Question about Dell Dimension 3000 PC Desktop
Dimension 3000 Power up problems
There is nothing, no lights anything. I have removed the panel and there is also no indicator light on. Also, does the monitor have to be hooked up to the computer in order for it to work
Thanks for the help,
Randy
    President:
  • 1,902 Answers
Sounds like you have a bad power supply. If your computer is plugged in and you turn it on and nothing happens then replace your power supply and all will be well. And yes the monitor needs to be plugged into a outlet and also the back of the computer to work.
IF this has helped please rate
Posted on Feb 12, 2009
Testimonial: "That was the answer, thank you very much"
How do I fix a dimension E510 with a solid amber power light?
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 25, 2014 | Dell Dimension E510 PC Desktop
Dell dimension 8200 help
Apr 09, 2014 | Dell Dimension 8200 PC Desktop
Dell dimension 8400 blinking amber light ethernet port
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Jul 27, 2012 | Dell Dimension 8400 PC Desktop
During a recent thunderstorm, the power fluctuated and my dell dimension 3000 turned off. There was popping sound and now I cannot power on the computer. When I take off the side panel, I can see a green...
The popping sound is most likely your power supply or something on your system-board like a capacitor.
If the problem is only the power supply:
If you want to see if you can salvage it try just replacing the power supply. The part is around forty dollars. You can google "Dell Dimension 3000 250w power supply" to find a deal on a power supply.Here is a link on how to replace the power supply in that computer.
http://support.dell.com/support/edocs/systems/dim3000/en/SM/parts.htm#wp1075727
Hope that helps.
Joel
Jun 03, 2010 | Dell Dimension 3000 PC Desktop
No panel lights, no fan, flashing front left light
the blinking lights means power issue. If you already plugged the computers power cable directly to the wall and stll get the blinking power light then your probably looking at a bad power supply in the computer.
Just for measures go into the system and if you have a video card remove it and start the system up. Also take out the memory stick and put them back in just incase during the move some components got loose. Put on your detective hat and check all connects. if problem still persist replace the power supply. In Computers terms thats called the PSU (power supply unit)
Your friend
Joel
May 29, 2010 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 just stopped working, no sound, no picture. Power supply comes on, hard drive light blinks as if it is trying to load, but, nothing.
just reinsert your RAM.
its not a graeat problem. so just open your cpu and eject ram and insert it again properly. okay
Apr 26, 2010 | Dell Dimension 3000 PC Desktop
No power light when on but can hear running, no screen image
First make sure the monitor is on and connected to the PC.
If the power light is not on you could have a bad power supply, it could also be that the onboard video went bad.
If your PC has four trouble lights in the back, let us know which ones are lit, this can pinpoint the problem.
The noise you hear is the drive spinning up and the CPU fan.
Good Luck.
Feb 22, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 Power Problems
You have one of two problems. Power supply bad or your heat sink has got to hot and has fried your processor
Feb 07, 2009 | Dell Dimension 3000® Pentium® 4...
Dell Dimension Shut Down
Hi
You query suggest you have Dell Dimension 3000. Dell Dimension 3000 is a desktop PC and does not have a battery backup by itself.
I am assuming the battery backup you are referring to is a UPS (Uninterruptible Power Supply). If this is correct then by your description of the issues, the UPS may be faulty (indicated by the Red light and beeping).
Disconnect the computer's power cord from the UPS and connect it to a wall power outlet to confirm or rule out the UPS as the offending device.
If this does not help reply with more info
Mike
Aug 15, 2008 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000 PC Desktop Logo
81 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
