Question about AT&T Lucent MLS-12D Phone
I want to disable a call from going to voicemail
I have a separate line that I want to just ring. I never want it to go to voicemail. How do I turn voicemail off on a specific line?
    President:
  • AT&T Master
  • 860 Answers
Changing programming on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#206"
the display should say group call distrib and Group:
enter 7.
the dislay will then say group call distrib 7 line:
enter the line number you wish to program in 2 digit format i.e. line 1 is 01 and so forth
the display should say group call distrib 7 L01 and 1 assigned
enter 2 on the dialpad (not assigned)
enter feature "00" when finished
hope that helps
Posted on Feb 13, 2009
L39c. How do I disable voicemail?
Sounds like you got your calls going to call forwarding or you need to turn up your volume on your phone if it is call forwarding it want to dial*73 and then hit your call icon button on your phone and that should disable any call forwarding that you have.
Oct 02, 2015 | LG Cell Phones
My incomingcall not ring straight to voicemail and iPad ringing why?
Verify that "Do not disturb" is off otherwise all your incoming calls will be forwarded to your voicemail.
Your iPad is ringing because iCloud has connected both. To disable this on your iPad settings go to iCloud and disable that.
Dec 07, 2014 | Apple iPhone Cell Phones
Phone rings 4 times then goes to message I want it o keep ringing
Basically, you want to disable Forward No Answer to voicemail:
Feature ** CONFIG
Terminals&Sets
enter ext #
advance past Line Access to Capabilities
go to Fwd No Answer
CHANGE softkey to None
go to Fwd On Busy
Jul 01, 2014 | Nortel Lands Phones
When somebody is calling me my phone (vtech) has only 4 rings before the voicemail starts for them to leave a message. can i do something to get more than 4 rings before the voicemail starts? it's...
The CS5111-2 isn't an answering machine. If you have a separate answering machine connected to your phone line, consult its documentation. If you're subscribed to a voicemail system offered by your phone company, contact them for information.
Aug 28, 2011 | Vtech Digital Cordless Telephone VT-2568
Can send faxes but not receiving them and yes there is paper in fax
Make sure the correct fax number is assigned on the printer. If you have an answering machine connected to the same line as your fax, configure it so that the answering machine picks up first then the fax. For more information, please refer to this article: Change Number of Rings on Inkjet AIO to Alleviate Issues with Answering Machines.
If you have a voicemail feature associated with the fax line, please disable the voicemail. Voicemail feature and the fax will not work together in the same line.
Jul 05, 2011 | Lexmark X4270 All-In-One InkJet Printer
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Mar 30, 2011 | Uniden Cordless Phone
When I receive a call and am not at home, the operator says I am not available instead of going to the answering machine. I am getting no messages.
Sounds like you have voicemail from your service provider and it might need to be activated before allowing messages to be recorded . If you do have voicemail on your number and it is set to answer after 3 rings and your answer machine is set to answer after 4 rings, then the caller will never get to your answer machine. Voicemail is often automatically added by service providers, especially if you have recently changed service providers or your service provider has upgraded their telephone switch equipment. I suggest you call your service provider's customer service number and ask them if your telephone line has voicemail and if you don't want to use it, have them disable it. If the service provider says you do not have voicemail then report the problem as a trouble on your telephone line.
Mar 24, 2011 | Panasonic KX-TG5632 Phone
Does not wait for the 4th ring; sends call to verizon voice mail box after the second ring
Sounds like your service provider(Verizon) has your phone line setup to forward to voicemail on no answer after 2 rings. Call your service provider's customer service number and request that the number of rings for forward no answer be increased to at least 5, then your answer machine can receive and answer your calls after 4 rings but if your line is busy callers can leave a message with your Verizon voicemail service. If you don't want Verizon voicemail to answer any of your calls, you could have them disable the voicemail service. When you call the service provider have a recent bill ready because they may request your account number before they will make any changes.
Feb 25, 2011 | Uniden EXA15580 Cordless Telephone
AVAYA PARTNER ACS PHONE SYSTEM - Voicemail/Greeting capability
Yes you can have the 2 lines answered by a particular mailbox instead of the AA greeting.
Would need to know the model of the voicemail system that is installed to see if there are more than 1 AA menus.
Oct 06, 2009 | Avaya Lands Phones
Receiving Fax using a phone line with voicemail on a Lexmark 5470
well, your voicemail can configure to key tone?? or have some one configuring options????
Nov 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
AT&T Lucent MLS-12D Phone Logo
194 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
