My 4 year old Inglis top loading wash machine has stopped spinning in the rinse cycle. The water still pumps out, and you can hear the machine click into and run on the rinse cycle, but if you lift the lid you can see it is not spinning. Is there an "at-home" fix for this?
  • Priya darshan May 11, 2010
    It doesn't pump or spin
    If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
    • If
      the motor is running, your washer probably has a frozen pump pulley or
      a broken pump belt. To check the pulley, remove the pump from the
      washer and try to rotate the pulley manually. If it doesn't turn
      freely--if it's frozen or stiff--replace it. If the pump belt is broken
      or looks quite worn, replace it--but be sure to check the pump pulley
      before you change the belt.
    • If the motor isn't
      running, the lid switch may be defective. If so, the washing machine
      can't spin and may not function at all. The switch is inside the
      washing machine main housing near the door frame. Often you have to
      raise or open the top or front of the washing machine to get to the
      switch. If it's defective, you need to replace it.
    It pumps, but doesn't spin
    If your washer pumps out the water but doesn't spin, check these:
    • The
      lid switch may be defective. If it is, the washing machine doesn't
      spin. The switch is inside the washing machine main housing near the
      door frame. Often you have to raise or open the top or front of the
      washing machine to get to the switch. If it's defective, you need to
      replace it.
    • The motor coupler may be broken. Many
      Whirlpool®-manufactured washers use a small, relatively inexpensive
      motor coupling. It's plastic and rubber and is mounted to the shaft of
      the motor on one side, and to the transmission on the other. Over time,
      the coupler wears out and fails. You may need to replace it.
    • A
      belt may be broken. Many washing machines have one or two belts. If a
      belt is broken or badly worn, you need to replace it with a genuine
      belt from the manufacturer. (Some washing machine belts are designed
      with special characteristics not found in automotive belts.)
    • The
      clutch may be worn. If your washer is a GE, it may use a clutch to come
      up to the proper spin speed. As the clutch wears out, it may prevent
      the unit from spinning well or at all. If the clutch is worn, you need
      to replace it. For this job, you probably want to hire a qualified
      appliance repair technician.
    • The drive motor may be
      defective. Many washer brands use a reversing motor. For agitation the
      motor runs in one direction, for spinning and draining, the other. It's
      possible for a motor to burn out in one direction and continue to
      operate in the other. If this happens, you need to replace the entire
      motor.
    • The transmission may not be shifting properly.
      Older washers produced by Whirlpool® have a transmission with an
      electro-mechanical shifter. If the shifter becomes even partially
      defective, the unit may drain the water but not spin. This is a complex
      system, if your washer has a shifter problem, you may want to hire a
      qualified appliance repair technician to repair it.
    • The
      spin bearing or basket drive may be worn or seized. These components
      allow the inner tub to spin freely inside the outer tub. When this is
      the problem, you usually hear a loud sound during the spin cycle. Call
      a qualified appliance repair technician.
    It spins only with the lid closed
    For
    safety, washing machines are made so that they spin only with the lid
    closed. The lid switch prevents the spinning action when the lid is up.
  • 142 Answers
Without being there to test the switches, my best advice is you have a bad switch. The only thing you can try to do is cycle the switch a few times quickly and see if that frees the switch up. If so, then you know you need a switch after all. That would be the only "at-home" fix you could try.
Please remember to rate this solution.
Posted on Feb 12, 2009
    Genius:
  • 3,422 Answers
HI,
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
    Genius:
  • 2,920 Answers
I think the clutch went out on it,,,if its not spinnig then you have either a bad clutch or a bad belt and from here its hard to tell which. the belt you can do at home if its the clutch youll need to call someone
Washer WPSR3100WOWW Will wash but not drain and spin... Stops at the rinse Cycle
Christina,
Does it leave water inside the tub? There are a couple of possibilitys. One could be the drain pump. If this fails the wash/rinse cycle will stop as it can sense the water not being pumped out. Can you hear the light sound of a small motot running when it goes into rinse cycle? Listen down at the very bottom far right side or far left side. If you hear the drain pump motor running is there any water discharging out the drain tube going into the wall? You should easily hear the flowing water. If not you have a few possible problems: Drain pump has an obstruction in or around it or, drain pump is actually bad.
Oct 12, 2013 | GE WSXH208A Front Load Washer
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
Apr 13, 2009 | Hoover Nextra HNF 2137 Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Whirlpool ingis washer will not engage rinse cycle
make shure the cold water is on and also if it worked before then it cold be two parts 1 the timer is bad or 2 the water inlet valve
Jan 17, 2009 | Whirlpool Inglis IP4400 Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Leaking when entering the Rinse/spin cycle
what is happening is the pump is not pumping the water fast enough. your washer sounds like its a frididaire built washer. there should be a pause where the washer just stops and drains, then go into the spin cycle. so if there is water in the tub and the washer spins it will splash out from the top of the wash tub. you need to make sure the drain is clear, the drain hose is not blocked or kinked, and that the pump is functioning properly. your unit has a electric pump and even though you might hear it running the impellor my be damaged and able to pump the water fast enough.it could be as simple as removing the hose from the bottom of the tub that go's to the pump and removing a sock that found its way in. or just a bad pump. its a simple job to replace it.to get to the pump remove the 2 screws on the bottom of the front panel tilt the washer back a little and slide the panel down. you wil see the pump on the lower left. so check all the things i listed and you should find the problem..Id check the pump first it most likley the problem. good luck
Aug 04, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
