Question about RCA 20F420T 20" TV
Security camera hook up
I am trying to hook my security camera up to my tv.
is if possible and if so, how do i do it.
thanks for any help.
  • 1,498 Answers
Hi Boybest,
Yes it's possible.
You have several options with your TV. You can use the Video-In from the auxiliary/line in or even though a VCR. The plugs in this case use what are called RCA Jacks. They travel in three's, one yellow, one red and one white. The yellow is the Video.
Any hook up is going to be dependent upon the output from your camera. Security cameras, for the most part output a video signal much the same as a VCR. Some however use RF (Radio Frequency) which requires it to be attached to a cable or antennae jack and then tuned in (usually channel 3 or 4).
If it's a straight NTSC Video signal there should be no problem. A long cord with RCA jacks to the Video-In would do it. Then you could switch the channel to AUX or Line One (which ever your model uses) to get the camera signal.
Computer cameras have a whole different way of doing things. If you run into any snags, comment me back with the make and model of your camera. I'll get you up and running.
BTW, good things come to those who rate. ;-)
Hope this helps.
Mike
Posted on Feb 12, 2009
How do you hook up security cameras to my tv
The a v leads( red and white and yellow usually) should fit into corresponding sockets on most modern tvs. Then put the tv onto a/v input. That should do it. For more than one camers, use an a/v switching box to take the camera inputs and then use the switch to see the different camera streams.
Nov 10, 2017 | Hook Up Home Security
We have a new TV, old surround sound, old dvd player & want to get Blu-ray player with component video output to work with our surround sound. Is this possible & Which Blu-ray player?
component video output is not going to help you hook it up to a surround system. component video is just that - video. No audio signal is carried on it. You would be better served hooking your blu-ray player to the tv via hdmi cable and then running an optical cable from either your blu-ray player or your tv to the surround system (assuming your surround system has an optical input).
Dec 24, 2016 | Televison & Video
How to hook up security camera
Basically, all you need is:
1- Power-up the camera.
2- Select video input 1 or 2 on your TV.
3- Run a cable from the camera to the TV
4- Connect the cable coming from the camera to video input 1 or 2 on your TV.
Please note:
The cable you run from the camera to the TV has 2 Ends.
One End connects to the camera (BNC plug) the other End connects to the TV (RCA yellow plug)
I hope this helps. If not, provide the model# for the TV and camera, and if I come across your post I will be Happy to contribute.
Best of luck
www.aaatvservice.com
Aug 09, 2014 | Mitsubishi WD Televison & Video
Where can Ifind help for installing a Ouku brand 4 channel cctv dvr?
I had exact same problem and it took forever to fix but I did fix it. If I plugged the camera into the tv it worked but when I tried going through the dvr no picture at all. The problem was the power supply cord to the cameras. It was bad, I happen to have another one and that was it. All cameras working!
Dec 30, 2012 | GW Security Home Security
Ps3 goes to black screen then to normal
It could be as simple as your video cable going bad. Check to make sure the wire is in good shape and that the contacts and connections are secure.
I would say try using it with an HDMI cable (if possible) and see if the problem persists. You can also try and hook up another device (DVD player, camera, PS2, etc) to the TV input you are using now and see if it is the TV that is giving you trouble.
Jul 09, 2012 | Sony Playstation 3 (PS3) Console
My Sony Bravia tv screen turns green on occassion when changing channels. You can still hear the sound on the channel but can't see the picture only a green screen. My tv is hooked to a digital cable box...
If you haven't done so already, check that the cable between your tv and digital cable box(probably HDMI) is secure at both ends. If it is, try a different cable and/or different port on your tv if you have more than one. If the issue is still there after you've tried these options it's most likely an issue with either the digital box or tv. I would contact manufacturer at this stage for advise and possible replacement of tv or box if they are under warranty.
Hope this helps.
Dec 30, 2017 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
How to hook up digital camera to tv
if your camera has a video and audio cable then it is possible,just connect the one part to your camera and the other part to the audio and video output of your tv and the switch your tv to AV, if it does not display interchange the cable you connected to the tv.
Feb 24, 2010 | LG 32LG30 32 in. LCD HDTV
I need the user manual for Homeland Security Camera Model 01880
i have a homeland security camera with monitor , a philps tv and a jvc vcr .. how do I hook up monitor to view and record off tv
Sep 03, 2009 | Home Security
I have no idea what this is called and Im not really sure how I use it,please help if you can.
It is a wireless video camera that should have a camera with it.You hook the RCA plugs to your TV or VCR hook a 12v dc power supply to it. Then hook your camera to a power supply and it should work.Make sure you have the reciever and the camera switches on the back the same. The four switches are used with one to four cameras. To use all four they must all be turned on. The round thing on the camera and receiver is an antenna with an arrow on the top. Turn the one on the camera towards the receiver. Hope that answers your question. The camera has a place for a battery or you can use a power supply.
Apr 04, 2008 | Computers & Internet
When I plug in AV cable for playback on TV camera screen goes black
did you fully charge the battery before use when you bought the camera? and is it charged now? most cameras can take photos but not be able to hook up to download. because photos take less energy it may be that it has just enough energy to take a picture, but not quite enough to do anything else. i don't think your stupid, its just that some people don't think of the little things as be possible. also could check to see if there is any obstructions. (dirt, little pieces of plastic, etc.) on the main routing items. (memory card, plug-both ends, inside the camera housing itself). hope i could help GOOD LUCK!
Apr 08, 2007 | Olympus Stylus 710 Digital Camera
RCA 20F420T 20" TV Logo
1,908 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
