Question about Emerson EWL20D6 Television
Off and on signal
I live 45 miles from Toledo and last year I purchased a new Digital Antenna from amazon . com. It's a Directional DB2 by antennas direct. 5 Stars. I installed per co. directions and had it pointed per directions from the internet at 273 degrees from my house toward Toledo, as all signals come from the same direction. I receive all analog signals fantasticaly and all the Digital signals are super, but the signal from the NBC station won't come in digitaly. It comes in sometimes for like a day or two, then the converter box tells me there's no signal. When it does come in, it's a great picture for a while, then it starts to line out and completly quits. All the other stations, CBS,PBS,FOX are great and I havn't had any problems with them except during storms.
The converter box is hooked up directily to the TV
At a lost on what to do.
    President:
  • 2,992 Answers
Welcome to the world of digital broadcasting. Chances are the antenna isn't positioned quite right for the station that's giving you trouble. It's not a TV issue or problem with the converter since other channels are fine, so it comes down to signal strength. Most of the time it's okay, but sometimes when band conditions change it gets weak enough that the converter box can't tune it. You might try shifting the antenna slightly while noting signal strength on the different channels. You'll likely find a few degrees change may give you a reliable signal on the problem channel without noticeable reduction in the others.
Posted on Feb 13, 2009
No signal using digital antenna
In some areas, it can depend on the antenna used. In areas close to the stations, you should pick up fine with just about any antenna. If you're out in the country or even thirty to forty-five minutes away from the station, you will probably need an outdoor antenna. Even with this in mind, in some areas, the antenna may need to be higher or lower than your neighbors antenna. As an example, I lived in an area where, with analog television, my outdoor antenna was on a twenty foot pole. When I switched to digital, I had to lower my antenna about five feet. A person, one city block behind me, had mimiced what I had done before and after the switch. Because of the job I had at the time, he showed up at my work and inquiried about the reason he wasn't getting anything. After telling him that I had to play with the height of mine, and that he might need to take his higher, he went to try it. Two days later, he came back saying that he was getting great reception, but he had to go the full extent of his thirty foot pole. That's just within a city block, but I've even talked with people in the country where some have been lucky enough to be able to use an indoor antenna and their neighbors had an outdoor one about twenty to thirty foot high. Some have even needed to go to a good fifty feet.
Apr 19, 2016 | Protron PLTV3250 32 in. LCD Television
After installing an outside antenna, our unit will not get streaming media.
Roku 101: everything you need to know about your Roku ...
https://blog.roku.com/.../roku-101-everything-you-need-to-kn...
Roku, Inc.Dec 22, 2011 - You will find in-depth posts on new channels, features and updates, and ... to stream your personal media from a laptop, desktop or media server. .... Alsomake sure your phone is connected to your home WiFi signal and not an outside one. .... The Sony unit seemed possible, but after watching the video I ...
Mohu Sky 60 Amplified Attic/Outdoor HDTV Antenna with ...
www.amazon.com/...Outdoor-Antenna/.../B00AVWK...
Amazon.com, Inc.Next step was to now get working on the install of the antenna, outside. ... Sat. that was outside, coax cable already run, and this Dish was not in use. ... I have MANY more pictures, it appears that Amazon will only allow up to 5? ... Three months after my initial purchase last year, the attic mounted MOHU Sky went dead. Well ...
Mohu Leaf 50 Amplified Indoor HDTV Antenna - Made in ...
Dec 21, 2015 | Televison & Video
What can I hook up to this tv to get basic channels. Not cable?
Depending on your location and distance from the available broadcast outlets, you may be able to receive basic commercial broadcast channels using a simple inside or outside ad-on antenna, available from most electronic retail stores or on line vendors such as Amazon, Ebay, Best Buy, etc.
Jul 16, 2015 | Televison & Video
What antenna works on Toshiba 20VL43U? I purchased Mediasonic Homeworx HW110AN Super Thin Indoor HDTV Antenna - 25 Miles Range.
I recently went through a whole song & dance about HDTV antennas for my RV. I bought two different directional high-gain antennas, only to find that they wouldn't even receive signals at my home! When I'd reorient the antenna and initiate another channel search, I would sometimes get ONE or TWO channels... then I'd lose them when I'd try to reorient the antenna.
What I figured out is that DIRECTIONAL HDTV ANTENNAS ARE, ESSENTIALLY, WORTHLESS. There is really no way of knowing precisely which direction the broadcast towers are and, even if you knew, they will not all usually be clustered in one small area... they may be scattered here & there around your area.
