Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Washer fills during spin cycle
I have a Whirlpool stacked washer/dryer that is about 3 years old. It's been a couple of weeks now that water starts filling the machine as it approaches the spin cycle and continues to do so during the spin cycle. As a consequence, my clothes are very wet at the end and it takes 3-4 dry cycles to get them dry. The other issue is that the washer won't stop after the spin cycle, but it continues with a full permanent press one. I am not sure what the exct model of my Whirlpool thin twin is. How can I find out? It was pre-installed in my condo and no papers were left behind. Thanks a lot!
  • 1,902 Answers
Replace the timer, you can find the product name model and serial number on two place. Either the back panel or on the lid underneath. Please rate if this helped thank you
Posted on Feb 12, 2009
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool wshser-dryer: water won't drain, cycles won't start
You need to give more info in order for a diagnosis. Is this a compact stack unit or an all -in -one unit or an interconnected washer/dryer pair ? Is it front load or top load washer ? What do you mean by "dry cycle"? Is that dryer cycle or is it washer cycle without water ?
Usually when water cannot be drained it is a bad coupling connector on the motor drive, or a bad or clogged pump (small socks have been known to get sucked in an lodged in the pumps); in either case you need a good mechanic or a service person to handle the repair because it requires opening up the shell of the unit and getting to the motor/pump assembly.As always, disconnect the power cord before diving into the unit. Good Luck, Macgivor.
Sep 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle does not take all the water out
Check the coupling between the motor and gear housings. It should be a rubber piece sandwiched by plastic piece. It could be broke. Just happened to mine. That prevents the maichine from spinning the cloths dry.
Mar 01, 2009 | Whirlpool LTE6234D Top Load Stacked...
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
I have a Whirlpool stacked washer and dryer combination. The water is overflowing on the washer. It happens during the rinse cycle when the water is filling up. It appears that the cycle gets "stuck" in...
check the pressure hose. a kinked clogged or disconnected hose continues to fill. the pressure switch senses the air pressure in the hose.awaiting your further comments. thank you.
Dec 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Washer will fill up w/water and wont spin. It still goes through all the cycles.
The fault could be caused by several things, 1. it has a blocked air trap, 2.the lid switch is faulty. 3. The motor to gear box coupling has sheared off or the motor is faulty, there is nothing else that can cause this fault. Regards Engineer
Jul 29, 2007 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
254 people viewed this question
Dan Webster
Dan Webster
Sal De
