Question about Polti Vacuums
When turning on the unit blows the fuse every time
Vaporetto eco pro 3000
  • Anonymous Mar 20, 2014
    Blows. Fuse when plugged into mains
  • 3 Answers
I had the same problem with my Polti 715 - every time I powered it up it would trip the circuit breaker on my mains power. I found that it was due to the power cable coming out of the Polti steamer - it had split slightly at the base of the unit exposing a bit of the blue wire inside. I dismantled the Polti - I had to use a long Torx screw driver to undo the screws. I disconnected the power cable in the Polti, I cut off about 15 cm of the power cable from where the split was and then re-terminated the power cable onto the Polti and then it was all good. So a fault int the power cable was the cause.
Posted on May 03, 2014
  • 547 Answers
You need a 60amp to run this have a quilified elec in stall
Posted on Feb 15, 2009
Filled with water, pressed both buttons and nothing happening ??
Are you sure it's plugged in and if so, is it plugged into a live socket?
Nov 02, 2013 | Polti 3000 Vaporetto Eco Pro Steam Vapor...
My polti vaporetto 2300 is belching with steam,have changd the safety cap seal,but hasn't helped --any ideas
My polti 2300 vaporetta is heating the water but not getting up to steam, could the problem be the safety cap?
Nov 17, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
I plug my Polti in and absolutely nothing happens, no lights come on nothing, I've changed the fuse but still noting
There maybe a broken switch or the motor may be burnt out. Take it to a used vacuum store and they will give you sound advice.
Oct 07, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
How does the cap open to put water in
You push down and hold it down while turning, keep turning till it is off. Same as puting on
May 05, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
The boiler stoped working on my eco pro 3300
There is a high possibility that the boiler has build up of minerals and requires cleaning. I suggest using a product called KalStop to remove the calcium buildup that is cause by leaving water in the tank for long period of time.
Mar 23, 2009 | Polti Eco Pro 3000 Canister Steam Vacuum
Starting a polti vaporetto steamer
Put a couple of lts. of water in the tank, replace lid, assemble hose with tool you require. Plug in switch on, wait for needle to climb into yellow then pull trigger for steam
Jan 23, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Looking to buy small nylon brushes for vaporetto polty eco 3000
Please contact me directly for pricing. I am a Polti dealer/ distributor in Canada. I have all of the accessories.
email: antonio_romeo@oralogic.com
Dec 15, 2008 | Polti Eco Pro 3000 Canister Steam Vacuum
Polti Vaporettto 3000 Steam cleaner
I suggest using KalStop to remove the calcium and minerals built up in the machine. Polti has built the machines to stop working when there is too much calcium in the boiler to prevent further damage.
Aug 24, 2008 | Polti Eco Pro 3000 Canister Steam Vacuum
Vacuums Logo
263 people viewed this question
Top Polti Vacuums Experts
Billy Detlefsen
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
