Question about eMachines T6524 PC Desktop
Emachines d3315 video failed - no signal to monitor.
Put in new pci e card but still no video.
  • Thomas F. Schneider May 11, 2010
    Did you remove the old Video software and install the new for the PCIe card? Are you sure that the driver is for the version of windows that uyou are running?
    Genius:
  • 1,226 Answers
Is the system work using the old video card? if yes then, use it and then reconfigure the in the bios setup using the PCI video card. You can insert it simultaneously and then use first the old video in preparation for the configuration using the new PCI video card
melnavz
Posted on Feb 13, 2009
Monitor not working with desktop T6410. been working fine but won't work today. it say no signal, R G B and monitor shuts off
Most likely you have an integrated video card. I would suggest taking out the ram and see if your machine beeps. We know it is not the monitor itself. Since its an integrated video card off the board try using a PCI spare video card if you have one or an AGP card and restart the computer and see if you have video. The bummer about these machines is that you have to replace the board to repair this or use an external video card that will work with your machine. AGP or a PCI slot has to be available and it has to work with your make and model computer. Contact support online and see what upgrades are available.
Personally integrated hardware is a pain to deal with. Factory hardware is something you cannot get over the counter often times if your lucky you may be able to get a PCI card to work. John
Apr 09, 2012 | Computers & Internet
Monitor say RGB no signal?
If the monitor works with other computer then the video card in the computer where the monitor does not work is bad. You need to replace the video card. If the video card is on the motherboard, just replace it with a video card that fits into one of the PCI slots. If you were using VGA then purchase a PCI VGA Video Card.
My emachines d3315 will power up but there is no video, monitor displays "no signal"
This is quite a common problem, if everything has power then you need to look beyond, this sounds like its your video card, if you have more than one video card slot (these look different to the pci slots) then you can swap them over to see if its the slot, if not then you need a new video card my friend, if thats the case get the model number off of the card you have and search it on amazon
Mar 30, 2011 | E-Machines eMachines Desktop PC
EMachine T6522 monitor says "no signal input" when turned on. tower switch light on and motor seems to be running. Nothing but above message on monitor. Checked both ends of cable and unplugged tower and...
This could be an issue of a video card gone bad. I have experienced the same issue firsthand. This could also mean that no RAM is installed. If you have been using this computer previously, the second option is probably not even an option.
If you have another computer available, please try plugging the monitor in to that machine to test. If it works, your Video Card is more than likely toast.
But not to worry, you should be able to find a new card for that machine. I believe it will be a PCI Video Card, which may run you anywhere from $20-$100 depending on what you purchase. Please consult with eMachines before ordering a new card. Some will not work with your machine.
I hope this helps you out. Have a great day and please don't hesitate to ask any further questions regarding this issue.
Feb 26, 2010 | eMachines Computers & Internet
Im trying to install a new video card on an emachine and i keep getting a no signal input on the monitor. thats what i started with.
Is the new video card compatible with your motherboard?If it is , can you try connecting your monitor VGA Cable from your video card properly?
And also if you are using a PCI Video Card you should try to install it to another slot if theres an instance that a PCI Slot doesnt work.
Jan 07, 2010 | E-Machines T6528 PC Desktop
EMachine stopped displaying video (card not working, just mobo)
Hi there
I would say it's the graphics card that's failed. You might get the same beeps for faulty card as removed card....
Take it to a shop where they can test a compatible card, before they sell you one or install one for you.
Jan 09, 2009 | E-Machines eMachines Desktop PC
Emachines w3609
Hey iluvyakatu
Does your emachine has inbuild video card or AGP or PCI card? if one it has AGP or PCI card try to reseat it. If it is inbuild try to use AGP card or PCI card and see what happen. Also try to check whether you have an inbuild video and AGP or PCI both installed, if you have both try to use one of them.
good luck
zinja
Sep 17, 2008 | E-Machines eMachines Desktop PC
No Video Signal
reboot in safe mode, safe mode will put the pc in vga mode and use whatever video it can find.
If no good U may have a problem with the MB.
May 23, 2008 | Gateway GT5228 PC Desktop
RESTORE DISC
The 'test screen' of the monitor means only that the monitor would display if it receives an input signal.
Make sure it isn't something simple like dislodged video connector on the back of your system box.
You may even want to removed the plug and reinsert it several times in case a sync signal contact hasn't taken a hike.
If this doesn't help, your restore CD won't help either; it means that the video signal (there are several: Red, Green, Blue plus two synchronization signals) is incomplete or missing altogether.
If the video connector is attached to the strip with many others, then the video is on the main board (common on lower end systems) and the chip supplying video has failed.
This doesn't make the system worthless as you can buy dozens of different video cards to plug in to the main board and disable the on-board chip.
I don't know how old your system is but you will likely need a PCI video card (check your manual for the types of buss available for 'add-on' cards) to install and then possibly new drivers from a supplied CD.
This is a pretty simple procedure and even the Chinglish instructions are normally enough to guide you.
Until you can see your system's boot sequence appearing on screen again, you won't be able to restore anything.
May 05, 2008 | E-Machines eMachines Desktop PC
eMachines T6524  PC Desktop Logo
196 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
