Question about HP Media Center PC 873n (P9875A#ABA) PC Desktop
HP 873N CPU fan error
CPU fan error and system shuts down. I have previously had the fan replaced, only to have the error occur a year later. Could the issue be mother board related? Also can you suggest where I can look for a replacement fan? Thx...
    President:
  • 2,692 Answers
Yes, It is possible to be a board problem much more likely to be a dust /dirt problem. I have not found anywhere to purchase the CPU fans by themselves.Would obve to be wrong on this one; seems that they are sold along with the heatsinks. My favorate is : Newegg. com  but another is: Tiger.com
All you will need to know is your CPU  socket number. You can look that up in tghe manual:
I provided a link to the HP manual for you computer below. I beleive,once opened , you wil see the dust and dirt which may have caused a failer of the CPU fan. Filters are available for the same websites as the fan/heatsinks.
http://h10025.www1.hp.com/ewfrf/wc/product?product=90829&lc=en&cc=us&dlc=en&submit.y=7&submit.x=7〈=en&cc=us
Posted on Feb 13, 2009
HP Compaq 6200 Pro Microtower XL504AV - doesn't boot
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Mar 26, 2013 | Computers & Internet
HP M370n System fan failure will shut down in 5 seconds,
Return to the person that replaced the fan. Obviously it's not fixed.
Feb 20, 2013 | HP Pavilion Computers & Internet
HP M7357c overheating problem
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 03, 2012 | HP m7357c PC Desktop
CPU fan failure causes system to aromatically shut down..
Without a proper working cpu fan the cpu will overheat and shut the computer down... if not fry the cpu. You will need to replace the cpu fan and hope the overheating didn't mess up the cpu or something on the motherboard.
Jul 06, 2011 | HP Hewlett Packard HP-COMPAQ DX2450 MT...
My HP 8710W shuts down when overheated. Usually when playing games. To overcome this, sometimes I let the part of the laptop where the power supply input is located, to stand out of my desk, so that it...
I had similar problem on my HP 8710p and eventually fixed it. Here is how.
First I had a normal overheat situations twice due to clogged dirty fan vents over a period of 4 years. You notice this when the vent cooling fan stays on most of the time, unlike when it was new, even while idling, and of coarse one is reluctant to break open new a PC. After eventually cleaning the fans the problem was resolved but the PC was actually operating at slightly higher average temperatures as the cooling fan would switch on more often that it did when it was new. This is so suttle it did not concern me at the time me until eventually after 18 months, a mere boot would send the cooling fan into frenzy of cooling mode and usually switch the PC off before a full boot could be achieved.(and yes my cooling fins were spotless as I cleaned these once a month at this point).
System reboots were a nightmare as I would have to wait for 30 mins for the CPU to cool down. Eventually I lifted my keyboard on the left side and slipped a small 5 volt fan onto the processor. The fan was powered by a USB port. This worked great but directly cooling the CPU also meant directly depositing dust directly onto the inside of your PC which had to be cleaned with compressed air at least once a week. That was besides the fact that I had to contend with a lop-sided keyboard because of the fan height.
After a year of this I finally I decided to rather try replacing my CPU as I had run out of options. While searching eBay I discovered that CPU cooling apparatus'us were sold in conjunction with CPU's so I decided to buy the cooling apparatus first as a replacement CPU was pricey, especially for an older PC. Skeptical about about my decision, I replaced the CPU cooling apparatus.
To my amazement the problem was solved. Where before I could not even touch the copper tubing near my CPU with my bare finger, now it was cool, probably no more than 30 C and booting was silent. Needing to be sure of this, I replaced the previous cooler and the problem returned, the CPU cooling apparatus copper evaporated spit near the CPU and miraculously cooled down to a room temperature on the fin end.
This was difficult to understand because copper is a very good conductor of heat and here clearly was a situation where the one end of the copper tubing was hot enough to boil spit and the other was at room temperature.
So what can cause this? I am not sure exactly but its not mentioned any where on the Internet as a fix, Not even by HP themselves.
