Question about Kenmore 95822 / 95824 / 95829 Electric Kitchen Range
Kenmore stove error message E0 -F2-
What does that mean and what do I have to do to fix it?
  • Cary Crook May 11, 2010
    I need the full model number please it will help narrow down the codes. Thank you
  • 15,935 Answers
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
Hello. I have a Kenmore Ultra Bake, with push button control. After wiping down the panel it went crazy. The panel is now showing EO F2 and continuously beeping. I can use the stovetop, but can't turn...
Hi
Thanks for using FixYa. Error F2-E0 on your oven means that the keypad is shorted and to resolve this issue you'll have to replace the electronic range control/clock(ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Kenmore Ovens
Stove is beeping and displaying EO F2. Do reset but it keeps coming back. Also one element on the range top has burned out. Is it something a DIY can do.
Hi dear.According to your explanation,E0-F2 code meaning is: F2 - E0
Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
I hope that helps to solve your issue.Thanks.
Sep 02, 2010 | Kitchen Ranges
Kenmore model 95781000 shows error code EO-F2- what is the definition of this code?
Hi
Thanks for using FixYa. Error E0-F2 means shorted keypad and to resolve this issue you’ll have to replace the electronic range control/keypad assembly.
Thanks
Rylee
Jun 21, 2010 | Kenmore Kitchen Ranges
Controls won't work. Displays message: E0 -F2-
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 20, 2010 | KitchenAid KERC607 Electric Kitchen Range
What does an E1 F5 error on a Kenmore stove mean.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Message on the display is E0-F2- need to know what is this problem code means. This is a glass cooktop Kenmore electric range
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Aug 03, 2009 | Kenmore 95589 Electric Kitchen Range
Oven not working Message E0-F2- showing
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Apr 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
EO -F2- Error?
Oct 27, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 95822 / 95824 / 95829 Electric Kitchen Range Logo
438 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
