Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Router wont connect to internet
When I try to get on the internet it tells me that the cant find the dns and that the configuration is wrong what can I do. It worked at four oclock this morning and it stopped working at nine
    Problem Solver:
  • 4 Answers
It sounds like you have a timer set on your router. you need to go to your routers configuration webpage by typing in the IP address in the web browser. Once you get to the router's webpage you need to go to access restrictions or something similiar to that. then you need to change the timer to your desired time you want internet then push save changes and that should hopefully fix it.
Posted on Feb 12, 2009
Farmville wont load
Slow web pages could be the result of dns server timeouts. Your router is probably getting the dns servers from your Internet provider. (Logging on to the router should tell you the routers dns server IP address).
The PC's could be getting their dns server IP address either from your Server or the 2700HGV router. Disconnecting your server from the network and connecting a PC to the router should test this premise.
Take your server out of equation and see if Internet access and webpages speeds up. later test your speed here
Jan 12, 2014 | Computers & Internet
My belkin n600 keeps saying no internet connection the light is orange but the computer registers the router
Alright. The orange light means the router has no problems with your inner (private) network or its internal configuration, but it can't connect to the internet by itself. So obviously, your devices, which are routed trough your router, won't be able either.
I've compiled a small list for things you can check to resolve this issue:
- Check if your ethernet cable is connected to your router. It can be a CAT5 DSL cable or a CAT5 cable from your modem, to your router.
- Log onto your router configuration panel on or http://router/ by clicking log in at the top (the default password is blank). Should you get any problems with logging in, you might need to reset your router (button on the back, hit once for restarting and hold for 10 seconds for factory reset).
- Your problem is with WAN (Wide Area Network) or the outer network, so you will want to focus of that area of the configuration panel. Hit "Connection Type" and make sure you configure it accordingly to your ISP. If not sure, you can try and check the LAN/DSL configuration on another device that can connect to the internet via an ethernet port (the CAT5 from your ISP or modem) or just try the "Automatic" option.
- Check out the "DNS" section in the "Internet WAN" section. If unsure, try setting it to automatic. This will inherit the settings from a parent device in the network.
- Working with MAC addresses can be tricky. They are the fingerprint of your internet device (router, computer, LAN switches, modems) and some ISPs register your devices for security purposes. You should probably call your ISP and ask about it, if they need this configured specifically, they'll tell.
- If you're using a number of routers or a modem and a router you may need to change your LAN subnet mask or routers IP address in either your modem or one of your routers settings. This is only necessary if they overlap on multiple devices.
I have to say, though, 99% of the time it's either cables left unplugged or DNS misconfigured.
Nov 04, 2012 | Belkin Play N600 Wireless Dual Band Router...
I got laptop and desktop. done configuring the router. laptop and desktop successfully replied when I ping them. I tried pinging the router too on both laptop and desktop. i can see my desktop in the...
If your LAN is working but the internet can't be reached the problem will likely be that you don't have the correct dns number in your configuration or the gateway number is wrong. The gateway address is the ip # for the router. The dns address is the one your ISP uses.
Try setting up one pc to the router and get it working to the net first. Then do the same for the other computers. Each will have the same gateway address, the router's address, and all will have the same DNS addresses from your ISP.
Jun 06, 2011 | Computers & Internet
Can't Connect my Belkin router FSD7230-4 to the internet. I can connect to my new ADSL service when my computer is directly connected to the modem. When I'm going through the router it's not...
There are several reasons that this could be happening. Sometimes the DSL modem can be the cause. If it is configured incorrectly then it will not be setup to work in a routed bridge mode (what you need for it to work with the router). Easy fix for this: press the "reset" button in the back or bottom to set the modem to default settings then power cycle everything. Second, on your computer go to network and sharing center and find your adapter settings. right click on your Ethernet or wireless adapter (whichever you use to connect) and go to properties. Go to the TCP/IP protocal properties and check that everything is set to obtain its data automatically. Last thing to double check: Call your ISP and just verify the ip, login info, and DNS info are all correct. I have had an ISP give me the wrong DNS info before on accident and after several hours of troublshooting I called back and a different guy answered and told me that my DNS was wrong. I changed one number and POOF! Fixed! You can find more help for this at or email us at
Sep 01, 2010 | Belkin Computers & Internet
Cant connect to the internet
It means that either your computer or router is not getting a DNS address from your Internet provider. DNS is essentially the 411 service for the internet. You type in and your computer ask the router for the number, if it doesn't know it asks a computer at you internet provider and so on.