I suspect initial over heating may have messed with the internal climate system in the copper tubing to the extent that the coolant dissipated, probably due to high pressure. The faulty cooling apparatus did not demonstrate any signs of ware and tare, actually the replacement cooling apparatus looked worse than mine as the copper had lost its sheen. I also examined the faulty apparatus from close up for any possible cracks and holes and found nothing visibly wrong. All I had to go on is that the replacement worked and mine did not.
My CPU now peaks at around 50 C when number crunching and the cooling fan is seldom activated. The copper tubing is warm, but not hot, right up to the area where the CPU is located. My system runs so quiet now it has a feeling of newness about it. That raises another question, modern PC's have normally have self preservation software coded into their BIOS that prevents or slows down the CPU clock speeds when over heated or running on battery. The battery part is to conserve power but the heating part is to not do irreparable damage to the CPU. This feature is usually referred to as "dynamic clocking". A hot CPU will run at the slowest possible speed it can function at, (beyond this it will be shut down) at a time when you are trying to crank every bit performance out of it. So it goes without saying my PC now runs faster and appears to be more responsive, just like the day I bought it.
While this occurred to my HP 8710P, I know the problem occurs to many aging laptops that can by fixed the same way. Currently there are many alternative external CPU coolers being sold to solve this problem(and I have seen many and the ones I purchased I have returned). I believe that Trojans and viruses are not always responsible for sluggish PC's. Until you address the real issue, your problem will continue. Consider the above as an option.
My PC was headed for the trash heap. (I am a developer, not a gamer) but now it will stay. Its reliable, trustworthy and never had a problem besides the cooling issue.
May 24, 2011 | HP 8710w Mobile Workstation - Intel...
CPU fan not working computer shuts down. Replaced fan and it still does this? Hp Pavilion 9597c
Its possible that the Motherboard connector for the fan is not putting out power. there are CPU fans that use a standard 4pin Molex connector, that is what I would suggest you use.
Mar 18, 2011 | HP Pavilion (F2111-60950) CPU Heatsink &...
Computer frequently shuts down unexpectedly/ fans very noisy
You might have a cooling problem due to a fan malfunction. It is not clear whether it's the power supply fan or the CPU fan; in the latter case you might also have a thermal coupling problem. The symptoms you describe certainly seem to point to such.
My advice would be to replace the fan (or the whole power supply; you might also want to purchase a "Silent Power" unit for quieter computing). If it's the CPU fan and you are comfortable with, or know anyone comfortable with a bit of PC servicing, you might want to also unmount the heat sink from the CPU and replace the thermal paste between CPU and heatsink. Clean the heat dissipator (the black metal grille over the heatsink) with hot water and a bit of soap and dry thoroughly, or wipe it energically with a dust brush, before mounting the new fan on it.
Feb 28, 2010 | HP KQ499AA Pavilion Elite M9360F Desktop...
Hp Compaq nx5000 Laptop selft boot / restart when plueged
You need to replace the power supply, don't continue to use it for it would cause damage to your computer.
Nov 02, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
Cpu fan error, but spins
hi,, there may be an problem faulty in motherboard,, or processor,,,
Sep 28, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
Read disk error occured during rebooting
The acer recovery software sometimes has it's glitches. The CD might be fine, its just the data that wa written to the disk @ time of recovery creation was corrupt at some point.
If your machine shuts down randomly there can be only 3 possible solutions to this one:
  1. Your battery from your laptop has an issue. Try letting the laptop run on AC power ONLY.
  2. Your CPU is overheating, caused by a broken or unresponsive CPU heat sink fan, which causes your pc to shutdown (will always auto- shutdown at a certain temperature to prevent damage to the CPU. Check if you can feel "air" coming out of your laptop, suppose to be a hatched outlet at the side or at the back or on the top cover.
  3. You have a Virus that is shutting down the pc when it wants to. NO Operating system issue can cause your PC to shutdowb; only a virus can do that.
Summary, check your battery, check if your CPU fan is running, and make a virus scan (if the pc doesnt shut down). Remember to make a backup of your DATA, cause Acer (i dont think they will) don't do backups. Waranty on Acers is usually 3 years, depending on the country. So they should replace and repair, everything.
Apr 17, 2008 | Computers & Internet
HP Media Center PC 873n (P9875A#ABA) PC Desktop Logo
415 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
