Question about Goodman GMS90703BXA Heater
Heater not starting
I have a goodman heater and it is blinking six times. it read that six blink means open rollout. the roll is good and i still replaced it and the furnace still blinks six times. what can be the problem? the fan works but nofire
  • aldujam Feb 12, 2009
    thanks for the helpful information. i have tried all of what you said except checking the board. if you have any other solutions please do so
    Problem Solver:
  • 11 Answers
Did the furnace kick in at all after you replaced the rollout? if it did run then check the filter make sure its clean, or even leave it out for a bit. if it didnt run after you replace the roll out then switch the breaker off then wait ten seconds then turn back on this will reset the ciruit board and it should try to cycle. next thing you can try is jumper the roll out switch DO NOT LEAVE IT JUMPERED, its just to double check that its not the roll out, if it works jumpered replace the roll out again and try that. if none of that works take out the crews on the ciruit board and check the back. sometime when a ciruit board fails there will be a burn mark somewhere on the back, if there is replace it.
hugh
Posted on Feb 12, 2009
  • vegster Feb 12, 2009
    one other thing is that some furnaces have more than one roll out switch, sometimes there is one at the back of the blower motor which you can only really get at if you remove the motor, follow the wires because they all should be on the same loop. Another thing is to describe to me exacly what the furnace does after you reset it. the cycle should go something like
    1. inducer motor turns on (small motor at the top of the furnace)
    2. this activates a pressure switch and the glow/spark ignitor should turn on (you should hear the spark, or see the glow)
    3. the gas should switch on, you'll hear a click and the burners should light up.
    4. after about a minute the blower motor should kick in.
    if the furnace fails before step one then its either the board or one of those roll outs. if the inducer motor fails to turn on they it might be a problem there. if the inducer motor turns on but the ignitor never turns on it might be a problem with something stuck in the chimney, or sometimes something small gets stick where the rubber hose connects to the inducer motor. if the burners come on for a few seconds you'll have to clean the flam sensor.
    with a little more info i'm sure we can figure this out.
Why condenser won't start board flashes6times meaning open rollout
check your roll out with an ohm meter they should have continuity if not they have a reset button on top of the switch push it and this will reset them. If they don't have continuity they are open.
Jul 17, 2014 | Goodman Manufacturing Goodman DSXC180601...
Top rollout switch triggers with blinking code *6*, Furnace only runs with cover off
restart unit as soon as your inducer fan came on pump the 2 wires to pressure switch and wait to see how long it stay also watch the flame at the burner
Jan 27, 2014 | Goodman GMS90703BXA Heater
Trouble shooting light blinks 6 times showing open roolout!how do i fix that problem!
The flame rollouts are located in the burner compartment and attached to the sides or top of the metal housing around the actual burners. They are small and round and have 2 wires hooked to them. They are there for safety to detect if the flame is rolling out of the heat exchanger, caused by other possible issues. However, sometimes they do go bad and have to be replaced. Also, your rollouts are ran in series with the limits and may also be that. The only way to track it down is to have a meter that measures continuity and after the unit stops working, see which device you lost current through. Bypassing these can be harmful and cause major problems so I do not recommend it. One thing you can try is to make sure all filters are clean and the air flow throughout the house is "normal". These can cause the unit to overheat and trip one of the limit switches that I mentioned earlier. I also do not recommend watching if the flame is coming out of the heat exchanger causing a rollout to trip, but if it is, you could have a blocked flue pipe or other issues. I hope this helps or at least points you in the right direction. Good luck and happy holidays!
Nov 24, 2012 | Goodman GMS90703BXA Heater
My Goodman GMP 125-4 furnace has 4 blinking lights and we currently are unable to get it to come on. What might be wrong?
if this is an error code and you mean that the light blinks 4 times then it is the limit circuit. This could mean either the high limit or a roll out switch is open. the limit switch is right in the center of the furnace above the burner and roll out switches are probably somewhere around the opening of the burner. Follow the wires from the limit to find a roll out switch cause they are in line with each other and the rool out switch could have a button to reset it. However if the roll out is not tripped then you could need to change the limit. Only way to know is to check for continuity.
Dec 04, 2010 | Goodman GDS80904BNA Open Flame Heater
What does it mean when my goodman furnace is flashing a red light and will not work.
It is in Lockout mode. Something has happened to make it go into lockout.
It could be an easy fix. Look of cobwebs in the tubing between the proving switch and the draft inducer motor. Look for air restrictions in the chimney flue. Rusty burners (if applicable). Tripped rollout switches. Some times there could be up to 2 roll out switches on the burner and another in the flue and 2 others in between stuff. . Most times it is a dirty flame sensor. Over the summer the flame sensor gets dusty and the sensitivity gets off. The control fails to FEEL the probe and locks out the gas valve. Most times the failure will be defines by the amount of blinks the red light emits. The sub panel has a guide on it that tells what the blinks mean.
Oct 19, 2010 | Goodman Heating & Cooling
Opened pool. Rheem heater has the service light blinking
rollout switch is open, and sns is a sensor failure. replace rollout switch, clean out vents, inspect heat exchanger. water sensor senses too cold or too hot water
May 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
I have six blinks on my Goodman furnace, not sure what that means
You may have a roll-out switch triggered or a blown fuse on the circuit board. In the burner box, there will be a small round disk with two wires connected to it. It may have a small stem that sticks out between the two wires. Press in on the stem and feel if it clicks. Look for any other disks like this. Look at the fuse on the circuit board. Replace it if necessary. You can jump the roll out switch(s) to test them if you don't have a multimeter.
Dec 21, 2009 | Goodman GMS90703BXA Heater
My heater works fine when its a little cold,when its freezing outside it heats for a couple of airs then it would come on and off fine but with cold air blowing.i looked at the codes it blinks 6 times...
do not adjust your gas pressure without an manometer or if you dont know what you are doing could be very dangerous. Roll out switches are manual reset if you have an open roll out on a Goodman furnace you probably have a cracked heatexchanger, get a qualified technician out there asap
Oct 06, 2009 | Goodman GMS90703BXA Heater
RED BLINKING (6TIMES) ON FURNACE
THE ROLL OUT SWITCH IS LOCATED IN THE BURNER COMPARTMENT MOST CAN BE RESET
Jul 20, 2009 | Goodman GMS90703BXA Heater
Goodman heater will not start have continuous blinking light replaced secondary transformer still no work and continusous blinking verified 120 volts to vent fan but vent fan not running vent fan ohms to...
I cant be sure but usually the constant blink on some boards means reversed polarity. Check your HOT (L1 - Black) comming in to the connector box and the your NUTURAL (L3 - White) should not read any volts to ground (not more than 12 volts on an electronic VOM). If this is opposite remove power and reverse black and white wires and retry.
HOPE THIS HELPS PLEASE GRADE ME ACCORDINGLY and GOOD LUCK!
Mar 03, 2009 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
152 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
