Question about Kenwood VR-407 Receiver
Speakers Sound is low is speakers even when turned up
  • efrainvega18 Mar 12, 2009
    sound is very low, i put it to sound from one output but it sounds from all and very low
  • 336 Answers
Check that the tape monitor or tape2 is not on this is the case 90% of the time. Also check that the speakers A or B are selected. Be sure to turn the volume down first or you might damage the receiver or speakers.
Posted on Feb 12, 2009
Tv sound not working, even with soundbar.
Is the sound muted or switched off in the menu. Try resetting the set to factory settings.
What make and model is it?
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Apr 14, 2016 | Audio Players & Recorders
My radio makes popping sound when on for about 20minutes but when i turn volume up it stops but sound is disorted.any ideas on problerm
Sounds like there's wires touching and it's grounding to its self or there's a bare wire rubbing on body. Check all speaker wires in trunk or back to which are the ones easiest to vet messed up
Jan 09, 2015 | Audio Players & Recorders
I have a Rowe R80 jukebox and after moving it it has no sound through the speakers I am in New Zealand
Well, in addition to all the fine suggestions that are here, I would like to add the simple and easy things that may have happened during the move.
IF YOU ARE NOT GETTING A LOUD POP WHEN THE MACHINE IS POWERED ON.......
1) Make sure that the wires on the terminals below are still connected to the screws. There is one ground and one each for left and right. The lower the tap the lower the (max) volume of the jukebox.If they are not connected there will be no sound.
There is a jumpers on the terminal strip where the volume control connects. Make sure that these connections are correct and tight. Also make sure that the jumpers did not fall off.
If you are getting the loud pop in the speakers when the power is turned on .....
Check the plug on the side of the mechanism, just below the back of the tone are.(looks like a little tube socket) Check to see that it is connected to the mech and the CORRECT PLACE on the amplifier. It mat be possible to have this end in the wrong place. bf77613e-82a3-4e37-b8fe-cc80f4d4dbcb.jpg
Check all all your connections against the pic.
I hope this was helpful.
Mar 24, 2014 | Audio Players & Recorders
HMDX Jam wireless speaker cannot be paired with my computer
Go to your Bluetooth settings, go to the "Audio/Video" tab, under the "Content Protection" section uncheck the "Connect to content protection enabled headset only" and your bluetooth speaker(s) should now work.
Feb 02, 2013 | Audio Players & Recorders
Connect an active soundbar to a receiver
What if the soundbar is Bluetooth? Will I still be able to use that function and connect the active soundbar to the tv (Bluetooth) and connect the av receiver for other surround sound speakers? (they are pre-wired in the walls in the apartment I moved into)
Jan 08, 2013 | Audio Players & Recorders
It wont turn on, it shows 'push power protect' when you turn it on, or disconnect it and reconnect, i already attempted to disconnect the Sony Stereo MCH-EC909iP Mini Hi-Fi and it shows 'Push Power, P
The only thing I can think of is its goin into protection mode like an amplifier would, you maxed the volume out and it's protecting your speakers or you don't have the right voltage going to it, I can see you don't have it on a straight 120v plug and you might have the wiring wrong on the speakers to it might be too low of a ohm or too high
Nov 22, 2012 | Audio Players & Recorders
The feedback on my stereo is very muffled.
Does is sound this way with all audio inputs? You might have your speaker wires backwards Red to Black between the speakers and the Stereo, make sure they are red to red and black to black.
Oct 18, 2012 | Audio Players & Recorders
Sound problem with JBL Creature II
I had a problem with the speakers not working properly. The green lights lit, but the amount of sound coming from the speakers compared to that of the sub was much lower.
I decided to take it the speakers apart.
I found that the magnets on the speakers had moved forward slightly in the plastic cage they sat in. I pushed them back as far as they would go, and Hey Presto! working again!
I hope this helps someone!
Feb 23, 2007 | JBL CREATURE II Computer Speakers
Kenwood VR-407 Receiver Logo
130 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
sonic boom...
sonic boom...
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
