Question about Kyocera Mita KM-5035 Printer
Kyocera 4530 is reading offline
My computer says that my kyocera mita 4530 is offline..so how do i get it back online
  • Anonymous Mar 26, 2014
    kyocera 3035 says offline, how do i get it back online
  • 154 Answers
I would check the usb connection cable - maybe try a different one. 'off line' normally means that the computer can't communicate with the printer. Silly thing - check that the printer has power. I'm not trying to insult your intelligence, but sometimes it's the simple things that get missed.
Posted on Feb 12, 2009
  • diddydaveh
    diddydaveh Feb 12, 2009
    May sound silly, but check the power to the printer as well, sometimes it's the simplest things that even the most intelligent people miss
SAYS offline, HOW DO I GET IT BK ONLINE?
This is a network communications issue, most likely. If re-booting the copier doesn't change it, try rebooting the switch or hub it is connected to. I have seen Kyocera's take several minutes to report they are online following things as simple as being out of paper or a jam. Repeatedly trying things may cause it to stay in offline mode longer. If you are certain all panels are closed, paper and toners are in place, etc. and there are no codes or error messages, the machine should eventually be OK. If nothing works, it may be your cat5 cable or the socket in the machine. If the machine was moved with the cable still in, and it got a hard pull, there could be damage on the main board connections to the cat5 socket. that is sad and calls for board replacement.
Dec 11, 2014 | Copystar Kyocera Mita FS-C2126MFP Copier...
Km c3232
It can occur if your paper guides in your paper trays are not set 100% correctly. readjust the guides and try again.
Jul 29, 2014 | Kyocera Mita Office Equipment & Supplies
Maintenance code 4000
Defective laser unit,Replace the laser unit.
Oct 09, 2013 | Kyocera Mita Km 4530 Copier / Printer
Kyocera mita km 4530 misfeed
Please can you supply more information as to where the machine is telling you the misfeed is or the jam code that the machine is showing.
Mar 07, 2013 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera mita 3035 is offline cannt figure out how to get it back online
If you are taking about the printer portion. Just hit the printer button on the left hand side. When the printer options pop up on the touch screen chose the option on the bottom right hand side (the GO key) of the touch screen that should bring it back online.
Hope this helps.
Aug 06, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
Error Message C5100 Kyocera KM-4530
your main charger is shot... order a new one...
Dec 18, 2009 | Office Equipment & Supplies
Kyocera Mita FS1800 E3:e3:0060332
i looked up the manual and saw that the E3 indicated a mechanical error...the laser was bad; the other number indicates the number of copies. the machine must be repaired by an authorized dealer or replaced.
Mar 10, 2008 | Computers & Internet
Kyocera mita km2030
The Memory TX is for fax transmission only, not for your print queue. Push the printer button and highlight the go button and select it. This will take your printer online (or if already online it will take it offline). If the copier was offline, it should start printing when you select go. All of this assuming that the IP address is correct and the print driver is installed on your PC.
Please don't forget to rate your answers.
Jan 15, 2008 | Office Equipment & Supplies
Kyocera Mita KM-5035 Printer Logo
1,583 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
