Question about Canon ImageClass D880 Copier
How can i change the drum of canon laser base mf8081c...........................................
  • 62 Answers
The top should be able to be slid to the left and the right side, top of machine can be opened up. The drum and Toner are a complete set(all in one). The cartridge can be pu;;ed up and out and replaced with a new one.
Posted on Feb 14, 2009
Canon 2016, vertical black lines.Print and copy, not always
Dear. first change the drum cleaning blade and clean the waste toner from the drum unit safely and then try to copy if the black lines still appears then change the drum then it must solve the issue , If still the problem comes then check the laser unit if there is anything which produce the black lines on the pages.
Aug 14, 2013 | Canon imageRUNNER 2016 All-In-One Laser...
E000020 1360 canon error code after changing drum unit.
This has been fixed by replacing the memory chip on the drum. This may meaning replacing the drum. First though, try cleaning the laser and make sure all your drivers are upto date:
http://www.canon.co.uk/support/products/imagerunner/imagerunner-advance-c2025i.aspx?type=drivers&language=&os=OS%20X%2010.11%20(El%20Capitan)
This may be a call to canon support unless you are very confident with these procedures.
Part number for the drum is Canon C-EXV34
May 23, 2013 | Office Equipment & Supplies
Error code 100. On canon image runner 2000
You need to change the drum unit and turn the copier off and on. Drum unit C-EXV5.
If the drum unit doesn't helps, replace laser unit.
Sep 08, 2011 | Canon imageRUNNER 2000 Copier
Dear`hope you help me `my copier is conon IR1022 `when i on the power give me messege with sound :System Error E100 `PLZ dear excellency help me best regard and garatiful hakimi
E100 means laser section trouble, on some copier it will show E100 when the drum is worn out and you need to change the drum unit. But also the laser unit can be faulty.
First, try to replace the drum unit, then try to reconnect the laser unit, try to replace the laser unit or DC controller.
Hope that helps!
Mar 24, 2011 | Canon PC1061 Copier
How to repair opc drum on canon ir400 without change it
if there is minor scratch on the drum surface, cover it with solvent based glass colour let it dry and re install the drum. if there is scratch on the sides of the drum full circle then cover it with selophane adhesive tape, make sure to wind the tape in counterclockwise and one turn only.
Oct 06, 2010 | Canon Office Equipment & Supplies
How to change the inkjets I can't see how to take the old ones out
?? Inkjets on a Laser Printer? Not going to happen because they don't exist. Laser printers work on a heat transfer type drum. Every time you change a color cartridge you are changing the Drums so that shouldn't be an issue. There are some parts in the Printer itself that could be causing problems for you if you are having smudging or mixing of colors but that will be another problem.
Jul 05, 2010 | Canon imageCLASS MF7480 Laser Printer
Reset 8180 canon
Here's your support page.
There are various resets based on different messages.
Hope this helps!
Mar 17, 2010 | Laser Canon imageCLASS 8180C Multifunction...
Changed Toner but its still saying "No Toner"
You may need to replace the drum this time. Usually after a few toner changes the drum needs to be changed to.
Apr 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon 8180C laser Multi Function printer Error Code 078
did you reset the drum unit on maintanance counter of the machine?
Apr 18, 2008 | Canon MF8180C Color Copier
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
Canon ImageClass D880 Copier Logo
247 people viewed this question
old marine
old marine
