Question about Philips 42PF9630A 42 in. Plasma Television
Screen Problem After watching my Samsung HP-R4262 plasma tv for 30 minutes or so half the screen goes black from the bottom up.  Once it starts it continues to do that intermittently.  I've had the tv for 13 months. After watching my Philips 42 inch plasma tv for awhile, i have two problems: The bottom half of the screen goes black. Also, the sound goes out every once in awhile and we have to shut off and turn on again. Need to know how this can be fixed? I've only had this tv for a couple of years and don't want to spend on another one!
  • gysgt2u1 Feb 24, 2009
    Praky. Would replacing the YB upper/Lower fix this? Or should I replace all three YBU/L and Y-main? I already took back off set and replaced faulty caps on PSB. Tv worked fantastic for 3 days and now It only shows pic on top with horizontal white lines and bottom half is stary/colorful snow and vertical lines. Is this bad buffer or is this a dry joint? Tv was mounted back on wall.
    Any advice....
  • 744 Answers
Hi....Your tv picture is managed by several boards, the two specific ones are the ysus and the xsus. The Y controlls the horizontal pixelation and the X the verticle, if you are having horizontal problems then its the Ysus thats faulty, on this particular set, the Ysus board has two accompaning buffers that are particularly troublesome. I've had more than one of these sets in the shop recently with the same ailment.Sounds like your buffers are starting to go out. The screen is split horizontally by the two long skinny buffers attatched to the Y main, if the bottom one has one leg in the grave you'll be getting a partially black screen or no picture at all. The colored lines running through the screen are more typical of a failing buffer. Are you interested in taking this set apart and putting a couple hundred into fixing it?  When buffers go they usually take the Y main too. Worse case scenario you're gonna be out about $350 dollars to fix it yourself. Best case, a ribbon is loose on the bottom buffer and with a dismantle you'll be able to connect it again..
thank u rate me!!
Posted on Feb 12, 2009
Samsung HP-T4264 plays for a few minutes then goes to a black screen and makes a clicking sound
had the same exact problem. The customer service people at samsung were **** and had no clue. After doing some research I narrowed ti down to two potential problems. First one was check for the blown capacitors on the power suplly board. You can find lots of forums on this and is a very well known problem with samsung. Second, which was my fix, is try the firmware update for your TV from the samsung website. The rpoblem was fixed in 30 seconds and no money spent. The clicking and tv on and off problem is gone. Good Luck.
Dec 31, 2010 | Samsung HP-R4262 42 in. Plasma Television
Bottom half of screen is black
its ur diaplay problem.. go for a change of new display...
Jun 30, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
52" Samsung that the top half of screen goes black.
the HDTV has a heat-related problem check your fans. Do they remove heat? the vertical chips paint the screen from top to middle and, middle to bottom so; your top to middle vertical chip is overheating as is your video chip; that is why you have "glitter" in the back ground. get rid of the heat or, bye,bye TV.
May 20, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung plasma tv hp-r4262
The x drive board is bad in the area you see as black. OR the cable came loose.
Jul 03, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Bottom of screen is moving. I need help!
It looks like you got a bad Power Surge thought your Power Cable. There is a card in your TV that handles that. Unfortunately their is little you can do but bite the bullet and pay to have it fixed. First call Samsung and ask if this has happened to anyone else.
Feb 01, 2008 | Samsung HP-R4262 42 in. Plasma Television
Black line
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Dec 11, 2007 | Samsung HP-R4262 42 in. Plasma Television
Screen Problem
I have been trying to fix one of these tvs and found out from a repair man that the lower half going blank means a problem with the lower buffer. and that is also what the manual I downloaded says.
have you checked that?
Dec 07, 2007 | Samsung HP-R4262 42 in. Plasma Television
Large black line top to bottom
Oct 26, 2007 | Samsung HP-R4262 42 in. Plasma Television
Philips 42PF9630A 42 in. Plasma Television Logo
536 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
