Question about GE Profile Spectra JGBP79 Gas Kitchen Range
Stovetop burners won't stay lit.
I have a GE Profile Gas Range JGP79AEW1AA that's approximately 12 years old and recently the burners on the stovetop won't stay lit. The burners light without a problem and then after a bit I start to hear a sputtering sound and the burners will go out. It's happening to all 4 of the burners on the top of the stove. The oven does seem to be working fine but I haven't used it for any extended period of time lately.
I have already called the gas company and they are telling me that it is a problem with the stove itself.
This is a very big concern for me because the burners have gone out without my realizing it and the house has filled with gas. I now have to stay at the stove the entire time it's on to ensure that the burners stay lit.
I would appreciate any help or advice on this matter.
Kim
  • 1 more comment
  • John Hall
    John Hall Mar 09, 2009
    Burners will ignite only part way around the burner head, have a weak flame, sputter and usually go out. Leaving the ignition (sparker) on helps somewhat. Blowing gently on the flame either blows it out or spreads it around the burner and then they go out. Happens to all 4 burners. This is not after the burners have been cleaned; it just spontaneously happens. Has happened previously for short periods, then corrects itself. This time the problem continued for longer than usual, then went away. It acts like the gas is bad, like it's mixed with something that won't burn (CO2? Nitrogen from a line purge?) This is on a 20 year old Tappan range burning natural gas from a large SE Michigan utility co.
  • rsrchandra Mar 26, 2009
    same problem...when burner is lit .. i hear only sound ...i had to off but when i lit inside the burner it works well giving good flame...why is it like that..? ..Is the problem with the stove or with gas..??
  • fixmystove Apr 27, 2009
    I Have A Kenmore Gas Free Standing Range And It Does The Same Thing. It Will Light And Then About 45 Seconds Later It Will Slowly Decrease Until It Goes Out. Then The Gas Will Stop Spewing And After About 30 Seconds Come Back On.
5 Suggested Answers
  • 213 Answers
SOURCE: ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Posted on Nov 21, 2007
  • 33 Answers
SOURCE: Viking 4 burner gas range
if you are not hearing the faintest sound of clicking / sparking you could have a bad spark module or even bad burner switches i doubt that all switches went bad at the same time but its possible unplug oven check wireing to switches and spark module if you pull your burner knob off thats the switch starring at you follow wires and check for any loose connections
Posted on Jan 02, 2008
SOURCE: cleaning and care for my GE Profile stovetop
The one thing I don't suggest is using the Ceramabryte product the dealer left with us. It leaves a greasy film. When I get ready to clean my black GE Profile, I pull off the controls to wash separately. Then I lift off the grates, take a single-edge razor blade to scrape anything stuck on (it doesn't scratch), then I use baking soda and scrub and scrub with lots of paper towels. Then I start cleaning off the baking soda with lots and lots more paper towels. There is still a film, but at least it's not greasy. At this point I grab some more dry paper towels, pour on a 3' puddle of rubbing alcohol and wipe it all over the stove top and front. You may have to do this twice. Then, if I don't turn on the hood light's brightest setting, it really doesn't look too bad. I have to do this at least once a week, as I have never had a stove that got so dirty so fast and was such a pain to clean.
FYI, I would never buy another of these stoves. Besides the cleaning issue, there is the fact of having to replace the igniter (glow plug?) twice in the first four years. My old, bottom-of-the line Magic Chef went 25 years with the first replacement not coming until it was about 15 years old. Also, the broiler is unimpressive and steaks, etc., just sort of steam. Can't get a really good crust going. It's a slide-in and the top is very narrow, front to back, because of the slanted control panel on the front, and so you really can't put two large pots or pans on one side. Let's see....oh yes, I ordered the unglazed grates for safety reasons and it came with the procelain glaze. Those were replaced free of charge, though I had to go pick them up. Then the first set of unglazed grates began to rust about six months into use, so had to be replaced (again, no charge at least). Recently I noticed that the inside walls of the oven, where the racks slide, are starting to rust. Finally, the burners are difficult to calibrate, which I really notice when I try to cook rice, which comes out right about 50% of the time.
Now, on top of all this, I have to worry about the glass door exploding?!?! Should I ban my grandchildren from the kitchen? Has anyone from Consumer Reports seen this website?
Posted on Apr 03, 2008
rickzilla
  • 706 Answers
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
SOURCE: GE profile gas range: Gas burners don't work
Used toothpick to unclock gas output and worked great.
Posted on Jan 23, 2009
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
We spilled liquid into the gas burner by accident and it won't stop clicking. We can't find how or where to unplug it? GE PROFILE GAS STOVETOP RANGE
Won't stop clicking?
When?
Is it clicking constantly or only when you attempt to ignite a burner?
Normally the clicking can be traced to the electronic ignition that activates when you turn the burner on.
Regardless if you need to turn it off but do not have easy access to the back of the unit, you can always shut it off at the circuit breaker located in the breaker/fuse box.
Hope this helps but if not just let me know.
May 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE gas stovetop burner doesn't light
there are sparker modules on each burner behind the button, it may be that yours is failed, if you turn on other knob and you see spark at problem burner and still isn't lighting you have to make sure the black or grey tops are paced on perfectly, just give them a little nudge and you have to make sure area is perfectly clean for spark to take effect, spark will go for cleanest area on metal. so ensure area is clean and check burner top
Feb 05, 2010 | GE 30 in. Profile JGP979 Gas Cooktop
GE stovetop with propane, too hot to simmer
I think you are right. Check for an optional valve for propane in your service manual or online on an appliance parts website. You can look up a schematic of all the basic parts.
Dec 03, 2009 | Car Audio & Video
Profile stovetop spark element will not stop firing all 4 burners are sparking and will not stop unless I unplug the unit
You have a bad spark switch on one of your burner switches.
Remove the control panel to access the switches and burner stems. Carefully remove one wire at a time from each switch. When the sparking stops,that will be the bad switch. Replace the bad spark switch.
Oct 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Drexia clarifying previous post on gas range stovetop cleaning.
I have found that kitchen cleanser and a crub pad along with good old fashioned elbow grease is your best bet...
The fine scratches might come out with a good rubbing compound like the type used on car finishes...
Apr 10, 2009 | Frigidaire Gallery 30" Self-Cleaning...
How to light stovetop pilot light?
This cook top uses an electric ignitor and does not need to be lit.
Nov 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Dec 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas Burners Not Lit Completely
sounds like there isnt the right amount of gas coming out of the orifice. orifice could be partially plugged
Oct 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP79 Gas Kitchen Range Logo
868 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
