Question about Frigidaire GLEQ2152ES Electric Dryer
Burner lights first thing than never again till next day
After first drying cycle a small rattle sounds when you call for heat then cuts off and no burner ignition. could it be the coils? I replaced them last year. ignighter glows every time.
  • Anonymous Mar 24, 2009
    fgq1442eso same issue i will inspect gas valve coils
Replace one or both gas valve coils.
I replaced both.
Works fine now.
Posted on Feb 13, 2009
I have a HotPoint electric stove (don't know the model number sorry) and the front right burner makes a rattling sound when i turn it on. It's about 10 or so ticks in quick succession and then a low...
metal expands when it is heated. There is a chance that replacing the burner would stop the noise till the standoff wears out again. Also the burner wells have inserts that the burner standoffs rest on. Replacing those might help. There is no danger present.
Jan 23, 2016 | Hotpoint Kitchen Ranges
How to reset code to turn up the heat on a dishwasher model #WDT9105AYE
You can't turn the heat up, just on or off. Are you using heated dry?? It sounds like the vent system in the door is either not working or blocked. Some dishwashers have a small trap door flap in the dishwasher door that is closed during wash and opens to vent steam during the dry cycle. Sounds like it is staying closed. If you have a higher end dishwasher, they usually have a fan motor that come on during dry that gets rid of steam and moisture. Just a few things to check.
Feb 16, 2015 | Whirlpool Dishwashers
Burner shut off then there is a clicking sound, burner ignites again
this is normal the clicking sound you hear is the system starting another cycle for your furnace to ignite the burners, then turn on tbe fan blower.
Sep 27, 2017 | Heating & Cooling
Carrier gas furnace does not cycle right.
Check out the flame sensor see if it is clean and check the connections .
May 21, 2017 | Carrier Heating & Cooling
I have a kenmore dry that seems to hum very load once it heats up. If you turn it off and rest for 30 minutes it will sound fine again until it is 15 minutes into the cycle. What would be the likely...
Hello Bill,
Sorry to be the bearer of bad news,but what your describing sounds exactly what a bad motor will do...run whiles is realitivly cool,cut off when hot the restart after a cool down period and run for a while till hot again.
GENE
Sep 12, 2011 | Kenmore 84072 Electric Dryer
Next Step
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 08, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
No clicking sound from the burners.
Hi, I solved the problem by hand lighting the burners and turning on the oven to help it dry out and it worked. It took two days to work again. Someone from the gas company told me to do that and also take a blow dryer and use that to help dry it out. Saved us repair charges. Yeah
Thank you for your time,
April
Sep 17, 2008 | KitchenAid KGST300 Gas Kitchen Range
Dryer won't dry clothes completely. stops heating.
Clean vent 1st. Electric? Gas? More information is needed for sure. Does it come on and light up (assuming gas) then never light up again? or....are you running it thru like 3 cycles to get them dry? You say it stops heating......how long until it starts again....i assume that if you turned it on the next day that it would heat up right? (at leat initially) Can you see the heating element(or ignitor and flame)?
Jul 27, 2008 | Dryers
My gas dryer only heats up the first time...
replace both coils on the gas burner (the round black dohickeys)after first ignition they tend not to pull valve open next time heat is called for
Jun 06, 2008 | Hotpoint NBXR463GBWW Gas Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
189 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
