Question about Turboair Turbo Air Sandwich Salad Table 72" GSP-72T
Turbo air sandwich table too cold
Turboair Turbo Air Sandwich Salad Table 72" GSP-72T is too cold. Everything keeps freezing and it's on the warmest setting.
    President:
  • 1,902 Answers
Replace the thermostat which is located on the back of the unit underneath the bins in the very back. If the thermostat goes bad it will let everything just run and run and run. If this has been helpful please rate
Posted on Feb 12, 2009
Can you replace the door sliders on the tst-28sd-d2 one of the guides broke
You should be able to find the part at this website. They have a full line of Turbo Air parts for commercial refrigerators.
https://www.kitchenstuff.com/turbo-air-greenworld.html
Sep 13, 2015 | Turbo Air TST-28SD-D2 Super Deluxe...
How to change door gaskets.
DEPENDS ON UR TYPE OF FRIDGE BUT MAYBE THESE PICS WILL HELP SOME ARE THE SNAP IN KIND SOME SLIDE ON AND SOME SCREW ON
Mar 23, 2015 | Turbo Air MST-72 Refrigerated Counter...
Metalfrio prep table freezing evapoator
Check that all vent areas are clear of any dust or food packaging. If you have ice build up it needs to be thawed out also because it will only continue freezing until it gets proper airflow.
Sep 17, 2014 | Metalfrio SCL2-60-16 Salad Sandwich Prep...
Coils freeze
Either your coil is blocked with paper or wrap, or you have a refrigerant leak in the coil and the little bit of gas that's left is flashing as it enters the coil. Make sure that the cooling coil and condenser is clear and the fans are running. That's all you can do without refrigeration tools. Good luck and hope this helps
Apr 22, 2014 | True Refrigerated Sandwich Prep Table 72"...
Freezing
Keep the prep top table pans covered when not in use. Never leave empty holes where pans should be. If the pans are empty put a couple of inches of water in them to keep some heat load there. Check the door gaskets and door seal on the base doors. Make sure the thermostat is set on number 5. If all of this checks out probably need a new thermostat, but if it's erratic I suspect you will find it's one of the former problems.
Mar 27, 2014 | True Refrigerated Sandwich Prep Table 72"...
I have a breen world GSP-72T and i need a new thermostat but cand find where they sell any
http://parts.turboairinc.com/index.php?cPath=4 follow this link to the Turbo Air parts page. See if these match your thermostat. If not then call the number listed there to order yours...hope this helped you
Jun 09, 2012 | Turboair Turbo Air Sandwich Salad Table...
How do get to evap fans? One of them is causing the unit to pop the GFI.
Hi.
To reach the fan remove panel located behind the pans:
If instead you need to reach thermostat and evaporator, remove the panel at the back of the refrigeration compartment to reach the evaporator at the back.
Here the full service manual:
SERVICE MANUAL DOWNLOAD
Regards.
Ginko
May 28, 2011 | Turboair Turbo Air Sandwich Salad Table...
My pizza prep-table freezes everything. I think it might be the thermostat. Could I be right
Hi
Sounds like you are correct, unless the door seals are not in good order, air leaking in can fool the thermostat.
If it has a top section that the pans for pizza ingredients sit in check that the airways are clear and that the tins and lids fit properly.
Regards
Gordon
Apr 27, 2011 | True Refrigerated Sandwich Prep Table 72"...
Turboair Turbo Air Sandwich Salad Table 72" GSP-72T Logo
322 people viewed this question
Top Turboair Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Turboair Refrigerator Expert? Answer questions, earn points and help others
