Question about Nikon Cameras
Cannot remove memory card write protection Nikon Coolpixs9
All of the sudden, my camera tells me "memory card write protected" when I try to take a photo or delete a photo. I Tried using a new memory card, however, got the same message. The menu will not allow me to adjust the memory proctection settings. The camera is practically useless at this point.
HELP!!!!!!!!!!!
  • John LeFebvre May 11, 2010
    Is it a SD card? Check the little security slider switch on the edge of the card hasn't been slid the wrong way - try it the other way and see if it works.
    If not SD, we need the model of Nikon you have, the make and capacity of the memory card and any other info you think may help.
    John
    President:
  • 415 Answers
Take your memory card out and look to see if you may have moved the sliding switch on the memory card, if you have move it back.
Posted on Feb 13, 2009
  • Nightshade41 Dec 05, 2010
    Gough2960--- You are officially my hero! My husband's camera did the same thing and I was clueless on how to fix it...Thank you, thank you, THANK YOU!
    Jolea
    Problem Solver:
  • 8 Answers
Haha, my dear friend, you can't see there is a "read only switch" in the memory card body?
so you can change the protection settings in the card not in your camera.
np-bg1
What is mesage "memory card write protected " in nikon coolpix4500
It means that the camera 'thinks' that the Memory Card in the camera has been switched to 'Write Protect ON". If there is no Camera Menu Item to override this function then remove the memory card from the camera and check along the edge. You should find a small black or grey slider button that will move. Hopefully it will be labeled for Write protect ON and OFF.
Reinsert the adjusted card and see what happens. If the error persists then try another card. This link might help:
Good luck.
User Manual Coolpix 4500 Guide to Digital Photography Nikon Knowledgebase
Mar 02, 2015 | Nikon Cameras
Why has my memory card in my Nikon L310 just suddenly told me that it is "write protected"?
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 26, 2012 | Nikon Cameras
Memory card is protected????
Move the slide switch on the side of the card.
Oct 06, 2009 | Nikon Coolpix 5700 Digital Camera
Memory card is write protected
Hi..
Suddenly the card you have inserted is locked so that's why is says write protected. To unlocked the it get or remove your card from your camera. You can see in your memory card there is a small button her try to slide the button to unlocked. Insert your memory card back to your camera and try to take a picture it will take a picture.
Thanks for using fixya
Regards
PCmania
Sep 03, 2009 | Nikon COOLPIX L5 Digital Camera
My camera is write protected
Dear Hannahboggs9,
I am not quite sure of what is the make of your Memory card however most of the memory cards have a small switch on side that could be toggled to make it write protected. I am sending you a link with picture to make it more clear.
http://media.digikey.com/photos/Toshiba%20Photos/SDM%20MEMORY%20SERIES.jpg
See the yellow slide lock on left edge of the above card...
Now if there is no lock on your card or if the above mentioned is not the problem then you might want to try formatting the card using your computer with "FAT" OR "FAT16" file system selected from the drop down (DO NOT SELECT FAT32).
If that too doesn't work then you might want to try with a different memory card.
This issue doesn't seem to be with camera.
In case any further assistance is required please write back and I would be glad to assist.
Regards,
Srinivas
Jun 25, 2009 | Nikon COOLPIX S51 Digital Camera
My nikon camera coolpix 1600 memory card is write protected. Plea
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Apr 28, 2009 | Nikon Coolpix S51c Digital Camera
Memory card write protected
Mar 31, 2009 | Nikon COOLPIX S51 Digital Camera
''Memory card is write protected''
Remove the SD memory card from the camera and move the small switch on the side to the unlock position. That should solve the problem.
Mar 16, 2009 | Nikon COOLPIX S51 Digital Camera
NIKON L10
Dec 18, 2008 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 4800 digital
Your memory card has a little switch on the side of it called the Write Protect Switch. If it is in the Locked position, the camera will tell you the memory card is protected. Just take the memory card out and slide the switch to the unlocked position. You should be able to take pictuers now.
Feb 07, 2008 | Nikon Coolpix 4800 Digital Camera
Cameras Logo
538 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
