Question about Kenmore 23822 Top Load Washer
Kenmore washer only will fill to a small load water level
No matter what water level you select it only fills enough to do a small load (recently professionally installed lid switch)
    Scholar:
  • 99 Answers
This is Joyce
This is your water sensor, it is going off before it lets the machine fill up, if not this then the control on your machine that determines the size load you selected. go to kenmore.com download your manuel. see what you can find out about the machine.
let me know if you need any other assistance
thanks
joyce
Posted on Feb 13, 2009
Washer does not fill with enough water.
The water level is controlled by a pressure switch connected to a long rubber hose that goes inside the tub. If the switch is defective or if the pressure hose is blocked the machine may under-fill.
Check also inlet hose and water pressure from the house.
Mar 28, 2012 | Washing Machines
If you open lid during operation, washer fills all the way to top
if you really want to see, simply stick an object (like flathead screwdriver) into the little hole that the lid presses into to click the switch, hold it there
Aug 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore 70 is also overfilling...
Sounds like it could be a faulty water level switch. A defect or an obstruction can mean that it can't tell the water to shut off. This switch raises the water level in the clothes tub. It's usually a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, the pressure increases on the air in the plastic tube. When the pressure reaches a certain level, it activates the switch and turns off the water. It also signals the washer to begin the wash cycle. Clean out any obstruction in the plastic tube or replace the water level switch. Hope this helped.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
Washer not filling up with water at beginning of cycle.
Don't replace anything. You will need to clean out the tube which connects the water level switch to the tub. (or replace that tube)
Feb 26, 2009 | Kenmore Washing Machines
Washer doesn't fill with water. Only enough for a small load.
A - Two things could be your problem...
1) - sometimes the screens in the fill valve or inside the ends of the fill hose get clogged up...use a tooth brush to clean them out. Don't forget to shut off the water first before removing the hoses to check for this.
2) - The fill valve itself may not be opening fully = time for a new fill valve.
Dec 17, 2008 | Kenmore Washing Machines
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model# 110.28803890
Hello. Yes there is a fill level pressure switch. It is pressure activated by the pressure of water rising in a tube as the water rises in the tub.It's easy to find and easy to replace. Look for the tube and follow it to the switch. Parts for Kenmore are available at 1-800-516-9625 or at http:\www.sears.com.
Good luck.
barneyluc
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag washer will not stop filling when wash cycle is first selected. Doesn't matter if I choose small, medium, or large load.
How do you get it stop filling? If it stops filling by just shutting the timer off you may have a bad pressure/water level switch, if you have too shut the water off too the machine at the wall then you have a bad inlet water valve.
Jul 30, 2008 | Maytag Washing Machines
Whirlpool washer
the Pressure switch is bad (also called Water level switch) there is a small hose from the tub that runs up to it ..The tub will need top be empty when this part is changed
Mar 02, 2008 | Washing Machines
Kenmore 23822 Top Load Washer Logo
190 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