If the settin for the address for dns is missing either on your laptop or on your router it will not be able to find the address and like trying to make a phone call without a number you'll never get through.
Easiest solution is to call your internet providr and tell them that exact error message, then tell them you want to manually input their DNS server address(s) into your computer.
They will need to know what version of windows you're on then they can tell you where to go and what address to punch in.
Hope this helps FixYa,
May 13, 2009 | Computers & Internet
Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
Aug 10, 2008 | Cnet CWR-854 Router
I cant get onto internet explorer it says dns error can you help?
Check out your internet connection and its settings, whether it is dial up or broadband oriented.
then you have to know about your ip address of dns server in the network setting places.
you just ping the ip address of dns server following as...
go to start, then run and type "cmd", and it shows the command prompt. type as following format.
ping and press enter key.. this is the sample ip address only. if it gets reply, your dns server is ok. you can use internet. suppose, it wont comes, ask your service provider or support for another or different ip address of dns to check it out.
Jul 21, 2008 | Computers & Internet
Connected to Linksys Wireless G ok, laptop rebuilt, now can't connect
I'm a little confused about the status of your network adapter. Can you check to make sure your wireless network adapter(s) (wireless and physical) are set to "Obtain an IP Address Automatically" and to "Obtian DNS Automatically".
After this can you reconnect to the wireless network? Try the internet. If the internet still doesn't come up flush your temp files, close the browser and retry the internet. If it's still a no see below:
If so, can you try and do some simple "ping" diagnostics?
Open a command prompt:
1. Click on the START MENU and select RUN
2. Type in: cmd
3. Click OK
4. Type in >ping <ip address of wireless router>
Example: >ping
5. If your results are 4 "request timed out" then you have not established a wireless link yet. I would try and do a factory reset of the router and start over from scratch. A factory reset can be done by simply holding the "RESET" button on the back of the router for about 20-30 seconds.
6. If your results are 4 replies then you can run the next test.
7. Type in >ping
8. = a public DNS server. If you get replies then your are on the internet, but it appears that name resolution is a problem. All this means is that when you try to go to the DNS server that you should be contacted to find your way isn't able to tell you what the actual IP address is of and so you go nowhere.
9. Provided you're set as a DHCP client (meaning your network adapter is set to "Obtain an IP address and DNS automatically" it means your wireless router (if it's the DHCP server - this is the default configuration) is giving you the wrong information for DNS.
10. I would contact your ISP for the correct DNS servers and make sure they are configured properly on the Router.
11. You can see what DNS servers you are actually getting from the Router if you run the following command from a command line: ipconfig /all
Hope this is helpfull.
Let me know if I can help any more.
Jul 07, 2008 | Linksys Wireless-G Broadband Router
Wireless router problems
your computer is only connected to the signal coming from the router that's why it's saying connected but it seems that your router is not properly configured to provide internet access since your dns server is the same as your default gaetway. it could be that the your router is not in sync with the modem.
- if it's working before, tyr to power cycle everything by turning all the devices off then turn on the modem first, wait for all the lights on the modem to turn on then power on the router and the computer.
- if the router is for initial setup, kindly provide me you ISP, brand and model of the modem and how you connect the modem to the router and tell me if how you access the internet directly from the modem.
Jul 02, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Dns error 80710102
Hey peterk18,
First of all, how is your network configured? Are you behind a router? What's it's IP adress, does it act as a DHCP server?
If so try to set up a new network connection and put everything to automatic.. When the routers acts as a DHCP server it will give the PlayStation 3 an IP adress. DNS however is something else. DNS is a system that allows you to browse by a website or hosts name. For example: it allows you to type in your browser instead of it's IP.
DNS is essential for Internet. Your router should be your DNS server and your router itself also needs to know a DNS server, this would be the server from your ISP. All these settings are automatically configured via DHCP.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
87 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
