Question about Texas Instruments TI-83 Plus Silver Edition Calculator
Find square of -x
I could have sworn that 2 days ago when I entered (-x)^2 i got x. Now when I enter the same thing I get 100. How do I fix this?
  • Texas Instru... Master
  • 7,993 Answers
I do not know how you could have obtained the first result: The only possibility is that your X has been assigned a value of 1. Even if it was the case, the calculculator shown on the left (TI83PLUS SILVER Edition) does not do symbolic algebra.
For the second case, I suspect some way or other, the variable X store a value of 10. When you enter (-X)^2 the calculator retrieves the value stored in the variable X and performs the calculation, which does yield 100.
Note: to store a value in one of the 26 variables (letters) you proceed as follow
10 STO-> ALPHA X
The screen displays 10->X
When you press ENTER it displays 10.0..
To recall a value stored in the X variable you type
2ND RCL ALPHA X.
Hope it clarifies the question.
Posted on Aug 20, 2009
  • k24674 Dec 25, 2009
    To calculate the square of a negative number you calculate the square of the positive number. The result is the same. If you want to do it with the calculator, the negative number must be enclosed between parentheses. (-x)^2=x^2.
Cheat code central
this is some red faction 2 cheats
Unlock All Cheats
At the cheat screen, enter SQUARE, CIRCLE, TRIANGLE, CIRCLE, SQUARE, X, TRIANGLE, X.
Gibby Explosions
To show gibby explosions, go to the Cheat screen and enter TRIANGLE, CIRCLE, X, SQUARE, TRIANGLE, CIRCLE, X, SQUARE.
Unlimited Ammo
To have unlimited ammo, go to the Cheat screen and enter this code: SQUARE, TRIANGLE, X, CIRCLE, SQUARE, CIRCLE, X, TRIANGLE
Unlimited Grenades
To have unlimited grenades, enter this code at the Cheat screen: CIRCLE, X, CIRCLE, SQUARE, X, CIRCLE, X, CIRCLE.
Super Health
To get Super Health, enter this code at the Cheats screen: X, X, SQUARE, TRIANGLE, SQUARE, TRIANGLE, CIRCLE.
Dec 18, 2013 | Sony PlayStation 2 (PS2) Console
Enter sin squared in Ti-83
The position of the exponent in trig functions is an anomaly in mathematical notation. While the square of sin x is commonly written as
sin^2(x) ,
the square of any other function is written as f(x) ^2 . For example, you wouldn't write ln^2(2) if you mean the square of the natural logarithm of 2, instead you write it as ln(2)^2 or (ln(2))^2 .
The calculator works the same way. To calculate the square of the sine of 3, for example, press
SIN 3 ) ^ 2 ENTER
Nov 18, 2011 | Texas Instruments Office Equipment &...
Does my ti-86 solve sq. root problems
Yes, your Ti 86 should solve square root problems. At the HOME screen press [CLEAR] [2nd] [x^2] which gives the (Square Root Symbol) to display at the Home screen. Then enter the number you want the square root of and close the bracket [ ) ] and, press the [ENTER] key.
You can even get the square root of complex numbers too. Select the correct complex format in the mode settings. For example: I'll do one in the rectangular form by enter a number as (a, b). I then will go to [2nd] [MODE] then [Arrow down] 3 times and make sure the RectC is highlighted and selected. Then quit out of the mode settings screen and enter [CLEAR] [2nd] [x^2] [ ( ] [9] [ , ] [ - ] [4] [ ) ] [ ) ] [ENTER], this displays the SQRT((9,-4)) equals (3, 2); The real part is 3 and the imaginary part 2.
Jan 09, 2011 | Texas Instruments TI-86 Calculator
When i square a negative number i get a negative result when it should be positive....
Use parentheses. If you enter (-) 2 x^2, you're not squaring negative-two, but getting the negative of two-squared because the square operation binds tighter than negation. Enter the expression as ( (-) 2 ) x^2 to square negative-two.
Nov 17, 2010 | Texas Instruments TI-30X-IISTK Scientific...
Have a TI30Xa, i am trying to input 100 micro squared. how do I do this?
Usually you do not use the prefix micro by itself, it must be followed by the name of a unit: 1 micrometer=10^-6 meter. This being said, you want to enter 100*10^-6 and raise it to power 2.
For this you can use the exponent rules.
  1. 100*10^-6=(10^2)*(10^-6)=10^(2-6)=10^-4; product of powers =>algebraic sum pf exponents
  2. (10^-4)^2=10^(-4*2) =10^(-8) ; power of power =>product of exponents.
