Question about Chrysler Sentry Key Immobilizer Bypass for Remote Start
Sentry Key system won't let me start my Jeep Grand Cherokee
I have a 2000 Jeep Grand Cherokee and the Sentry Key device is malfunctioning, so that whenever I start the car, it automatically shuts down. Every so often it starts up fine. We have followed the sentry key programming procedure in the car manual, but it doesn't help. The key also, falls out of the ignition at times, but even if we hold it in, the car still shuts off. Our dealership wants to replace our ignition switch (at a hefty cost) to fix the problem, and say if that doesn't work they have to replace the entire computer system including wires, etc at a much heftier cost. I am wondering if an ''...immoblilization system bypass...'' that I see advertixed for the Sentry Key system will work on this problem. Any other solutions? Thanks.
  • 3 more comments
  • ajames412 Feb 17, 2009
    Thanks for the suggestion. We removed the Jeep keys from the keyrings we have and the problem persisted. The Jeep starts, usually in the morning, but by afternoon it leaves us stranded. It turns over like it is going to start, then just dies out. FYI, this problem started when we put a new battery in the car. Thanks.
  • ajames412 Mar 02, 2009
    Ok, so after several weeks, we found the solution at a Chrysler Jeep dealer in Phoenix. The owner's manual stated that if this problem persisted, it was electronic. We told that to the dealership and they tested it to find that sure enough a wire/component was burned out. They replaced the "skim module". They also gave us two new keys which they programmed at the dealership. The first dealership (in another Arizona City) was going to replace the entire ignition system at a goodly cost, and "start from there". Thanks for everyone's input on this.
  • kathy archer Mar 21, 2009
    I have a 1999 grand cherokee I just bought it used but in good shape. A few weeks ago the light with the key and circle came on while I was driving. It continued to stay on all the time. I went to leave one time and it stated the shut down thing. This was probably within one week 1/2. IW e removed the negative cable to the battery .That seemed to fix it. Next day nope. Not even the cable worked. I had have it towed too a friends shop. He said the diagnostic showed a probablem with the drivers door. Then he informed me the door lock on the drivers side had been tampered with buy a screwdriver. He said to change the door lock cylinder. Sometimes it will start and blink some not. I think its a wire in the door.My door panel is still a little off.I wiggled the wires inside it seened 2 make a difference. Maybe the wire was messed up when smeone tried to break the lock.Im at he end of the road.Havent even registered it yet. thank you for taking the time to read my diagnosis.lol. KATHY ARCHER.kovespain@yahoo.com.
  • Anonymous May 09, 2009
    My 2000 GC Limited does the same thing. I called the dealer and they said it could be as simple as the Key needing to be reprogrammed, a new key battery, or the whole ignition switch. I have not taken it to them to determine what it is, exactly - However, in the mean time, I have discovered that if I have my steering wheel all the way down when I start it, it always starts. I drive with it in this position anyway and when I park, I release the steering wheel to the full-up position to allow for more room exiting the vehicle. In this full-up position, it usually shuts off after 2 seconds. Though I have not looked closely at the ignition switch area, this tells me that it is likely a loose connection that is affected by the position of the steering wheel. I refuse to pay the dealer or any mechanic big money for something I can fix myself. I just did the front rotors and pads last night- classic Jeep warpage - and this is my next issue to tackle once and for all. After this, I will be fixing the "blend door" problem which renders your AC - and heat - totally useless.
  • tjdowling May 10, 2009
    I just a similar issue. However, in addition, I can't you the keyless entry to unlock the car. Of course when I use the key itself, it activated the security system. But since the Sentry Key is messed up, I can't deactivate the security system that way either. I've tried both of the keys that came with the vehicle. Anyone this this might be the same issue?
Get a new key. you can easily bypass your alarm to ignition conection, worked for me!
Posted on Mar 02, 2009
Do you have 2 keys on the same keyring? if so remove one of them
Posted on Feb 13, 2009
Its probably the ignition module computer thingy ma bob that needs replaced. thats what i was told at the dealership. took it to a local mechanic and got it diagnosed. turns out the battery cables were damaged and that was it
Posted on Jan 03, 2012
Can a 02 jeep grand Cherokee work with out a sentry immobilizer system
Annette you can not immobolize the vehicle if the sentry system is on is your Cherokee petrol or diesel
Dec 19, 2014 | 2002 Jeep Grand Cherokee
Have a 2000 grand cherokee, will be running good,
Does the car stall when sitting still, might just be that the key is worn and wiggles itself out just enough to shut down the vehicle
Aug 30, 2014 | 2000 Jeep Grand Cherokee
Sentry key light on
reset the auto shut down and it will start sounds like the anti theft is holding you out
Feb 10, 2013 | 1999 Jeep Grand Cherokee
Replaced steering column on 2000 grand cherokee with LKQ which had a key,it starts but shuts down in a few seconds
the skim module needs programed at a dealer,it tells the security moduel the key code,if thay dont match it wont run ,thay charge a pretty penny for this service
Jul 21, 2012 | 2000 Jeep Grand Cherokee
1999 jeep showing code p1686
P1686 is a SKIM (Sentry Key Immobilizer Module) no signal code. The keys have tiny chips in them that have to match the SKIM module for that vehicle, if they dont match then the engine will stop running after a few seconds. This is to keep theives from making a key and driving away with you vehicle.
First of all, do you have 2 keys? If so try the other one, if it works, then the other sentry key (the one that didn't work before) has bit the dust. If both do not work and both seem to have same symptoms, then it is quite possibly the module under the sterering wheel cover attached to back of ignition switch which reads the sentry key and if it gets signal from sentry key, then it sends a signal to pcm allowing start up to complete with no shutdown. If this unit is bad, unfortunuately just replacing it is no help, because after replacement a DEALER must then program both the unit and your keys. Make sure you give the dealer both keys, as both have to be reprogrammed to the new unit, if only one is done, the other will not work.
Apr 24, 2011 | 1999 Jeep Cherokee
My Grand cherokee is not starting
If anyone has this problem also where you start your Jeep and it dies in about 2 seconds and the key symbol lights up on your dash I can help. I had this problem yesterday after jumping the battery, I had the correct key but it wouldn't read it. I had a locksmith come out and if you take off the steering column plastic there's a small black module in the column behind the key switch. Unplug that module for 5 minutes and it will reset. My Jeep started up right after. You MUST have the correct key though, mine is gray not sure about other years.
May 15, 2009 | 2004 Jeep Grand Cherokee
2000 Jeep grand cherokee limited remote start
higher end starters will have the lock/unlock/panic buttons built onto their fob. as for the seats... I dont know why it would interfere with your settings, but who knows... better to ask the seller of the remote start system.
Mar 18, 2009 | 2000 Jeep Grand Cherokee
Chrysler Sentry Key Immobilizer Bypass for Remote Start Logo
11,624 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Joe Taylor
Joe Taylor
_-__-___-_
_-__-___-_
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
