Question about Yahoo Messenger
Yahoo messenger 9 crashes every time I get a message
Windows vista, newest version of yahoo messenger.
it worked fine a few days ago, I have no idea why this happens now
  • 40 Answers
Hello.
Many of the problems with yahoo messenger are solved by following the steps on this help page ->
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/notices/mstabuguqscripterror.html
Also it helps to have internet explorer set to be your default browser.
Hope this will help you with your problem.
Have a great day.
/Tech5508
Posted on Feb 13, 2009
My yahoo messenger is locked 81003003
HI.......................
it has errors
Messenger "9" 1st version was in Beta (testing) form. The newest version is not, But it's not working well either. Stick to 8.1 until they work out the Bugs. Including people using 8.1 trying to message ones with 9 or reverse they are having compatibility problems; like text not showing,pictures not showing. It shuts down on Vista users , not allowing people to log in.Web cams do not always work. Many things do not work or are missing that YM 8.1 has. It Seems for Vista users it is so buggy Yahoo is giving up on it and are no longer trying to fix it. http://www.ymessengerblog.com/blog/2008/...
You need to remove version 9 completely 1st to Get version 8 to work.
Use this method: Start,My PC, C drive, open Program files.Next open Yahoo file then Messenger file.Click on UNWISE to Un install messenger 9 completely. Do not just delete yahoo file as this can cause problems with other Yahoo programs.
Download the newest 8.1 here http://download.yahoo.com/dl/msgr8/us/ym...
Your contacts list and messages are stored online and will be there when you return to 8.1 messenger.
Another big problem is with the latest update for Flash Player
Flash player 10 Does have conflicts and is causing things to not load or just crash upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel, then download the older version.
http://www.download.com/Adobe-Flash-Play...
Some people are losing signal,things fade out, freezing up or getting disconnected . This can be caused my running low on virtual memory! You can increase your memory by going to start button, settings, control panel, system, advance tab, performance, advance tab, virtual memory, change it, make it 1500 kb or higher, In both boxes, click apply then ok . This applys for all instant messengers,MSN, Yahoo,skype ect.
More help can be found here; http://www.freecreed.com/userid.html.
GOOD LUCK........................
Sep 22, 2011 | Yahoo Messenger
I cannot fully load my web cam. yahoo freeze ups , missing memory on yahoo
If you are using messenger9 you need to go back to 8.
Messenger "9" 1st version was in Beta (testing) form. The newest version is not, But it's not working well either. Stick to 8.1 until they work out the Bugs. Including people using 8.1 trying to message ones with 9 or reverse they are having compatibility problems; like text not showing,pictures not showing.Chat rooms not found or opening. It shuts down on Vista users , not allowing people to log in.Web cams do not always work. Many things do not work or are missing that YM 8.1 has. It Seems for Vista users it is so buggy Yahoo is giving up on it and are no longer trying to fix it.
Download the newest 8.1 .
Thanks
Arnob
Apr 22, 2011 | Yahoo Mail
Yahoo messenger 10 crashes
Are you using the Windows Blinds program? This is a Windows OS skinning program, and there is a conflict between it and yahoo messenger. There is a simple fix for this. Exit Yahoo Messenger by right clicking Yahoo icon by your clock and choosing Exit. Then right click the Yahoo Messenger shortcut on your desktop and choose Properties. Click the Compatibility Tab, and check the box that says Disable Visual Themes. Click OK. Restart Yahoo Messenger.
If the above does not apply to you then be sure to exit yahoo messenger first, by right clicking the yahoo icon by your clock and choosing exit, before you do the following steps:First, clear out your yahoo cache. My Computer/ C: drive/Program Files/Yahoo/Messenger/Cache. You can delete everything in the cache folder. I am not sure of the path for Windows Vista.
Next thing to try is to change your connection settings. Go to top of YM and click on Messenger and then Preferences. Go to the Connections page and try these options, no proxies or no network detection (try one than the other). Click OK after choosing one. Yahoo Messenger will need to close to change the settings.
