Question about Dell Inspiron 1100 Notebook
How do I get info out of a dead laptop inspiron 1150?
Inspiron 1150 old much loved lap top has some serious problems. It starts, but fails to get through its opening sequence and cuts out when the hard drive wants to start with a 'click'.
I have been told it is a main frame problem, will cost more to mend than it is worth.
I need to get the info off the hard disk. Documents, photographs etc
I've been shown how to unscrew the hard drive... then, what the hell do I do next?
I need another laptop? or pc? to plug old hard drive into make a copy?
Am stuck here. Advice much appreciated
  • scgeraghty Feb 12, 2009
    Hi, I did that first. he said I should take the drive out, then he lost me. I think he said I should undo the hard drive, and plug the drive into another carriage of another machine and plug it in and copy it?????? I think there were several stages to what he suggested.
    Does that sound a possible solution. From what you've suggested it'll break when its taken out
    Sean
  • 77 Answers
Go to any pc tech store, aka best buy, staples, etc...have them help you with your problem, if you open the HDD you will ruin it, and will not BE ABLE to retrieve data
Posted on Feb 12, 2009
  • pcgeek08 Feb 13, 2009
    do you know if the HDD is SATA or IDE?
    IDE is a thin long black plug, usually with a gray flat cable
    SATA looks more like a USB cable
    you might have to find a PC that has both or either
    Oh, that guy at the tech store...he ripped you off, he only did it because he probably doesn't know how to remove it himself ;D
    do you have any other friends or stores that provide that service?
I have the Dell 1525. The screen is black with only the cursor appearing. Please advise
Check to see if you have the machine switched out to a stand alone monitor. This is a feature on many lap tops that lets you re-direct the signal out to a larger monitor, or if your monitor fails you can display the computer info on another screen. This feature is engaged by holding down the Fn key and tapping teither the F4, or F6 key on many lap tops. This feature can be toggled by both displaying at the same time or switched to the stand alone or the Lap top.
The other cause is that the machine has malfunctioned usually because of the CPU failure and there is nothing to boot the machine up.
Dec 30, 2010 | Dell Inspiron 1525 Notebook
Dell 1150 laptop configuration module problem
Hi, you can perform a system restore by accessing safe mode by pressing the ESC button during bootup. Restore system to a time before the problem began. You will need to perform a full virus scan straight after normal bootup is achieved. Hope this helps
Jul 15, 2010 | Dell Inspiron 1150 Notebook
My Dell Inspiron Mini hasn't been used for some time. I've plugged it in, but it won't turn on. What could be the problem and how can I fix it?
The battery might be dead. The first thing to check is the power supply. If the battery is dead, it needs to be plugged into the transformer, but if the transformer is not putting out the required voltage (somewhere around 18V.) then it won't start.
Jun 10, 2010 | Dell Inspiron 1150 Notebook
Inspiron 1150 Latitude D600 14.1 LCD Display-LP141X14 CD-ROM Drive: I installed window xp on my DELL inspiron 1150 lap...
you need the drivers...look here...http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
you will need a computer thats online to download them,, put them on cd or flash drive
May 17, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
How do you reset a Dell Inspiron 1150 to factory settings without a CD?
Option 1.) System Restore.
Option 2.) Format Harddrive to restore to factory
reply: team.akwrite@gmail.com Irving
Mar 16, 2010 | Dell Inspiron 1150 Notebook
Dell inspiron 1150 ethernet drivers
You can download the drivers for dell insp. 1150 laptop from this link. Select your operating system and it will bring up the appropriate drivers for you.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_P4_1150&os=WW1&osl=en&catid=&impid=
If the above link doesn't work then you can copy it and paste it in internet explorer directly.
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 1150 not staying on even with new battery
1.yes this can be fixed.
2.buy a laptop hard drive caddy the ide not sata to gain access to info. you'll need to open the hard tray remove drive place it in the caddy connect ythe caddy to desktop or laptop. start the desktop/laptop go to my computer the pc will give your caddy a drive letter maybe g or e copy your info from that location to disc or local drive.
3.its not a virus. motherboard issue
motherboard cost USD180-240
Apr 15, 2008 | Dell Inspiron 1150 Notebook
Inspiron 1150 screen is black
It is one of three things usually Bad cable at the hinge, Failed inverter board, or failed backlight. Probably inverter. Not to difficult to repair. Check cable first because it is inexpensive and easy. Check the inverter and replace if needed . Sometimes you can buy one used cheap with a bad motherboard and swap the top.
Jan 19, 2008 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 1100 Notebook Logo
53 people viewed this question
Alun Cox
