Question about Hotpoint WMA66 Front Load Washer
How to reset the setting of the wma66 washing machine
When i turn the machine on the light of the control panel screen all come on and will not go off so i cannot select any problem
    Scholar:
  • 99 Answers
This is joyce\
Push the pause cancle button at the same time 2 times or unplug and let stay unpluged for 1 min
this should do it. or if this does not work for your machine go to hotpoint.com and download codes and this should tell you how to unlock your machine or what the problem is.
thanks
joyce
Posted on Feb 13, 2009
How do I reset my Fisher Washing machine size?
To set the size switch, turn the power on at the power point and off at the console. Press and hold
WASH TEMPERATURE UP then press POWER. EcoSmart will give 4 short beeps
and the pattern of LEDs will change.
To lock the size into memory.
 Press SPIN SPEED UP, the SPIN HOLD LED is on for 7.5 / 8.0kg (650mm wide).
 Press POWER to confirm the setting and also exit this mode.
Apr 15, 2015 | Fisher Paykel EcoSmart GWL15
Control Module problem?
It sounds like the pump or drain hose is blocked by something, and if the water does not drain away it will not spin properly.
The last resort would be the control module which is about one hundred and fifteen pounds, so check everything else first.
Jun 13, 2014 | Hotpoint WMA66 Front Load Washer
My Kenmore H2 Plus needs to be reset to factory settings. Cannot find how to in the manual.
Not sure if this will work with this model but try this:
1-Turn off and unplug the machine. Plug the washer back in and wait for the control panel to light up. This resets the washer back to the original factory settings.
2-Unlock the control panel by simultaneously pushing and holding down the Options and Select button for 10 seconds if you see a lock icon on the control display.
3-Push whichever new options you need, and wait for the control panel to flash and reset the washer's options.
Apr 22, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
My machine wont stay on wash cycle.it starts turns a few times then turns itself to the "on" mode
If the drum is turning then its most likely the tacho on the back of the motor or the wires connecting the tacho to the control panel. So the motor is turning but the panel can't control the speed so will switch off straight away.
If the drum doesnt turn but you hear the motor kick, then the drum belt is broken...
Aug 05, 2011 | Hotpoint WMA66 Front Load Washer
Hotpoint WMA66 Drum Bearings gone. Drum will not ...
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
May 20, 2010 | Hotpoint WMA66 Front Load Washer
Hotpoint WMA66 starts to fill but instead of beginning to agitate it begins to spin for a second or two and then drains!
Sounds like a tacho fault. Could be you have a broken wire on the motor circuit. Tilt the machine back and take a look underneath at the wires leading to the motor. This is just to give you an idea if it is a broken wire, you shouln't try to repair it like this, you would need to remove the front panel to allow yourself enough space to affect a repair. For a workshop manual on the WMA66 which would give additional help and advice on dismantling and rebuilding as well as fault finding click on the link.
Mar 17, 2010 | Hotpoint WMA66 Front Load Washer
Fuse blew door light flashing and it beeps 5 times
The symptoms suggest that the door switch or wiring have failed, and shorted to ground, which caused the fuse to blow. Take apart the door switch and check the wiring for shorts.
Jun 13, 2009 | Hotpoint WMA66 Front Load Washer
Control Locked
look closely at the machine console, the most right set of buttons, the lowest possible one is the control lock button, youll need to hold it in for 3-5 seconds to unlock the control panel(child lock)
May 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint ultima wma66
Sounds like the PCB is Freaking out. All you can do is Check all the connections between the Main board and Display board and if you still have the problem - then i'm afraid it is probably the Main Board gone Faulty.
Mar 14, 2008 | Washing Machines
Hotpoint WMA66 Front Load Washer Logo
256 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
