Question about HP Color LaserJet 4550 Printer
HP 4550 will not print graphics
My HP 4550 color laserjet will not print graphics, or anything else correctly. It will print a document from wordpad. If I make a drawing on paint it will print a black square over most of the page but you can see a bit of the drawing sticking out (in the correct color) It will not print a test page unless I use the control panel. All control panel pages print correctly. I had unhooked it and used an adapter to turn it into a USB printer so I could attach it to a new print server so I could print off of a VISTA computer. Didn't work. I bought a new printer and use that on the Vista computer, but now I cant get the old printer to work again. I have plugged it directly into the computer and it still will not print correctly.
  • bdehar Feb 13, 2009
    The driver is HP Color Laserjet 4550 PCL
  • John LeFebvre May 11, 2010
    Sounds like the wrong driver is being used. In Control Panel, Printer, Properties, Advanced, what driver does it say that printer is using?
  • 291 Answers
This printer will work with Vista. I use the driver that Vista provides with the standard HP internal network card and it works fine. Try putting your network card back in and undoing the USB adapter changes. Then just go in and add it back with the "Add Printer" wizard.
My compliments on the 4550, though. It's a great printer. A bit slow compared to what's out there new, but a workhorse that will last nearly forever.
Posted on Aug 31, 2009
Servis manual
Service Manual can be downloaded From
http://www.eserviceinfo.com/download.php?fileid=10036
It is in 29 Parts after you have downloaded the 29 parts to a Dedicated folder, I named my HP 4500
You need to download 7-Zip and install it
Right Click on the first part and and select 7-zip and select extract t0 "hp color LaserJet 4500 and 4550 Service Manual"
If you did everything correctly you should see a inside that folder this PDF file "hp color LaserJet 4500 and 4550 Service Manual.pdf"
I downloaded it and verified that it is authentic and 58,802Kb in size
Site asks you for Donations, Use your own judgments on whether or not you want to donate.
May 05, 2016 | HP Officejet 4500 All-in-One Multifunction...
My laser color HP cp1515n is not copy anything that's black copy? what can l do
Hi there, my name is Lisa and I'd be happy to help you with your LaserJet CP1515n. The following document will help you to troubleshoot the issue you have described:
HP Color LaserJet CP1215 CP1217 CP1514n CP1515n and CP1518ni Printers One...
I took a second look and found this one too:
HP Color LaserJet CP1514n CP1515n and CP1518ni Printers Resolving Print...
I hope this helps.
I work on behalf of HP.
Jun 19, 2015 | HP LaserJet CP1515n Printer
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Damaged toner cartridge
Hi:
You can download the entire set of documentation for your HP Lasergjet 4550 from the HP site, including the owners manual, and a service manual.
just go to : www.HP.com
type in the model number under the support link, and you can get everything you need.
Jan 29, 2010 | HP Color LaserJet 4550 Printer
Scanner problem -- new HP 4550
Go to hp.com. Support and drivers/enter your printer/check your operating system/find the correct drivers that allow scanning. Download and install them
Connecting a HP 4550 parrallel printer to a USB Laptop
in order for you to use USB on this printer. you need to get "HP175x jetdirect, USB to parallel" which is print server box use to convert USB to parallel print port fo rolder printers that don't have USB or use as multiple pinters for network.
price is around $70 USD.
Jun 05, 2009 | HP Color LaserJet 4550 Printer
Looking for a exploded diagram/parts list for a HP 4550
Here is a link to exploded diagrams for HP color Laser Jet printers:
http://www.printersupplies.com/c-HPCLJPRINTERPARTDIAGRAMS.html
Take note that the site does not have the 4550 model, but has a 4500 and 4650 which possibly has the same or similar internal parts.
Hope this helps you.
Regards,
Graemevm
Apr 25, 2009 | HP Color LaserJet 4550 Printer
Hp laser jet 1010
Dr.M.subrahmanyam
1. This printer is not specifically a postript printer. It uses HP PCL printer control language, according to HP it does not support Postcript, see the table on page 15 of this pdf file: http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00442162/c00442162.pdf page
2 Screen prints are not directly sent to the printer. They are copied to the Clipboard - you must open up another application which can access graphics - WordPad , Word, Excel. E.G from wordpage paste the screen print (using Control + V or Edit-> Paste) and the contents of the clip board will appear in the document - use the print option from wordpad to print this graph to your HP 1010 printer.
Feb 21, 2008 | HP LaserJet 1010 Printer
HP LaserJet 1020 Prints a Black Line when at the right side when using Ms Word 2007
First, you need to try update the latest microsoft office patch file from microsoft or you can open the MS Word, go to "HELP" menu select the update MS Word or related. Try the latest patch file first. You also can try windows update and select custom update, see their list have this problem solution or not. Second, you need to go to HP website download latest driver for LJ1020 and suitable use on Vista. Lastly, if still not solve the problem, you need this problem/issue to microsoft, ask their solutions. Kent
Aug 22, 2007 | HP LaserJet 1020 Printer
HP Color LaserJet 4550 Printer Logo
132 people viewed this question
Seeker5211
Seeker5211
