Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
I have the Blanco-Mix Harvest faucet.. I am confused as to whether I need two o rings between the cap and nut; a small one that fits up inside the cap and another larger one that fits on the bottom of the cap[next to the nut. Does anyone out there know. I think I need just one smaller o ring. Help
  • Anonymous Apr 04, 2009
    After shutting off my kitchen Blanco single handle faucet w/pull-out spray it continues to drip for a minute or more. Is there a solution to this problem?
    President:
  • 1,902 Answers
You only need one small o-ring. If you put two of them it will not work properly and will mostlikely leak like crazy. If this helped please rate.
Posted on Feb 12, 2009
2 Suggested Answers
gary1121
  • 332 Answers
SOURCE: Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
Posted on May 30, 2009
Faucet insert replacement
Contact Blanco to find out why the insert they sent doesn't fit.
Oct 28, 2017 | Blanco 157-090-CR Rados Kitchen Faucet...
Leaking blanco single handle faucet with sprayer
minarl deposit bildup in the handol best to just replace the sprayer any hardwer store hose is still good only sprayer head needs replaced comen threds
Mar 11, 2012 | Blanco Plumbing
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
Moen has a diverter built in that will need to be replaced.
use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
use a non silicone faucet lubricant when putting back together
Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Sprayer leaks on my Rohl single lever faucet
The spray head will need replacing, it unscrews and the new one will fit right on
Jun 27, 2010 | Rohl A3608/11LMAPC Single Lever Country...
Blanco harvest kitchen faucet with pullout spray low flow rate
Check fine filter at tip, probably blocked, got caught with same thing myself recently!!!
Jan 26, 2010 | Blanco Harvest Single Handle Faucet with...
May 30, 2009 | Blanco Classic Single Handle Faucet with...
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
751 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