Do you have the latest Adobe Flash Player installed? The latest version is 10.0.22.87. If you do update this also you can uncheck the box for Google toolbar that is on the download page, it is totally optional. After the installation box pops up, close all browser windows before installing. Important: Yahoo Messenger relies on Internet Explorer so be sure that when you update Adobe Flash Player that you do it in Internet Explorer. If you also use Firefox you will also eventually want to run this same page in Firefox and check your Adobe Flash Player version but the one that matters for Yahoo is Internet Explorer.
Do you have the latest Sun Java? The latest version is Version 6 Update 14.After you install the newest sun java uninstall the old ones through add/remove programs. Well I hope something here is of help to you. Please remember to choose a best answer and give feedback. I would also love to hear which of these solutions, if any helped you.
Apr 07, 2010 | Yahoo Messenger
My Yahoo Messenger keeps closing
my yahoo messenger keeps closing (crashinggraying out or sleeping not able to open to do instant messeging
Nov 28, 2009 | Yahoo Messenger
Yahoo messenger error 81003016
HI welcome to fixya free solutions. you are getting this error because of connection error! try to go to messenger then connection preference, its on the top left of your yahoo messenger..choose connect directly to the internet then apply. mess 9 noted for this error.
Messenger "9" 1st version was in Beta (testing) form. The newest version is not, But it's not working well either.Try using 8.1 "the newest before 9", until they work out the Bugs. Including people using 8.1 or older versions trying to message ones with 9 or reverse they are having compatibility problems; like text not showing,pictures not showing.Chat rooms not found or opening. It shuts down on Vista users , not allowing people to log in.Web cams do not always work. Many things do not work or are missing that YM 8.1 has. It Seems for Vista users it is so buggy Yahoo is giving up on it and are no longer trying to fix it. http://www.ymessengerblog.com/blog/2008/…
You need to remove version 9 completely 1st to Get version 8 to work best.Left over files and fragments from using control panel to remove messenger can cause problems/conflicts with the new download.
Download the newest 8.1 here http://download.yahoo.com/dl/msgr8/us/ym…
And it works well with Vista.
Flash player 10 Does have conflicts and is causing things to not load or just crash upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here.
http://www.download.com/Adobe-Flash-Play…
Some people are losing signal,things fade out, freezing up or getting disconnected . This can be caused my running low on virtual memory! You can increase your memory by going to start button, settings, control panel, system, advance tab, performance, advance tab, virtual memory, change it, make it 1500 kb or higher, In both boxes, click apply then ok . This applys for all instant messengers,MSN, Yahoo,skype ect. And yahoo games.
If none of these work for you then kindly do comment back to me.
Aug 05, 2009 | Yahoo Messenger
My yahoo Im stops working
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
http://www.ymessengerblog.com/blog/2008/10/27/installing-90-on-windows-vista/
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.html
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
Here is the best help/fix it sites I have found so far for Messenger,chat,and Yahoo in general. http://www.helpbytes.co.uk/ This one for Vista http://www.vista4beginners.com/tips-and-tricks
many problems solved using this link http://www.freecreed.com/
Dec 11, 2008 | Yahoo Messenger
Yahoo Messenger 9 Vista Installation Problems
Dec 09, 2008 | Yahoo Messenger
My yahoo messenger application is not responding
http://help.yahoo.com/l/us/yahoo/messeng...
Yahoo messenger 81003005 problem
To get away from errors you need to use YM8.1
Download 8.1 here;
Yahoo 8.1: http://www.soft32.com/download_30.html.....
Flash player 10 Does have conflicts,and 9's latest update 9.0.124.0 Can have conflicts with Yahoo(very rarely, if you are using it with no problems keep it) and is causing some Yahoo Messenger services to not load.Use the link below for a download of Flash player #9.0.115.0 It should work as it's the latest before 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel, then download the older version.
http://www.soft32.com/download_500.html....
More help can be found here; http://www.freecreed.com/userid.html...
3 weeks ago
Source(s):
Soft 32 is showing "errors" on the link. updated links;
Download 8.1 here http://www.filehippo.com/download_yahoo_...
http://www.adobe.com/support/flashplayer...
Nov 28, 2008 | Yahoo Messenger
Vista installed messenger logs in starts download of addresses and quits
you might want to download version 9 it's out now
might have fixed all those bugs that beta has
http://messenger.yahoo.com/download/win/
Oct 18, 2008 | Yahoo Messenger
Yahoo Messenger Logo
232 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
