Question about Apple iPod touch
Wet itouch My itouch was dropped in my drink, is it possible to be fixed? Right now, it's not charging at all. It's showing red battery on screen. Previously, it charged and went to the home page but went off again. Thank you.
  • kevenx Feb 18, 2009
    my itouch got washed in the washing machine, i let it dry out for one week and now everything works exept the actual toucing part but the home and volume and power buttons work. Are there any parts i can buy to fix it?
    Scholar:
  • 36 Answers
DON"T TURN IT ON AGAIN UNTIL YOU KNOW IT IS COMPLETELY DRIED OUT!!!!
Sometime electroncis can be salvaged if they are not turned on again until after they are dry.
The electrolytes...(sugars, salts) can cause the electric current flowing through the device to arc accross connections causing a short. It may be too late to save your iTouch, but for the future if you can dry out the device before trying to turn it on again with a blow dryer or napkins or whatever you have handy it may save it.
Try drying it out and then turning it back on...it may or may not work as the damage may have been done already.
I hope this helps you in the future. Good Luck!
Posted on Feb 12, 2009
My phone got damp in snow today, screen is black. I plugged it in to charge and on screen it shows C3590, goes off then shows a picture of a battery. It did not get very damp and battery was fully charged...
It sounds like it is damp inside. It needs to dry for several days with the power and charger off.
One popular method is:
Remove the battery from the phone, if possible, or at least turn the phone off. ...
  1. Disassemble the device, if possible. ...
  2. Blow compressed air on the device to remove as much water as possible. ...
  3. Fill a container three-quarters full with dry, uncooked rice.
Here are some links that may help:
How to Save Wet Cell Phone
Here the Right Way to Rescue Soaking Wet Smartphone WIRED
How We Drowned Nine Phones and Found The Truth About Rice
Mar 02, 2015 | Cell Phones
Just got this phone yesterday! dropped in water... pulled out and shock water out and dryied it with a hair dryer..no moisture appears on screen. Dried battery...waited an hour and put on charger..the...
There may be some water logs present in the phone which obstructs the functioning of the phone.
Never switch on the wet mobile,When the power goes to the circuit board it may short circuit the full mobile motherboard.DONOT put your mobile in charge when it is wet it may be very dangerous.
You need to remove the water logs present in the mobile. So,please go to mobile service centre in your place and they will fix it.You cannot fix it yourself.
Thanx
Aug 07, 2010 | Cell Phones
Samsung Jet Cell Phone is "dead"
under warranty will not count on liquid damage if you take the battery out you will see a red dot that tells you water damage i have dried out some mobiles take out battery and sim leave on warm radiator couple of days then try again if still the same then it spares cost way too much to put right needs mother board ,and connectors hope this helps
Apr 30, 2010 | Samsung Jet S8000 Cell Phone
Camera wont turn on.
try replacing the battery. Check best buy, radioshack or other camera dealers for a battery. Possible deadcell battery. These lith-ion batteries die with no warning. If there is no change, the camera is defective!! hopefully htis helps
Jul 20, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Cutting out in wet weather and No power steering in wet weather?
I sounds by your explanation, that the belt which drives the alternator is slipping when it gets wet.
When this happens the alternator stops charging the battery, and when battery voltage drops the engine cuts out and won't start due to not having enough current to supply electrons as well as starter motor.
Have the belt tension checked, as well as charging output of alternator, should fix it.
Oct 04, 2008 | 1995 Volkswagen GTI
Hp 530 laptop = dead no lights/nothing...power supply reads 19.2 volts with meter.son spilled drink on keyboard..suggestions?
Remove battery and power. Take apart as much as possible. wash any wet/sticky parts in de-ionised water (as used for topping up batteries), allow to thoroughly dry before re-assembling and powering up. Leave at least 24 hrs to dry.
Try not to get circuit board too wet, but if it does not work then you have nothing to lose!
Liquid on keyboard can be very difficult to fix as damp gets under the membrane - even if computer works the keyboard may not but you could always use USB keyboard.
If you have any Silica Gel packets, put notebook and all parts in a plastic bag with them to absorb all moisture (but make sure no powder gets into the components).
Aug 08, 2008 | Computers & Internet
Phone wont charge
Did you drop your phone in water? or do you live in a humid area?
Your phone was exposed to moisture. That red dot is a moisture sensitive piece of tape that changes colors when it gets wet.
If your phone still works, but the battery won't charge when connected to a home charger, you might try charging it in your car. Its a different type of current and may work with a somewhat damaged battery.
If that fails to fix the problem you may need to get a new battery.
Hope this helps
Jan 15, 2008 | Motorola Mobility RAZR V3
Wet phon
If the screen is working, your phone seems fine, however, you must take this phone to someone who knows how to open the phone and clean the IC. The drink must have gone inside the phone due to which the keypad is not working. For the iPod, it seems the battery isnt charging anymore. Thats why it won't work when not connected to the power. So, get the battery checked.
Feb 28, 2007 | Motorola Mobility RAZR V3
Apple iPod touch Logo
434 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
