Question about Denon AVR-3300 Receiver
How do I set radio stations without the remote control
I have a Denon AVR-330 with no remote control. How do I set the radio station presets - either automatically or manually. Hard to figure out when I just have the front panel controls, not a remote control!
  • 119 Answers
Without the remote there is no way to set radio stations
http://www.usa.denon.com/avr3300_ownersmanual.pdf
Posted on Feb 25, 2009
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
How to tune in radio stations on a mini system without the remote
Hi, with just the controls on the unit itself you cannot set the radio station presets. They are set by holding down one of the numbered keys on the remote while in radio mode. The letter P with a flashing number will show up on the display to indicate you are setting that preset, radio will stop flashing and station will be locked into memory.
Aug 21, 2013 | JVC FS-2000 Shelf System
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
Have a denon avr 3300 with no remote, how can i program radio stations
Hi hodgie00,
Sad to say but manual/auto tuning set-up can only be access through the remote control button. There is no button in the front panel that can access the command to this set-up. Also this is stated in the Denon AVR-3300 manual.
Click this LINK to have the replacement remote control if the original was already faulty or misplaced.
Hope I helped you.
Have a nice day!
Apr 28, 2011 | Audio Players & Recorders
I lost the remote to my denon avr 3600 receiver....how can i change the stations on the tuner???
I just tried doing it on mine from the panel and I could only change the presets
Oct 24, 2009 | Denon AVR-3600
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
How do I preset radio stations on my hi-fi system?
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Apr 28, 2009 | Denon DRA-375RD Receiver
Bought n older avr 3600 cant get inputs to work
you have to have th stations already preset into the denon for the preset buttons to work
Feb 01, 2009 | Denon Audio Players & Recorders
Denon avr-1700
If you have the owner manual check for reset and reset the unit. If you don?t have the manual unplug the power cable for a wile and then try again. Good Luck Toufic Malek
Sep 23, 2007 | Denon AVR-1700 Receiver
Denon AVR-3300 Receiver Logo
1,122 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
