Question about Samsung SCX 4521F All-In-One Laser Printer
SCX 4521F multi/f keeps reporting "Document Jam"
I have removed everything possible and opened every door, blown and vac'd all through the openings, changed paper etc but still get the Document Jam when I switch on. Any suggestions?
  • 1 more comment
  • mbradshaw Feb 18, 2009
    I have much of the same problem. 3 pages tried to go through at the same time. I simply grabbed them and slowly pulled them back out. Ever since, it has read "document jam" and will not work.
  • Anonymous Apr 22, 2009
    help me, please..
    I have a big problem!
    What's a solution paper of obstrution ?
    very thanks!
  • Anonymous Apr 27, 2009
    I have same problem, have tried turning on and off.
    Opened every door
    any other suggestions
    Novelist:
  • 166 Answers
Hello there,
If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Posted on Feb 12, 2009
Samsung SCX-4521f Document Jam with no paper jammed
u can clean sensor in your printer, i mean all sensors.
Jul 05, 2014 | Samsung SCX-4521F Laser Printer
Samsung SCX-4521F All-In-One Laser Printer states there is a document jam and toner empty but no documents are jammed and the toner has ink....cannot find the paper sensor to check if its causing the...
hello try to do this
press #1934 and right arrow key disply appear ready tech press menu &left arrow key display new cartridge press enter button twice. then toner empty message is over do previous simulation for go normal condition.
paper senser is located at back side of the machine remove backside cover and see heater unit near the hot roller paper senser is located
Aug 19, 2010 | Samsung SCX 4521F All-In-One Laser Printer
How to remove paper jam in that printer
1. open front door
2. remove toner cartridge
3. remove jamed paper from inside
Good luck
Jun 24, 2010 | Samsung SCX 4521F All-In-One Laser Printer
My paper is getting stuck on roller for laser printer scx-4521F, when remove paper and open door to reset printer, paper goes through and then jams again on new job.
open the front door and take the cartrige out.
if it jams at the black roller. you must clean the pickup roller.
you will see it at the back of the unit in the center.
Nov 11, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper Jam message on every print job.
I have the same printer without the doc feeder. Check the paper trail thru the printer for the paper sensor lever hanging up. It gets pushed up by the paper and can stick, making the printer think it still has paper in it. Pulling the cart unsticks it till you print again.
Jul 03, 2009 | Samsung SCX 4521F All-In-One Laser Printer
The Samsung scx 4521 printer JAM
ithink it is a hard were pr oblem we should clean our printer time by time, there is many dust inside, they can make disattacment between sencer and parts ,so we get this information. open printer and also if u open drom and other part open , then blow air by air blower machin e.we solve more than 80% thise type case in our lab .
Jun 19, 2009 | Samsung SCX 4521F All-In-One Laser Printer
"paper jam 2" after each page with samsung scx-4521F printer
sir, our printer is 4521f model its showing paper jam 2 How to solve this peoblem
Jun 02, 2009 | Samsung SCX 4521F All-In-One Laser Printer
SAmsung printer SCX-4521F
Run a print job,then when the paper jams, open the cover and remove the toner cartridge.
If the paper is past the area under the toner cartridge, then it is the fuser that is causing the problem. If it is not getting that far, I would clean the rollers that you see with a damp cloth(almost dry cloth).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 13, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
389 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
