Question about Alpine MRV-T707 Car Audio Amplifier
Alpine v12 amp no power
I have a alpine v12 amp installed in my renault clio mk2 all wires are wired correctly but i have no power to the amp.
nothing wrong with the amp as i have had it tested what could the problem be??
  • dan_mcnee Feb 28, 2009
    thanks 4 the idea but sadly i went out and bought a whole new woring kit and hey presto it worked thanks for the help
  • 6,784 Answers
Its your fuse box. i would bypass the fuse box and wire this amp directly to the battery via monster cable. make sure you attach a 30wieght fuse to the monster cable that is running from the battery to your amp. ground the amp against the trunk. scrape the paint of a section and drill a hole in the trunk. use this for the ground for you amp. this will fix the no power issue.
Posted on Feb 12, 2009
  • Michael Masters
    Michael Masters Feb 12, 2009
    You may want to add a switch to this amp as well.or, you can connect the remote wire to the auxiliary master wire in the dash that's connected to the stereo. i would suggest just adding an independent switch . you will have to mount it yourself under the dash but, its worth it.
Where are the Headlight relays on 2002 Renault clio
The headlamp circuit is rather simple. From the 15 amp RH headlamp fuse, there is a red w/yellow trace that goes to the RH high beam. Out of the 15 amp LH headlamp fuse, the wire going to the LH Hi beam is solid red. Both of these wires should have power when the headlamp relay is energized. The wires from the Hi Beam bulbs going back to the switch should both be red w/black trace. The wire going from the headlamp relay to power the 2 15 amp fuses is white. The headlamp switch applies a ground to illuminate either the Lo Beams or the Hi Beams.
Sep 11, 2012 | 2002 Renault Clio
I need to know how to hook up an alpine v12 amp 2 ohm i have two tens
This really depends if your 10" subs are 4 ohms each or 2 ohm - for this exercise, I'm presuming they are 4 ohm each.
You already know your amp can deliver 600W RMS (@ 2ohm), so you need to be careful you do not exceed the maximum RMS input power of your subs.
Normally you would wire subs in "parallel", which would reduce the circuit load to 2ohms - however, the 600W RMS power may be too high for your subs to handle.
In this case, it may be safer to wire your subs in "series" - this will increase the circuit load to 8ohms, which will effectively decrease the amps RMS power output.
Cheers,
Sep 05, 2011 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
My alpine v12 turns on but no sound
no you don't have to hook up both of the power terminals. but should have it hooked up so you get the proper power to the amp. use a disubution block with two 8 gauge wires.
do you know if the radio's rca jack's are good? have you ever had another amp in the car? if it worked before try new rca's from the radio to amp. recheck all connections from amp to speakers and make sure no wires fell off.
Sep 22, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Bostom tweeter cutting out
get a new tweeter. really, if its starting to cut out, or static, then its prabably old and need a new 1
hope i was help :)
Apr 28, 2009 | Car Audio & Video
How to wire into a renault clio mk2
should plug straight in / there should be 2 connector blocks one with all the power leads and the other(8wires) for the speakers
Jan 19, 2008 | Pioneer DEH-P6600 CD Player
No sound from the amp
Make sure that your amp turn on wire is connected from behind the radio to your amplifier. Usually the turn on wire is a blue wire but it can be any. This blue wire connects from the blue/white wire behind the radio to your small connection turn on connector on the amps power connections. You have 3 ( 12V , Ground, Switch or the smallest connector)
Also check the amplifiers fuses, and the main powerline fuse as well. If this doesnt work then write back to me.
Oct 10, 2007 | Alpine MRD-M1005 Car Audio Amplifier
Alpine V12 MRV-T707
power wire from fuse block goes to "the 1 that says power"...remote is used to have your device turn another device on...like a cd changer
May 28, 2007 | Alpine MRV-T707 Car Audio Amplifier
No sound and some smoke
If you got smoke comming out its already has damage my friend.. Was this unit bench tested before you bought it or was it hooked up in another vehicle and you seen it work or did you buy it sight unheard??
Mar 23, 2006 | Alpine MRV-T707 Car Audio Amplifier
Car Audio & Video Logo
2,874 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
