Question about Dell 0Y3740 Keyboard
Numerical lock problem
Each time I log on to this PC, I must remember to click th num loc key or my right side numerical keypad is can I get the default to be "always on"
  • rferber Feb 17, 2009
  • Frank
    Frank May 11, 2010
    the numlock is set in BIOS.
    what make and model is the computer?
  • Dell Master
  • 4,806 Answers
Hi there
If its a wired Keyboard you are using, you have to set it in the system bios F2. Esc or Del on startup.
Good luck and thanks for using Fixya!!
Posted on Feb 12, 2009
Right side numerical keypad is not working
Make sure your num lock is light up. There will be a light that will light up. If the num lock is off the 10 key will not work.
Feb 08, 2013 | Sony VAIO Notebook
Acessability shortcuts
Right SHIFT for eight seconds........ Switch FilterKeys on and off.
Left ALT +left SHIFT +PRINT SCREEN....... Switch High Contrast on and off.
Left ALT +left SHIFT +NUM LOCK....... Switch MouseKeys on and off.
SHIFT....... five times Switch StickyKeys on and off.
NUM LOCK...... for five seconds Switch ToggleKeys on and off.
explorer shortcuts
END....... Display the bottom of the active window.
HOME....... Display the top of the active window.
NUM LOCK+ASTERISK....... on numeric keypad (*) Display all subfolders under the selected folder.
NUM LOCK+PLUS SIGN....... on numeric keypad (+) Display the contents of the selected folder.
NUM LOCK+MINUS SIGN....... on numeric keypad (-) Collapse the selected folder.
LEFT ARROW...... Collapse current selection if it's expanded, or select parent folder.
RIGHT ARROW....... Display current selection if it's collapsed, or select first subfolder.
on Apr 04, 2011 | Computers & Internet
My numeral key are not working[123456789 right side of key bord]
Step 1:
On some laptops it may be difficult to locate and activate the "Num Lock" key. Depending on the laptop, it may be hidden as a function where you have to press two keys. Most of the time, a laptop keyboard is just like a full desktop computer keyboard and it has a "Num Lock" key on it. Most people do not realize the "Num Lock" key is on their laptop keyboard because it barely serves a purpose without a full numeric keypad.
Press the "Num Lock" key on the laptop at the top, right of the keyboard. Press the "Num Lock" key and the "Fn" key simultaneously if the above does not work. Press "Fn" and "F11" simultaneously on the keyboard to activate the "Num Lock" function. Some laptops, like Toshiba, do have a "Num Lock" key. The shortcut for G3 Mac laptops it is "F5," and on G4 Mac laptops it is "F6."
Feb 07, 2013 | Computers & Internet
Key board right side numerical not functioning, why?
You have to push the Num Lock key to enable numerical keypad.
Jun 09, 2011 | Acer Aspire 4720 Notebook
The keypad on the right-hand side of my HP ProBook is locked. Please advise how I can unlock it.
Try num lock key ( usually over the "7" on numeric keypad) . It's labeled, so you should find it.
Mar 17, 2011 | Computers & Internet
How to tell if/or when the cap lock and num lock are engaged, I was spoiled when the green lights told you the status. thanks
simply when caps lock key is engaged all you type is always printed in capital num lock without you can not use numeric keys that are located on right side of your keypad.uyou can always use your numeric keys which are up to ur alphabeticl keys.
if it helped you.plz rate it
Feb 22, 2010 | Microsoft Wireless Desktop 3000 Keyboard
My function key is on and i cant figure out how to turn it off
To use the embedded keypad
After pressing Fn+F8 to activate the numeric keypad, you must press the Lock key
(in the top row of the keyboard) to turn number lock on or off.
When number lock is on:
• Keys change to the numeric or arithmetic designations printed on the right side of the
keys in the numeric keypad area.
• The Num Lock status indicator is lit.
• To turn off the embedded keypad, press Fn+F8 again.
For further reference of usage of Function keys, check the HP manual:
Page number: 30/141
Jan 19, 2010 | HP Pavilion N5415 Notebook
Keying numbers instead of letters whun num lock on
Check 2nd Function keys. The problem you describe is normally a Fn +numlock keystroke on most systems
Dec 27, 2009 | Compaq Presario 700 470024-192 Notebook
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
The Numeral Lock mode is turned on by pressing the key named "NUM LOCK" which is usually located on the top of the number keypad (on far right side of keyboard).
However, laptop keyboards are different. Most laptops do not have a separate numeral keypad set. Those laptops usually use a blue (or other color-coded) "Fn" key, on the bottom left. You must press that Fn key at the same time as the "Num Lock" key of same colr. Then a light comes on to indicate the mode change, and some alpha-numeric keys on the keyboard now become your numeral keypad. On mine, it is 789, UIO (456), JKL (123) and M (which is zero).
If this is too confusing, you can plug in a cheap full size desktop keyboard, using the USB or PS2 port on your laptop. That is what I prefer, because the funky integrated dual-key deal interferes with all the touch-typing I learned 37 years ago.
Feb 10, 2008 | Compaq Presario 1275 Notebook
Dell 0Y3740 Keyboard Logo
91 people viewed this question
Alun Cox
