Question about Hotpoint Ultima WF860 Front Load Washer
Drum wont move
Hotpoint ultima condenser dryer tc71 power going through it can hear but drum wont rotate
  • geogth Feb 26, 2009
    I have the same problem.The motor is not turning but if i give it a start by hand it then run ok.Any help please.
  • 3 Answers
Its fixed! The starter capacitor was blown.
Posted on Feb 27, 2009
    President:
  • 1,902 Answers
Check the motor and the belt on the back of the unit behind the rear plate. Make sure that the belt is attached and the motor is spinning. If this helped please rate. Thank you
Posted on Feb 12, 2009
Hotpoint ultima tumble dryer
sounds like its blocked with fluff somewhere and your element could be wet take off the back and check your element and if water around it you need to compleatly clean out your filters and down where the condenser is then leave it for a day or two to compleatly dry the element
Apr 07, 2014 | Hotpoint 1701746 Ultima Tc71n Condenser...
Hotpoint aquarius condenser dryer tc71 does not heat up
These washer dryers have a lot of problems. you are better off getting a seperate dryer.
Mar 07, 2010 | Dryers
My hotpoint ultima wont spin, its as thought something is preventing it for spinning. When its switched to spin cycle it turns a little to the left, then a little to the right, but cant seem to go any...
Things that couse this are, worn motor brushes, unplug remove the top, the motor should be at the top, if so remove the wire attached to the spade of the grey cartridge then unclip using a very thin screwdriver pushed down the back of the cartridge, and slide out if there is only a small peice of brush showing they must be changed, if ok spin the drum by hand if it moves freely the the drum is ok, the last thing to check is if it moves through the wash, but its just the spin that it wont move, there is a blockage, and the preassure vessel wont allow it to spin.
Jul 10, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint condenser dryer drum workinbg no heat
check the temperature switches in the back for continuity and also the moisture sensor on the exhaust housing at the rear of the unit. all these switches should be normally closed.
good luck...jay
Apr 23, 2009 | Hotpoint Dryers
Hotpoint ultima condenser dryer TC71 is running cold
Thermostats rarely go. You could have a bad heater or even a voltage problem. Even if the dryer runs, the voltage can still be wrong, it only needs 110 volts to start the motor but must have 220 to have heat.
Apr 06, 2009 | Dryers
Hotpoint Ultima Condenser Dryer - where is the reservoir?
under the door, you need to take the small panel off and its there.
Mar 03, 2009 | Hotpoint Dryers
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Feb 16, 2008 | Dryers
Ultima Condensor Dryer
on the back of your dryer you have a heater behind the protruding panel... Either you heater element has gone, but most like the thermal cut outs have blown...these are located in the same area..they are small and round looking and are connected to them are wires either side. Anyways check the conitunity of the termal cut outs using a tester if no continuity then they are no good... hope it helps...
Nov 18, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
249 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
