Question about Hotpoint First Edition FEW12 Front Load Washer
Even when not programmed to the washer/dryer fills up with water?
When not in use if we leave the door open and say go to bed by the morning the drum would have filled up with water and leaked all over the floor? We are having to close the door at ALL times just in case the drum randomly fills up with water.
Please help with a poss solution
    President:
  • 1,902 Answers
Check the water inlet valves, located where the water lines plug into the machine. Also check for proper water pressure and make sure that your water pressure is not surging. If this help please rate. Thank you
Posted on Feb 12, 2009
Fills when not being used
where the water pipes plugs into machine it has a water stop valve there. turn water off at mains and unscrew pipe. it may have a blockage of some sort keepng the valve open. hope this helps
Feb 14, 2012 | Hotpoint First Edition WMA22 Front Load...
Whirlpool Duet GHW9100LW1 fills up with power off
You have a faulty fill valve
If you want to check which one, try turning off the cold supply only before you go to bed
If the washer has water in it next morning it is the hot valve that has gone faulty if it is dry then it is the cold one
They are easy to change and can be bought from a number of suppliers
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When machine is not in use, with door open, tub will have water
Drum keeps filling with water even in dryer mode
Open up the top of the machine. Plug off the wall mains. Turn off the wall faucet. How is the wire connection for the inlet valve, the water inlet. Fine? If not unscrew the inlet valve from the corner of the machine after disconnecting the hoses, & dismantle to clean it up, re-assemble, refit back to machine.
Mar 27, 2009 | Hotpoint Aquarius WD640 Front Load...
Washer Dryer - drum is filled with water even when switched off and door can still open!
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Oct 31, 2008 | De Dietrich LZ9619 Front Load Washer /...
Neptune Dryer
the belt needs to be replaced. open the front of the dryer, remove the bulkhead and install belt. or call your service guy and have him do it
Sep 04, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
Inside of Washer Smells
often in washing machines there is a drain trap which needs cleaning out from time to time, (usually accessible from the front behind a removable facia) The manual should tell you how to clean this. you need to drain the water first (as there is often a little water still in the system). if you look on the program dial there is often an item that has an arrow pointing down, this should be the drain program, after this is done you can remove the draining cover and clean the workings inside, hopefullt this will solve your problem :)
Sep 27, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Water in drum
It sounds like you have a faulty fill valve that is leaking by. The valve has an electric solenoid but also has a small diaphragm that needs to seat properly to keep the water supply from coming in. If the diaphragm is not seating correctly for whatever reason, water pressure alone can keep water filling into the wash tub. Even the smallest amount, over time can cause problems. One way to test the theory is to shut off the water supply before you go to bed. If the tub is still empty in the morning, more than likely you have a bad fill valve. Let me know if this helps.
Jul 09, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
Hotpoint First Edition FEW12 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