With your calculator: You have a key near which is written [10 to x]; you access the function with [2nd][10 to x]
In what follows, I will enter (10^-6)* 100 and square it. I will use the change sign (-) or [+/-] key
(-6) [2nd][10 to x] [*] 100 [=] [x^2] [=]
The first = calculates 100*10^(-6), the second [=] calculates the square of the number obtained after the first [=].
There are other ways that use parentheses to avoid ambiguities, but I think this is the safest one for you. Be warned that the result will most likely be displayed in scientific format, 1.00 -08 where the -08 will be raised with respect to the main level line. If not, the result will be 0.00000001
Feb 17, 2010 | Texas Instruments TI-30XA Calculator
Cant change time on nec etw phone
Try this:
NEC Electra Telephone System
Changing the time on a Electra Elite & Professional system must be done from the "main" or primary phone. It is usually extension # 100. 1.- Press "FEATURE" 2.- Dial "9#" 3.- Enter hour and minute 4.- Press "RECALL" to change AM/PM setting 5.- Press "HOLD" to change the calendar setting 6.- Press "RECALL" to change the day of week 7.- Dial "#" to move the cursor to day of month field 8.- Enter day of month 9.- Press "RECALL" to select month 10.- Dial "#"to move the cursor to year field 11.- Enter last 2 digits of year 12.- Press "FEATURE"
Carl
Nov 06, 2009 | NEC Electra Professional ETW-16DC-2
I just bought my Gameshark 2 V 1.3 and it has alot of Games but it does not come with Dark Cloud and when i try to add it all it says it not enough memory i don't know what to do
it's very Simple really at the main menu of the GameShark 2 go to Expert Cheat Mode, Press [O] click Add (name of game) accept then you should be on the game Hold [Square] and press [X] 2 times tell Flashing then Press Right on the D-pad and Press [O] Click Add
(enter name of Cheat) accept Then Hold [Square] and Press [X] 2 times tell Flashing and Press Right on the D-pad Press [O] click add enter the Cheat code example
F4D0B72A 96F445CE, NOTE, i used the Mastercode for Dark Cloud =D not Dark Cloud 2, some Cheats have more than one Example: 45703068 1260D5D8
3942D6E1 9BABB1E0 2 rows not one now i know what your thinking you cant enter more than 1! well you enter one accept Press [O] Click Add
Press [L1] tell you can Overwrite the First Number/Letter and enter the Second Row
not that hard hm? and if theres more than 2 Rows just copy what you do for the 2 Rows thing NOTE, the First code you enter MUST be a Mastercode or nothing else works after the Mastercode Go Crazy! enter Infinity Health, Unlimited Money ETC... Have FUN!
Apr 12, 2009 | Mad Catz GameShark2 for PlayStation2
I need help with square root functions
The square root has a dedicated key sequence [2nd][V square root symbol]
Square root of 21.2846 is entered [2nd][V square root] 21.2846 [ENTER] .
The result is`4.614.
I suspect you want to calculate the 4th root of 21.2846. If it is the case you enter that as
21.2846 [^](1/4) =2.148
Square root can be also entered as [^](1/2)
Cube root is entered as [^] (1/3)
nth root is entered as [^](1/n)
Hope it helps.
Nov 19, 2008 | Texas Instruments TI-86 Calculator
Set time and date on bt synergy 3505
to set the time the instructions are on page 9 of the instruction manual in the getting started section.
in case you no longer have the manual....
1. press the tick/menu button twice.
2. press 0 and you hear 'to set the day and time press Star, to hear the day and time press Square.
3. press star. you hear 'please enter new day and time after the tone' enter the day (1=sun, 2=mon etc) enter the time using 24hr clock.
4. press the X/security button twice to exit.
hope this helps.
Sep 26, 2008 | British Telecom Synergy 2110 Cordless...
Two days ago I turned my computer on and where my sidebar gadgets should be there were black squares and rectangles. My clock was square with a black face and not working. I tried installing different...
Hello Donpd,
I have the solution to resolve the issue.
Perform the steps as provided below:
1. Close windows Sidebar. Right click on the Windows Sidebar notification area icon and click Exit.
2. Open the Start menu and click All Programs, then click Accessories. Right click on Command Prompt and click Run as administrator.
3. In the command prompt, type "regsvr32 msxml3.dll" without quotes and press Enter. Then click Ok.
4. In the command prompt, type "regsvr32 scrrun.dll" without quotes and press Enter. Then click Ok.
5. In the command prompt, type "regsvr32 jscript.dll" without quotes and press Enter. Then click Ok.
6. Turn Windows Sidebar back on.Check to see if Windows Sidebar is displaying correctly now.
Sep 10, 2008 | Computers & Internet
Texas Instruments TI-83 Plus Silver Edition Calculator Logo
112 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
