does not have its driver recognized on boot, but does only after repluging its USB 2.0 connection. How do I get the driver recognized on boot? Why does replugging work
I guess it's some kind of a problem with the way your USB port works. I have an external WD too, connected to a USB 3.0 port and definitivly it's not detected at boot, just after windows startup as a USB device.
After some initial wondering about this problem, I decided no to worry more because I use external drive for data backup and if it is not detected by BIOS makes no difference.
It might be a problem of an outdated BIOS or the USB port's driver. In my case, boths, BIOS and USB 3.0 are rather old.
You can do some reading about issue if you do a ggogle search for issue
USB 3 0 external Hard Drive not detected after Intel Communities
External USB 3 0 HDD is not detected in Windows after boot Help
Aug 06, 2015 | DMCOM Western Digital Wd Elements Se 1 Tb...
Can't read data on WD external my book hard drive
It seems that your WD hard drive is corrupted so
you are unable to access the stored files. But there is no need to worry since
it is very easy to recover data from corrupted WD partition by using Western digital partition recovery
software. Couple of days ago, even I was stuck under similar problem I tried
this software which really helped me to retrieve all my lost data.
All the best,
Linda William
Jan 01, 2013 | Western Digital My Book Essential 1TB...
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
Computer won't recognize external hard drive anymore
Have you tried changing the USB cable or connecting it to a different USB port on the computer?
Nov 14, 2017 | Western Digital 320GB MyBook External USB...
My computer has 2 drives (C and D). My WD Passport will recognize and backup the C drive, but it won't backup the D drive. It doesn't split the files into pictures/video/etc like it does with the C, and...
Well, you don't have to use WD's software...you can better backup software like Acronis..you can back any files you want, or, the whole computer with installed programs, operating system and all. Are you using WD software, or windows? You can just select the files you want to copy from the drive in Windows, and just copy them to the drive, you don't have to use WD software.
If this post has helped, please vote.
Jun 15, 2010 | Western Digital My Passport Essential...
Hard drive is full need more space
From Control Panel go to Add/Remove Programs
Remove programs that no longer useful to you and delete documents, pictures any file that you don't need anymore.
if you don't have nothing to do with removing programs and deleting files, you have to upgrade or add a secondary hard drive, or a external drive will be a helpful to you, move all your files to your external drive this will also counted as your backup files.
Jan 05, 2010 | ASUS (90N804SH021) Hard Drive
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
WD 120 GB 2.5" hdd not listed in my computer
I HAVE MY PROPERIETRY SOFTWARE WHICH I USE TO FORMAT ANY DISK OF ANY TYPE... AND MAKE ANY TYPE OF PARTITIONS LIKE ALL IN ONE PARTITIONING AND DISK MANAGMENT.
I HAVE STILL NOT REGISTERED AND TRADE MARKED IT. BUT I AM SUCCESFUL IN MY PRACTICE ON VARIUOS HARD DISK DISCOVERIES AND RECOVERIES .EVEN I CAN DO A FULL ZERO LEVEL FORMAT TO ANY HD.
CATCH ME AND REQUEST FIXYA TO ALLOW YOU TO SEND YOUR HDD OR ANY TYPE OF STORAGE MEDIA FOR RECOVERY AND SOLUTIONS. +0+9+3+2+1+1+0+1+7+1+7
Apr 17, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
339 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
