Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Problem for Seagate Barracuda 7200.10 500 GB SATA Hard Drive
O.T: Hard disk size not recognised.
By Odud - usenet poster
I would appreciate your collective wit and wisdom to help me solve
this one:
I have a failing Maxtor One Touch HD in a box I carry with me on my
travels.
Thinking I'd be really clever I bought a Seagate Barracuda 7200.10 750
GB ATA100 disk to replace it. That way I can carry all my junk with
me.
No matter what I try the disk only reports as 137 GB. I can format and
partition, but only 137 GB. I have 500 GB (SATA) disks in my PC that
are recognized OK.
I've downloaded the SeaTools util from the Seagate web site, but that
does nothing useful. (I did not know that Seagate and Maxtor are one
and the same. Does that mean the same quality of HD's?)
Any useful suggestions will be gratefully received.
Thanks.
Same Problem
Jul 11, 2008
-   I have bought an Seagate Barracuda 7200 250GB SATA HDD which on partitioning gives only 137GB, while BIOS showing 250GB..................
DO some one help me !!!!!!!!-   rahul_700129
Mar 08, 2008
-   i have a 500gb hard drive which is only showinmg 137 gb. a fix to this problem would be marvellous!!!
-   Guest
Dec 30, 2007
-   My Quantum Fireball LCT15-20 cannot be recognized by the computer on the first boot but after restarting everything is fine...thank you-   Bols
Dec 23, 2007
-   i have a 500 gb sata seagate hdd but it only recognises 128gb in partition? any ideas on how i can get it to recognise the rest of the drive?
thanks
Lee A Brady-   LeeBrady
Nov 11, 2007
-   Aluratek AHDU350 USB 2.0 Hard Drive was working fine, but now my computer doesn't recognize it. It looks as if the computer is recognizing it as a DVD drive. Can anybody help me out on this?-   heith00
Best Solution
posted on Aug 01, 2007
Helpful)
Joey2
Rank: Apprentice
Rating: 0%, 0 votes
:::: I would appreciate your collective wit and wisdom to help me solve
:::: this one:
:::: I have a failing Maxtor One Touch HD in a box I carry with me on my
:::: travels.
:::: Thinking I'd be really clever I bought a Seagate Barracuda 7200.10
:::: 750 GB ATA100 disk to replace it. That way I can carry all my junk
:::: with me.
:::: No matter what I try the disk only reports as 137 GB. I can format
:::: and partition, but only 137 GB. I have 500 GB (SATA) disks in my
:::: PC that are recognized OK.
:::: I've downloaded the SeaTools util from the Seagate web site, but
:::: that does nothing useful. (I did not know that Seagate and Maxtor
:::: are one and the same. Does that mean the same quality of HD's?)
:::: Any useful suggestions will be gratefully received.
:::: Thanks.
::: Have a look at this link
::: Bearcat
:: Thanks for the suggestions guys. I have tried the following:
:: I have Googled the problem, found a few suggestions and tried those.
:: I have downloaded the util from Seagate, but that does not appear to
:: do anything.
:: What I have tried so far:
:: Installed the disk in PC's:
:: 1 off Asus P4c800E. Intel chipset = 875P. Old BIOS, but 160 GB ATA
:: disks running fine, as well as 250 GB SATA disks.
:: 1 off Asus P5W DH. Intel chipset = 975X. Old BIOS, but running 500 GB
:: SATA drives with no problems.
:: Both PC running XP SP2.
:: Atapi.sys is version 5.1.2600.2180
:: In both PC's the disk shows up in the bios as 137 GB. LBA is "on"
:: I feel cheated if this is all I can get out of the drive. I have not
:: yet tried calling Seagate or OverClockers, dread the 3 hour wait
Try swapping the jumper between cbl/slave/master, i had this with an
external enclosure that would only recognise the drive correctly if the
jumper was set to master IIRC
daZza
mr.dazza@"BUT_PLUG"gmail.com
(remove "BUT_PLUG" to reply)
Was this helpful?
