Question about Hobart Food Mixers
Hobart v1401 mixer slipping when in 1st gear.
Keeps moveing even when you put it out of gear or in the stop position. does not do it when in 2nd gear or higher.
  • davidshaw Feb 16, 2009
    thanks bigg t . I also have another mixer that sometimes will not lift a empty bowl. Replace bronze nut at bottom of big screw 6 months ago and now this. thanks in advance..
  • 640 Answers
Sounds like the planetary brake needs adjusting or the pin is worn.
Posted on Feb 13, 2009
I have a hobart a-200 mixer that had the brass drive gear go out. I rebuilt the transmission and used a parts breakdown to clean out and rebuilt the whole tranny. Now I have no 1st gear. Under a load...
Loosen the two planetary nuts, should be a thin nut and an acorn nut. With these loose make sure the large nut on top of the transmission is tight. Push the planetary all the way up on the shaft and turn the thin nut up until snug. Back the thin nut off 1/4 turn. Hold the thin nut in position and lock the acorn nut against it. The planetary must have a very small amount of up and down play.
May 20, 2010 | Hobart A200 Stand Mixer
Hobart A200 mixer 1st speed doesn't work 2nd and 3rd work fine
Could be that a gear is missing (broken) on the shaft that works the 1st gear. Check out the schematic at
http://www.food-equipment.com/parts_Hobart_mixers.htm
It could be the gear HM2-748
Feb 22, 2010 | Hobart A200 Stand Mixer
V1401 slips in all gears; what to adjust?
Take the top cover off,in front of you is the brake.Turn the mixer on and you will see it spin (put it in 1st gear),stop the mixer.on the right side you will see a pin that catches the brake flange,if its worn you can replace it,if its not worn then the brake needs adjusting as it acts like a clutch.Let me know,im a hobart tech band repair these units often.
Nov 18, 2009 | Hobart Food Mixers
Hobart D300 Mixer, Will not shift from 2nd to 1st gear without coming to full stop, Ideas as to source of problem? It also seems to be making increased noise.
Hobart mixers are NOT designed to change gears while operating. The Hobart planetary gears are like the transmission in your car but, without the clutch. Everytime you change gears while unit is running you are tearing up the brass spacers, gears & seals. Time to call a QUALIFIED service tech to come out & sell you another planetary or rebuild your old one, about $2K, Buy a Varimixer if you want to change gears while unit is running, they use belts. Another planetary premature failur cause, over loading the bowl. Batters & icings- 75% bowl capacity, Dough 65% bowl capacity.
Jul 23, 2009 | Hobart D300 Stand Mixer
Hobart A-200DT mixer lugs out
Can you be more specific?Does 1st gear run? are you overloading it?
Mar 18, 2009 | Hobart A200 Stand Mixer
A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Jan 17, 2009 | Hobart A200 Stand Mixer
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
Hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
Jan 27, 2008 | Hobart D340-6007 Mixer
Food Mixers Logo
277 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
