Question about Philips Vesta Pro Webcam
Philips webcam SPC535NC
The webcam and the mic works for a while and then skype tells me there is a problem and doesn't specify. On MSN it simply doesn't work! I keep going to webcam and audio set up and going through all the various tests, and still, it doesn't work. Have no idea how to fix this. is it just bust?!
Surprise, surprise the cam isn't in your list, so I stuck the make and model into the subject.
    President:
  • 8,637 Answers
Normal 0 See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://ca.messenger.yahoo.com/download/ ) set it up as follows:
  1. Click on Messenger at the top left and then go down to Preferences and then the Preference Window will come up.
  2. Next click on Calling and Devices. In the Calling & Devices on the right and set the Microphone and Speakers to the computer Audio Card or sound device installed in the computer.
  3. Just below that, go to the Test Audio section and (in blue writing) click on Open the call setup assistant” and follow the instructions on the left window.
  4. Then after completing the Audio Setup, go to down and click on Webcam it should BRODCSAST and you will see your picture.
  5. To Chat, click on MESSENGER and then
  6. After make necessary settings, click on APPLY, then OK.
  7. Then click on MESSENGER and go to my WEBCAM ready to use.
  1. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jul 02, 2009
Installed Philips SPC630NC web cam will not display picture on Msn Messnger live just a green screen, all drivers have been checked and software but just a green pictur, it wont work on any other cam site...
Set your mic as default
Vista
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Set your webcam mic (if it has one as default)
Vista -
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Jun 15, 2010 | Philips SPC 630NC Webcam Fun - Web camera...
Well I have a msi laptop and the built in web isnt working and I checked if it was on and it says it is. But when I go to skpe or msn nothing happens and the little light beside it doesnt go on? I need...
You will have to set up or configure your webcam software to work with any chat program before you can broadcast.with it.
If it has a built in mic with the webcam -Make it your default mic.
TEST SPEAKERS
Restart computer
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Vista -
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Jun 13, 2010 | Computers & Internet
Webcam
You both have to be in the same program to use your webcams.
You cannot hear her msn - this is probably a failing on her set up (mic)
She may have a laptop with a built in mic and she needs to nominate her webcam mic as default so that msn/skype software can locate it.
I suggest you both follow these instructions
Audio
TEST SPEAKERS
Restart computer
Configure to MSN
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Configure to Skype
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
May 07, 2010 | Logitech Webcam
I have a microsoft VX-6000. until recently it worked fine (video and microphone) on skype & msn, however now the microphone has stopped working. when I go into skype/tools/options/audio settingsand...
Make sure your webcam mic is set as default
TEST SPEAKERS
Restart computer
Configure to Skype
Apr 25, 2010 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
The microphone doesn' t work
Vista audio setup
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard SET DEFAULT & TEST MIC Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click Apply Click "Levels" tab and set sliders to approx 80% ( adjust to suit later)
Click OK
Once you have set your webcam mic to default on your computer and it is working you have to set it as the default device to any chat program you want to use it in
MSN
Open menu > Tools > Audio and video setup - set mic > Next - set webcam > Finish
Yahoo Messenger
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK Click ( > ) Messenger > Preferences > Calling and Audio Set mic and speakers to show Default equipment Run call up assistant to test audio equipment > Apply > OK
Skype
  1. Start Skype.
  2. On the Tools menu, click Options.
  3. In the navigation pane of the Skype Options window, click Audio Settings.
  4. Select your webcam device as the default microphone.
  5. In the navigation pane of the Skype Options window, click Video Settings.
  6. Select your webcam device as the default Webcam.
  7. Click Save.
  8. Test LifeCam by making a Skype test call.
Sep 09, 2009 | Creative Labs WebCam Live!
I have the same problem
MIC SET -UP VISTA
TEST SPEAKERS
SET MIC DEFAULT & TEST
Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Re-start Computer.
CONFIGURE TO MSN
Re-boot the webcam by unplugging and plugging it back in again - Its always good practice to do this before you open MSN. If you have been using your webcam in another program, it can remain hooked up to the old program and you will get an error message " Unable to find webcam or being used elsewhere"
Webcam Connected
Open MSN
Click ( > ) Open Menu >Tools > Audio & Video set-up > Set mic as default and run through audio set-up > Next > set webcam as default and adjust Webcam Settings > Finish
Aug 13, 2009 | HP VGA Webcam
Spc535nc only 160 x 120 resolution
Normal 0 See section C. Windows Live Messenger in the info below to setup the Audio & Video.
A. Skype Setup:
B. Yahoo Setup:
Apr 29, 2009 | Philips ToUcam Fun Webcam
Philips SPC110NC/27 webcam doesn't work with any chat service.. skype yahoo..
Guys I got one (SPC110NC ) today and it behaved as follows
1. Plug and play .. so windows XP (SP2) recognised it instantly.
2. images were recorded from the general webcam application (defaalu XP one ).
3. Skype however gave the error that was somewhat like " Skype cannot access ur webcam etc ..."
Apparently for Skype 3 and higher u need a special driver .. which u can get at
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=PC_CAMERAS_CA&sct=WEBCAMS_SU&session=20080804034458_66.249.71.24&grp=PC_PRODUCTS_GR&ctn=SPC110NC/27&mid=Link_Software&hlt=Link_Software
The user manual doesnot specify the exact url of the drivers , though it specifies the need of installing them.
Get the driver , install it and skype hopefully will work fine. it worked for me after this 30 min exercise ...
Aug 07, 2008 | Computers & Internet
Philips webcam SPC1300NC
The pdf instruction manual that came with the webcam shows the audio setup page as having gain contols for the microphone. However, the software that came with the camera did not have the gain controls on the setup page. Where do I get software that allows me to turn off the microphones. The built in microphones interfere with my headset/boom mike I prefer to use.
Feb 23, 2008 | Philips Vesta Pro Webcam
Philips Vesta Pro Webcam Logo
206 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
