Question about Kodak EASYSHARE V1253 Digital Camera
V1253 Kodak Lens stuck open, will not power on
Lens is in the open position, camera will not power on. Have taken out the battery
  • 1 more comment
  • ruth descant Mar 23, 2009
    My camera is doing the same exact thing. The lens is stuck ing open position and camera won't turn on. Is this something the manufactor can fix?
    lens will not close and camera will not come on
  • Anonymous Apr 15, 2009
    I have the same problem on my camara. Is there any fix for this problem or do you cut your loss and throw it away.
  • 744 Answers
Hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.
Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Posted on Feb 12, 2009
My problem is that the lens stays open, all the lights flash, I hear a very low set of tones and then it shuts off. I recharged the batter and tried all the fixes except taking it apart
Sounds like a stuck lens. Happens to V1253 / V1233 often. These lens can't stand dust, dirt or sand. The lens has to be taken apart and cleaned. It's not very easy, also it involves some soldering. I suggest you give it to a local repair shop (if you think it's worth it). I could offer you a repair, but I'm in Germany.
I have worked at a Kodak service center as a technician.
Tom
Mar 04, 2011 | Kodak EASYSHARE V1253 Digital Camera
The camera switches off immediatly after switching it on, an the lens is not closing anymore. Is there a way to reset the camera with a combination of the buttons?
Not really, but it's most likely a lens problem. Resetting wouldn't help anyways. I have repaired a lot of these V1253 / V1233 with such a problem. It has to be taken apart and cleaned. Sorry for the bad news. I have worked in a Kodak service center.
Jan 23, 2011 | Kodak EASYSHARE V1253 Digital Camera
I have a kodak easyshare v1253 and the unit turnes on, the lights activate and the lens clicks to try to open the unit turns off. The lens does not open. I sent it in for warrnety for the same problem a...
Im sorry about that, well anyway it seems that the lens of your camera is already defective,
are you using the recommended battery Lithium-Ion battery (KLIC-7004)? If yes try to charged the battery and if this issue not solve Please call kodak Toll Free 1 800 235 6325 canada and U.S support only
Nov 03, 2009 | Kodak EASYSHARE V1253 Digital Camera
Lens won't retract. Camera powers off immediately after powering on without retracting lens. New battery didn't help.
Are you using the recommnded battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7004
first you need to do make sure the battery is fully charged., now if you if this solution will not resolve the issue it means that the Gear Lens is defective thats why your Lens will not retract and camera will not stay On. you need to call kodak to send your camera for repair call toll free 1 800 235 6325., Gudluck!
Oct 31, 2009 | Kodak EASYSHARE V1253 Digital Camera
Kodak V1253 lense won't close
Use the vacuum cleaner to suckout the dust/sand particles stuck between the lens casing and the body.
Aug 11, 2009 | Kodak EasyShare Z1275 Digital Camera
The lense pushes forward halfway when turned on
Hi!
I'm afraid you will have to give it away for a repair - it sounds like the lens get stuck in the halfway - could be dirt, sand or something in the reductor or the lens are damaged.
I work in a Kodak service center.
Hope this helps!
Tom
Jul 29, 2009 | Kodak EASYSHARE V1253 Digital Camera
My kodak easyshare V1253 Powers up, then shuts off
You have damaged your lens. If the camera can not move the lens it goes through a built in diagnostics test and shuts down. Beyond repair as cost to replace is beyond the value of your camera.
Jul 03, 2009 | Cameras
I have a digital camera kodak easyshare V1253 and when i turn on, the lens go out ,but inmediately the camera turn off and the lens go in back ,I check the batery in a especial store and is in a good...
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Mar 13, 2009 | Kodak EASYSHARE V1253 Digital Camera
Lens jammed on a kodak v1253
I fixed my v1253 following these steps:
1. Pulled the battery when the lens starts to come out before it could power itself off.
2. Gently pull the telescope out until it clicks.
3. Use a fine tip paint brush to clear debris out of the cracks.
Camera works just fine now.
Jan 30, 2009 | Kodak EASYSHARE V1253 Digital Camera
Lens jammed will not retract, canon pc1147 zoom
I have had the same issue were the lens would not retract. took it in for extended warranty work. lens now retracts but takes lousy pictures.
When I purchased this camera family members ran out and bought thiers shortly after I did. One by one the same issue has happend to their v1253's.
I dissmantled one and found that there is a tiny battery on the power board inside of the camera. apparently the tiny battery's life is about 1 1/2 years. This battery is not serviceable as it is welded in place. I am not one hundred percent sure if this is the cause but it makes sense.
It would be nice if kodak would own up to this issue and make good on repairs as they did with my kodak 5500 all-in-one printer and it's crappy print head. Kodak has sent me 4 print heads in the 2 years I have owned it.
I have 5 of the v1253's in my family and every one of the are dead. I would think a $250 product should last longer than 1 1/2 years.
hope this helps.
Aug 16, 2008 | Kodak EASYSHARE V1253 Digital Camera
Kodak EASYSHARE V1253 Digital Camera Logo
624 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
