Question about Epson Office Equipment & Supplies
I have a completely clogged print head on epsoncx3200, can i fix
I had this stored for about a year. Just hooked it up and nothing will print.
  • 62 Answers
Replacement of the print head I think would be the only way to fix problem. Not to expensive and depending on model may be done your self.
Posted on Feb 12, 2009
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 08, 2011 | Epson Stylus 880 InkJet Color Printer
After a few years of not using my HP printer, I took it out of storage, hooked it up, put in new ink cartridge but nothing is printing. When I click print, it goes through the motions and prints out blank...
if the unit was stored with an old cartrige then over time it would have leaked ink there fore clogging up the injection points they will need to be gently using a ear but with hot water flushed until the points are all free from glug
best of luck
Aug 02, 2010 | HP OfficeJet D135 All-In-One InkJet...
My epson 1400 printer doesn't print
try printing a nozzle check to see if the nozzles are clogged by dried inks that why nothings printing. turn off the printer than press and hold power and paper button together for 3 sec. then release, it will print, if blank, all nozzles are clogged. do a head cleaning. hold the ink button for 3 seconds. wait until the power light stops flashing then print nozzle check again until all lines are complete,
Feb 10, 2010 | Epson Stylus 1400 InkJet Photo Printer
I changed the ink but nothing is printing on paper
The print head is contained in the machine and is likely clogged. If the machine is worth it to you, a willing technician at a refilling store should be able to clear the clogs. Otherwise there is not much hope.
Jan 14, 2010 | Brother MFC 210C All-In-One InkJet Printer
Have a dell 720 printer. sounds like it is printing but there is nothing printed when it is done. ink cartridges should be fine. any suggestions
You have need to take it to have the heads cleaned by your local electronics store. The print heads may be clogged. I had a printer do this to me before and that was the problem
Nov 22, 2009 | Dell Inkjet 720 Printer
Put in new ink cartrages but printer still won't print.
Same problem- & I fixed it!
My printer had all new cartridges and acted like it was printing, but only blank pages came out. Since I had followed all recommended trouble shooting steps, the Epson help center told me I had to take it to a repair center, and most likely replace it, saying that it was probably the actual printing head that was clogged and since it was a non-removable part, couldn't be replaced. Instead, I did this- try it!
-Remove all ink cartridges.
-Dip a cotton ball or q-tip in rubbing alcohol, and drop a couple drops on each ink head (the points sticking up that the ink cartridges stick onto.)
-Dab it dry with another q-tip, then repeat.
-Reinstall cartridges, and voila, it might work!
Mine worked PERFECTLY after this 5 minute procedure, no skips, no blots, nothing. And no repair center, and no new printer! Good luck!
Sep 02, 2009 | Epson Stylus CX4800 All-In-One InkJet...
I just bought new ink and nothing prints clearly
If it hasn't printed anything for a couple of years then the print heads will be severely clogged with dried ink. Epson recommends printing a page or two every month to keep the heads clear. You need to try cleaning the print heads, its unlikely that one or two head cleans will clear a badly clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink, have some new ones ready.
If you need to know how to do head cleans & nozzle checks, the user guide can be downloaded from Epson here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=wsMoc1iChVFHuU002FlmukU002FlwLFmittYG0bE9gMlZoUifYkU003D
Hope this helps.
Please take a moment to rate this solution, thanks.
Apr 01, 2009 | Epson Stylus C86 InkJet Printer
Not printing even the test page,full ink ??
I have the same problem, I re-loaded the software, checked all the settings, went through set up procedures and nothing??????? I goes through all the motions, spits out the paper..........blank
Apr 10, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Nothing prints on the paper for incoming faxes or copying a document.
i suspect you are correct in cleaning the unit.inkjets if not used often enough the ink will clog the print head. usually the easiest solution is to keep cleaning unit it works again. other wise to clean the print head manually requires the unit to be completely dissambled. it takes a long time to fix it this way. or if replacement costs are acceptable you can replace it. i would just give it a dozen or so more cleanings.
Aug 23, 2006 | Samsung SF-335T Plain Paper Inkjet Fax
113 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