What I eventually did is bought an OMNIDIRECTIONAL HIGH GAIN ANTENNA, which was no more expensive than the DIRECTIONAL antennas I tried. Did a channel search, and got almost all of the channels in my area!
Any omnidirectional HDTV antenna will work with your television, but I'd recommend buying the one with the highest GAIN (expressed in "dB" or "dBi" with the highest number being best). Try to find a POWERED antenna with an internal SIGNAL AMPLIFIER.
Also, if you live far away from broadcast towers as I do, you may wish to consider adding an additional SIGNAL AMPLIFIER as well.
May 21, 2015 | Toshiba Televison & Video
I've just hooked up my converter box. I can get most channels with decent reception. However, I can't get my NBC affiliate. I've been told that I need a new indoor directional antenna. What kind shoul
Totally depends on how far you live from the station you want. I sell antennas, converter boxes, the whole shebang at my retail store, and you're not alone in your confusion :-) My best advice to you is this:
www.antennaweb.org
If you live closer than 15 miles, rabbit ears
If you live closer than 20 miles, omnidirectional
If you live closer than 50 miles, midrange outdoor (oldschool arial w/ rotator)
Further than 80 miles, you'll need a long range with rotator, perhaps even an amplifier to go with it. Print off what your results were on antenna web and bring it to a RadioShack or a local antenna store and they should be able to point you to the right antenna for your particular location.
May 22, 2009 | Toshiba 13A25 13" TV
Poor antenna reception
That's a problem with the digital broadcasting. Signal strength is critical, and the frequencies used are more directional. Some people are finding they get no reception at all. Your antenna may not need to be higher, but aimed in a different direction. Did you have a rotator installed as well? An outside antenna really should be pointed toward the station. You might also be able to add an amplifier to the antenna to boost the signal. But get a mast-mounted version that mounts right at the antenna, not the kind that goes at the TV set.
Apr 09, 2009 | Televison & Video
How do I boost a digital TV signal?
No don't buy an LCD TV! I mean, unless you want to, they are nice :-) But you'll still have the same antenna issue. I looked up your antenna, if it's actually working just fading in and out, try an in line amplifier first (radioshack 1501170), and if that doesn't fix your issue, time to upgrade your antenna. It does get a little pricier, but do keep in mind the whole set up is good for 10-20 years. Before going back to RadioShack, go to this website:
www.antennaweb.org
Mar 15, 2009 | Toshiba 24AF42 24" TV
Intermittent reception with DTV converter box
I install at least 2-3 antennas a week. While Analog stations were no big deal when it came to reception, Digital signals are very directional, and can be very fickle about reception sometimes. Digital is "all or nothing," meaning that if you get enough signal to get a picture, then great, but if you don't, it won't allow you to even try to make the picture.
My suggestion is to first try a 15-25 dB amplifier (with an FM trap) on the antenna. Use it first in-line, immediately following the antenna, before it is fed to any TV's. If that doesn't help, try re-aiming the antenna directly toward the city from which your signals are being broadcast. You'd be suprised how little you have to turn it to make a big difference.
Give these two things a shot. Hope this helps you...
Jan 05, 2009 | Televison & Video
I have a digital TV with an outside antenna and rotor.I rcv analog channels w/o any problem.I can rcv channel 19.1 on my TV and on my old TV with a converter box. I have gone to antennaweb.com to get the...
the frequency catcher of the antenna may be weaker then required.to receive the digital channels u can attach a network booster which will solve the problem.
Dec 04, 2008 | Televison & Video
Please help
The signal received on scanners depends on a number of factors. The most important is the elevation of your location. If you are in a valley or have higher ground around you, this will screen signals from you and will reduce the number of stations you can hear.
Secondly, receivers vary enormously from one to another. The one you are using may simply be less sensitive.
Thirdly, the position and type of antenna is crucial. If you are using a directional antenna it will only pick up signal from the front and some from the back. An omni-directional antenna will allow you to pick up signals through 360 degrees. The antenna must also be as high as you can get it, especially if you are in a valley.
Some emergency services use repeaters which allow you to hear signals much further away. You may not be in range of a police repeater.
Mar 08, 2008 | Radio Shack Pro-97 Handheld Scanner
Emerson EWL20D6 Television Logo
124 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
