Question about RCA HDLP50W151 50" Rear Projection HDTV
50Inch RCA dlp Scenium
Last night I was flipping through channels and all of a sudden the screen went to this greenish tan color. Theres still sound coming through and my Comcast tv guide comes up perfectly fine itts just the tv shows im switching too are all this color...what could this be? Please help im going crazy My color quality changes from normal to a yellow/gold picture.
Did you ever find a solution to this? is it really the color wheel? WIll getting a new lamp resolve this?
Posted on Apr 05, 2010
    Novelist:
  • 184 Answers
Its the color wheel assy. Its changing speed due to worn bearings. You may also hear a hum coming from the rear of the TV. Seek an RCA authorized service center to resolve this.
michtech
Posted on Feb 14, 2009
Replaced bulb assembly in RCA DLP but screen is very dim
Sounds like your light engine is damaged. Could be cracked. You can replace it for under 100.00 which includes a new engine and color wheel as well.
Aug 03, 2017 | RCA Scenium HD50LPW52 Replacement Lamp
I have a RCA Scenium HDTV DLP that has a whinning sound and no picture. Could this be the bulb?
No, this is the color wheel. I have a tip at http://www.fixya.com/support/r4160054-replace_color_wheel_in_dlp_projection_tv which explains in detail how to change the color wheel and where to get the parts.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 06, 2010 | RCA Scenium M50WH187 50" HDTV
No picture and loud screeching on RCA Scenium 50" DLP
It sounds like it is the Color Wheel. I do not think you can get the Color Wheel separate from the Optical Engine like you can with Samsung. RCA is very tight with there parts like that. Because you have to get the whole
Engine Assy, cost would be too much in my opinion to invest into it. The part cost approx 800.00 the last time I checked on one.
Good Luck,
I Hope this helped,
Skyassoc
Jun 20, 2009 | RCA Scenium HD65W20 65" Rear Projection...
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Ramdon color changes
color in a dlp is controled by the color wheel.. this may be an indication of a pending color wheel failure. is the produceing a lound whining noise. this could be other problems but this is my first instinct on the symptoms given
Jun 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
I have an RCA Scenium HDTV DLP, Model HDLP50W151. Turned it on and went through it cycle, whining sound but the screen was gray. turned it off and then on again...no picture and there was no whining sound....
Sounds like the Color wheel on the Light engine has failed. Its a major repair. Contact Thomson at 1-866-465-7157 to find a local authorized repair center.
Jun 04, 2008 | RCA Televison & Video
RCA Scenium 52 DLP
you should take it to a tv repair shop to look it over, they charge $50 and they will tell you want the problem is.
Dec 17, 2007 | RCA Scenium D40W20 40" Rear Projection...
Rca scenium 44 in. HDTV with DLP
You need a new bulb or fuse, as yours went out. If under warranty call the warranter. The tv should have lights on it that blink if it is a bulb, my samsung does this. If there are no leds on the tv, ie the standby led is off, then its your fuse.
--XIII
Oct 26, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA HDLP50W151 50" Rear Projection HDTV Logo
206 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
