Question about Reddy Heater-30-55,000 BTU Variable
Dyna glo torpedo heater has e 1 error code and shuts down
When i remove the top cover it runs great any ideas
  • thebest0106 Feb 19, 2009
    did finally get a gauge for the air pressure and did increase the air pressure to the proper psi works great thanks
  • tattookings
    tattookings Dec 24, 2012
    I found that turning the pressure knob that controls the air flow of the fuel pump has different effects on it
  • 181 Answers
You either have too much air pressure or you don't have enough pressure.do you know what your pressure is set at.
Posted on Feb 17, 2009
  • James Espedido
    James Espedido Mar 02, 2014
    Supposed to be at 6.9 but won't go above 6.7 on the electronic gauge on the system
  • steve
    steve Mar 04, 2014
    have you taken the air pump apart?. is there any wear on the housings front or back. if there is, you need to clean them up and make them flat again. pump rotor shouldn't have any wear either. change if it does. reinstall pump covers and recheck air pressure, new filters also.
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Fuel shut off switch
Replace the thermostat.
Jan 23, 2014 | Dyna-Glo Heating & Cooling
WE HAVE A 170-210 KEROSENE HEATER DYNA-GLO PRO IT IGNITES FOR 10-15 SECONDS THEN CUTS OUT,CAN YOU HELP
That sounds like a bad photocell or a dirty photocell....check the photocell and clean it firt and then replace if neccesary...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 27, 2011 | Heating & Cooling
Can i convert my dyna glo 75000 btu propane
I'm sure you can, contact the manufacturer and ask if they have a natural gas jet or orfice for your model heater, these are usually very easy to replace.
Feb 28, 2009 | Heating & Cooling
Shuts off when switched to low and smells when running.
clean the burner and the orifice you can use a air line or blow off a vacum cleaner
Nov 20, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Feb 03, 2008 | Dyna-Glo (PPH16-LP) Utility Heater
Dyna-glo glass globe
go to this site they have mica windows and accessories for your heater:
http://www.milesstair.com/accessories.html
Nov 27, 2007 | Heating & Cooling
Reddy Heater-30-55,000 BTU Variable Logo
639 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
