Question about Alpine CDA-7998 CD Player
The deck opens buts doesnt play music and the screen doesnt show.
The deck opens and makes the beeping noise that it usually did, it was just playing music on the last mode that i had it on, but i pressed the reset button and the screen now is just blank, plays no music and i would really like to get it working again...i heard theres 2 buttons you might have to push to reboot or something! PLEASE HELP :) i would really like my music back! :)
  • pocheeyo Feb 12, 2009
    same thing just happened to me! the head unit stays out and doesnt close. when i turn the car on the motor tries to retract but cant, and nothing comes on at all (lights, sound, buttons). before it would play music but none of the buttons worked. any help?
  • 3 Answers
I have the same deck and a very similar problem. Mine was stuck in the out position and would beep and move a little but there was no lights or music. I called Alpine and they told me that sometimes the inner sleeve around the deck will pinch the unit a little. I took my unit out of the dash and sure enough the plastic face plate came loose and moved about 1/32 of an inch when I slide it back in place and turned the power back on it worked perfectly. Hope this helps.
Posted on Apr 04, 2009
I have vms4 decks, when i play a tune on my right deck i get serious crackling noise out of my speakers and headphones...any advice please guys?
Have you tried isolating the problem, like switching cables from the left side that is not making noise? Also check connections,
I say this all the time and use all the time.... electronics spray contact cleaner, usually takes care of crackling noises
really hope this helps?
Mar 04, 2015 | American Audio VMS4
Tascam 302 Tape Deck - When I press play it rewind/fastfoward
There is either a cam belt that is lose or the flywheel assist can not move the head base due to hardened grease. It needs to be serviced.
May 16, 2013 | Tascam 302 PRO DUAL CASSETTE DECK Single...
My dell d600 cant produce music sound
What program is playing the sound file? If you want to be completely sure that its not a codec issue then play it with VLC http://www.videolan.org/vlc/ - VLC can play absolutely anything usually.
If it still doesnt play then it can only be one of two things:
1. - corrupt driver / software issue - confirm this by seeing if anything else plays through the speakers, if you get noise from other things then its not this.
2. - Broken speaker - if you cant get anything at all to make noise, and its not 1, then it could be a faulty speaker issue. Technician needs to look at it.
Finally if its only one file obviously it could be a corrupt or broken file, but I'm sure you've tested on more than one file
Oct 29, 2010 | Computers & Internet
My xbox 360 is freezing while playing any game, it lets me play for maybe a half our sometimes, but when it does freeze the sounds in the background continue to play but the screen is completely frozen. I...
Yes this is freeznig up that is caused by overheating you need to stop the heat build up getting to the chips to make it work, use a good repair guide or send it in for a fix.
Aug 15, 2010 | Microsoft Xbox 360 Console
Vertical white lines appear on screen and music will play, beeping and a "chopper" noise have also occured. Replaced motherboard in Dec 08.
To isolate the issue.please connect the notebook to external monitor with the help of VGA port.(Blue PORT) on the notebook.if it good with out any lines.you need to fix the LCD screen of the Notebook.
May 10, 2009 | HP Pavillion ZV6000 Notebook
How do I make my alarm on my Bose Wave Radio play the FM Radio instead of the usual beeping noise?
When you choose the alarm button on the back row of buttons in the middle you get 4 options, no alarm, beeping, music, beeping & music. These are represented by icons on your front panel the note and the ))) sign.
Regards
Derek
Dec 20, 2007 | Bose Wave Radio
Music Won't Play
ok I had this happen before
Try unplugging the possitvive battery from your car let sit for 5min or open the doors and turn the key making sure that your car is completly dead. then put the possitive wire back on.
this will reset the deck and make sure you also have the setting s correct I thin it called I tunes is set to on in the menu opptions
May 01, 2007 | Alpine CDA-9855 CD Player
Cassette player on mx-d302t
Hi As you know cassette decks have been around along time, and as such they are fairly robust. The vast majority of the time, problems like you are describing are the result of a broken drive belt, or bad capstan motor. This is not true for all, but if you have favorite tapes you wish to play, you need the deck fixed, and if the problem is drive belt or motor, the repair normally should not be hugely expensive. Hope this helps, good luck!
Feb 23, 2007 | JVC TD-W118 Single Cassette Deck
Portable dvd doesnt play movies
Try cleaning the lasers lens with an anti static cleaning wipe. I used " nice'n clean" that I had purchased from Walmart to clean my laptop screen. My dvd player started back playing after gently wiping the laser lens.
Jan 05, 2007 | Apex Digital PD-450 Portable DVD Player
Alpine CDA-7998 CD Player Logo
226 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
