The problem IS PROBABLY BEING CAUSED BY A SHORTED POWER REGULATOR (MX084 ) OR AN OPEN FUSEABLE RESISTOR IN THE POPWER SUPPLY...
thank u rate me!!
Comments:
Feb 12, 2009
- I SUGGEST u TO CHECK THE INTERNAL FUSE , IT MAY BE OPEN
To find the fuse you have to unplug tv from AC then remove back panel or open case of tv , if you follow the cable that as been disconnetted (may be dangerous if you plug in ) i hope will be easy to find the fuse that can be blown . if you have a meter can check if the fuse is open or short .after this check and if did you change the fuse you can try to plug the cable making attention the risk of touching some electric part of tv thank u rate me!!!
i have a sony tv it was working fine till last night when turned on the tv picture started to skew...
(More)
i have a sony tv it was working fine till last night when turned on the tv picture started to skew upwards and then went black the sound is fine
I have just moved my satellite receiver and DVD recorder to a new cabinet and upon reconnecting...
(More)
I have just moved my satellite receiver and DVD recorder to a new cabinet and upon reconnecting everything, I can no longer access the DVD recorder using the TV/VIDEO button on my Sony KV-32S42. The TV recognizes the satellite receiver as Video 1 but I get only snow when I select VIDEO. How can I set the DVD recorder as a 2nd input to the tv. All connection are as specified in the TV and recorder manuals.
recently purchased a kv-32s42 32" at an auction. Tv was working but when we got it home will...
(More)
recently purchased a kv-32s42 32" at an auction. Tv was working but when we got it home will not turn on. no lights no sound. Any ideas?
