Fuzzy tv screen that says lost signal (no dishnetwork signal)
Fuzzy screen says no signal. television is on channel 3, how do I regain the signal? seems to only be one dish box which is in the bedroom but the lost signal is in the front room. Signal in the room with the dish box is working fine.
  • Anonymous Mar 14, 2014
    I have two dish boxes one in our room and back room and dvr in front bedroom and livingroom have partial and complete signal lost in our room and back room but have everything in the front bedroom and livingromm what is the problem?
  • 57 Answers
Here are a few suggestions,
*Check your connections to make sure none are loose.
*Try checking the Dish box to make sure everything that should be turned on is actually on.
*Also make sure channel 3 is the correct channel by contacting your service provider.
I hope theis solution is helpful. Please take a moment to rate this solution.
Posted on Feb 12, 2009
Lost signal
You have changed channels and now it's on the air. If your box is providing a signal on the 3rd or 4th channel you have to get back to those.
Aug 29, 2017 | Televison & Video
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
My panasonic TX37 lzd 80 tv has on screen message no signal on some freeview channels and the picture is fuzzy
Change your main board but before check if the power supply is ok. Good luck,
Serge.
Feb 26, 2016 | Panasonic Televison & Video
Lost ABC channels on retune, how do I regain reception
Try manually entering the channel number. Many TV's have, besides autoscan, a way to manually add or remove channels.
(Besides, what is worth watching on ABC? (;^D)
Oct 21, 2014 | Televison & Video
Colors are wrong
Do a factory reset:
Try this:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Dec 24, 2013 | AOC L24H898 24 in. LCD TV
The dish network is not working correctly in another room for two tvs what do I do?
Hi dmarshall020my name is Mike Houston of DISH Network and I was looking at your post and seenwhere your having problems with two TV's in your home. Depending on if it's TV1or TV2 and what is on the screen, if it's a black, blue, or snowy screen willdepend on the channel it is set to. For TV1 you will want it on channel 3 or oneof the inputs of the TV. If it is TV2 you will want to put it on channel 60 or73, I will send a link to help with these steps and if the problem still existplease e-mail me at Michael.houston@dishnetwork.com.http://www.dishnetwork.com/SupportSection/video
Feb 18, 2011 | Insignia NS-LCD19 19 in. LCD TV
New TV won't pick up existing dishnetwork signal
Hope u are not working in the basement.
Apr 27, 2009 | Televison & Video
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Trouble regaining tv picture
It sounds as though the TV [video monitor {Hitachi}] is not set to an input that is sending a signal. Snow is the result.
Cycle through the inputs on the set with ALL devices ready to send signal.
If you have good access to the input area you should see all of the names and what is plugged into each.
Jul 27, 2008 | Televison & Video
Record tv with Panasonic DMR-E75V DVD Player / VCR
Not sure about this, but my guess would be that you don't have the correct channel set on the DVD recorder. It has to be the channel that you use to receive your signal, NOT the channel that you necessarily want to record. For instance- if you use channel 3 to receive your signal from dish, cable etc but want to record a program on (hypothetically) CBS which is (again hypothetically) channel 24 from your dish or cable provider you would go to "Prog/Check" on the remote, highlight the "New Timer Program" line and press "Enter", and then use the numeric buttons to select channel 3 (the channel you use to receive your signal, NOT 24, the channel you want to record). You will have to program your dish/cable box to provide the channel with the content you want to record, in this case- 24.
Not sure if that was your issue, but hope this helps.
Jun 15, 2008 | Panasonic DMR-E75V DVD Player/VCR
Televison & Video Logo
477 people viewed this question
Top Televison & Video Experts