Yes
No
Solution #2
posted on Aug 20, 2007
Helpful)
Senzor
Rank: Apprentice
Rating: 88%, 11 votes
Try downloading "HIREN BOOT". It's a bootable CD pack wich contains lots of programs. There you will find "Active Killdisk". Note: It must be the only hard drive in your computer and it must be set on master. After starting the program simply select the hard drive and press enter. It will "Kill" it, meaning any partition, data, FAT, bad sectors, and any traces of previous smaller defects caused by software will completely be deleted. Note that it will take a very long time to complete (a HDD of 80 GB needs almost 2 hours to kill), but it will completely remagnetize your disk. After that use "Smart F disk" on the same CD, create your partitions, format them, restart your computer, install the Operating System and you;re good to go. If this doesn't fix it, the only explanation is that it's an electrical problem and no software can help you with that. Then you must replace the board on the back of the hard drive with one of the exact model, or take it to someone who is familiar with HDD electronics.
Was this helpful?
Yes
No
Solution #3
Not Helpful)
M0nica L
Rank: Apprentice
Rating: 0%, 0 votes
Bert,
I would put money on the problem being the firmware on the chip inside
the OneTouch box not recognising anything larger than 137GB.
Chances are it originally came with a 120GB or smaller drive.
I have a large selection of external casings that won't accept a 160GB
drive - for that very reason.
No amount of jumper changes or service pack installations will make a
difference.
Odie
Retrodata
Globally Local Data Recovery Experts
Was this helpful?
Yes
No
Solution #4
posted on Apr 28, 2009
Not Rated)
honglake
Rank: Master
Rating: 74%, 9 votes
update the firmware from seagate official,it is very easy
Was this helpful?
Yes
No
Solution #5
Not Rated)
Janice
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the support, all of you.
Redman - I am running XP with SP2 in both the desktop PC's I am trying
the HD in. Both are Asus MB's and both run OK with HD's larger than
137 GB (250's ATA and 500's SATA). So I assume the BIOS is happy with
larger disks.
Odie - The originnal OneTouch HD was 300 GB, so it should recognise at
least that size of disk. I thought I was smart buying the biggest HD
on the market
Bearcat - Thanks for the Seagate DiskWizard util. What you posted does
more that I could download off the Seagate web site. Thanks for that.
I am trying it out now:
It reports the correct size in LBA (750 GB, so at least the disk is
what it says on the label), but the "Translation info MBR partition
table" shows the size as 137.43 GB.
So far I have tried to "zero" fill to delete the partition, but still
can only make the partition 137 GB or smaller. Formatting will also
only allow 137 GB as the max.
MB bios reports the disk also as 137 or smaller.
Is it time to tape the phone to my ear and listen to endless adverts?
Thanks, I'll keep trying.
Was this helpful?
Yes
No
Solution #6
Not Rated)
Luisa_K
Rank: Apprentice
Rating: 0%, 0 votes
I have Googled the problem, found a few suggestions and tried those. I
have downloaded the util from Seagate, but that does not appear to do
anything.
Was this helpful?
Yes
No
Solution #7
Not Rated)
Hart
Rank: Apprentice
Rating: 0%, 0 votes
If you are using Xp make sure you have at least SP1 installed, I thought I'd
lost lots of stuff on a drive that wasn't being recognised and ended up
reformatting it, bugger.
Redman
Was this helpful?
Yes
No
Popular Solutions for Seagate Barracuda 7200.10 500
Questions and Unsolved Problems for Seagate Barracuda 7200.10 500
Do you recommend Seagate Barracuda 7200.10 500 GB SATA Hard Drive?
Answer
Answer
I have a iomega harddrive and the computer is not recognizing it. It is also beeping. the power... (More)
Answer
well i have the same problem i had a seagate st3500320as and i shutdown my pc and the next morning... (More)
Answer
How can i tell if my laptop will support a SATA1 and/or SATA2 Hard drive? Thanks in advance.
Answer
Not detected by anything, hooked it up via usb directly, and still didn't work. The drive spins up... (More)
Answer
The BIOS detected the primary HDD not installed either by auto detect or user manual detect. The... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Seagate Barracuda 7200.10 500...:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
