Question about Zanussi ZWF1230W Front Load Washer
Fault code E 40
Zanussi Essential 7Kg front loader
    Scholar:
  • 105 Answers
The code is door not locked or closed
Posted on Feb 12, 2009
The conditioner isn't going through my machine
Clean conditioner compartment as you can see on bottom picture.
Be sure to read the instructions of the manufacturer of conditioner. Some manufacturers supply concentrated softener which should be diluted with water (is too dense and can clog small drain tube in softener compartment). Also make sure you do not fill up over sign MAX., otherwise softener may leak in drum before starting the washing machine.
Dado
Oct 10, 2014 | Zanussi Washing Machines
Stops mid cycle and clears
It could be the heating element is at fault not heating to the selected temperature 95 degrees 40, 30,and so on, if one of these fail to work then the washer will not continue
also maybe the thermostat may be at fault, causing the same error
Nov 18, 2013 | Zanussi ZWF1020 Front Load Washer
Error code E 31 on a zanussi zwf 1431 front loader machine may not be water in. water feed and filter ok
The code E31 relates to a problem normally with the pressure switch,heater or maybe the Programmer.The heating element may even check out with a test meter but it can be an earth fault and normally just replacing this part cures the fault.If you are not electrically competant it would be worth getting it checked.
Hope I have helped.
Apr 25, 2010 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf1631w error code e40
hiya
E40 is the fault code for the doorlock, these are relatively cheap and easy to fit and if an independent (non zanussi) engineer was to fit it, you will probably be looking at around £40-£50 all in as a rough guide.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Nov 10, 2008 | Zanussi ZWF1440 Front Load Washer
I have a mastermind 708 7kg front loader and SE is flashing and maching won't work can you help please
Ihave a mastermind 708 7kg front loader and the SE is flashing and machine wont work can you help please? Thankyou
Aug 03, 2008 | Washing Machines
Westinghouse 798 front loader 7kg washing machine
God Sir
I am mr Yapi Antione from abidjan i am dealing with all washing marshing i saw your profle and i am intrested to to know the pris list of all the marshing in your company
i will like to haer from you as soon as posible
yours representetive
Mr Yapi Aantoine
you can reply me in this my email adress
yapiantione@yahoo.com
Or
Call me 0022501307526
Apr 04, 2007 | Zanussi FJS1225W Front Load Washer
Washer will not work
Possible drain fault, check filter. Regards Advisor
Jan 28, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1230W Front Load Washer Logo
259 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
