Question about Ricoh Aficio 1035 Copier
Ricoh FT4022 error E-1
I'm getting error E-1 on this old guy - Ricoh FT 4022 which makes it impossible to function . it just halts in E1 position . based on my investigations this error is related to lamp , but what should I really to make it work ?
thanks
I'm also getting and E-1 error code, with 40 noted when pressing the .
We are having light copy problems, with full toner, so I cleaned off the mirrors under the glass and when I plugged it back in and turned it on the E-1 showed. Any help?
Thanks
Cindi
  • gaterud Feb 12, 2009
    I posted the second part of the question and noted a "40" when pressing the "."
    Thanks
    C
  • Everett Lin May 11, 2010
    Hello dear; We need more information, when you turn on the machine it display E 1 then you press"." key to read more number.
  • 1,031 Answers
E1 Exposure Lamp problem. (sensor, lamp, lamp stabilizer)Either the lamp is blown, the board is bad or the sensor is bad.
Posted on Feb 12, 2009
  • Starnley Johnwells
    Starnley Johnwells Feb 12, 2009
    hope this helps do let me know
Ricoh ft 4022 photocopy machine displaying error code E-3.
cleaning requird clean properly with any quality cleaner then rty
May 17, 2012 | Pyle Office Equipment & Supplies
My machine is ricoh FT 4220. error 11 or E1
E101: Exposure lamp error
1- check the Exposure lamp if it damage replace it .
2- check the Exposure lamp fuse ( located in scanner )
3- check the Exposure harness .
and after you solve your problem you must
Enter SP5-810 (SC code reset) and press the Enter key to reset the code
Jan 04, 2011 | Ricoh FT3713 Copier
How do i solve ricoh ft4022 E-5 error
E5 is the error of the fusing unit chech the thermistor
Oct 12, 2010 | Ricoh Aficio 2015 Copier
I'm getting error E-1 on this old guy - Ricoh FT 4027 which makes itimpossible to function . it just halts in E1 position . based on myinvestigations this error is related to lamp , but what should I...
The E code tyo refer the exposure lamp malfunction.Turn ON the main switch,remove the rear cover and turn the DIP switch 101 01 ON and OFF,and turn tha main switch OFF and ON.
Aug 13, 2010 | Ricoh Aficio 1035 Copier
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have checked the fuser unit and its ok. What could be the problem? Do I need a reset code to solve it and where do...
The E5 code is the fuser malfunction error.
E52 fusing lamp warm up error.Possible causes thermistor open,heater lamp open,thermofuse open.
E53 fusing lamp overheat.Thermistor in shortcircuit
E55 fusing thermistor open
When service call E5 conditions occur they cannot be cleared by turning OFF/ON the power switch.To reset turn ON the main switch,turn DIP switch 101-1 ON and OFF(the DIP switch is located in rear part under main supply board).,and turn the main switch OFF and ON.
Nov 11, 2009 | Office Equipment & Supplies
I have a RICOH FT 4022 Copier and when I switch it displays U 6
Ricoh 4022, 4027 Код ошибки Описание C1 Front door open C2 Exit door C3 Cassette cover C4 LCT cover C5 Sorter open or not latched to machine, or fuse 304 on DC power board C6 ADF cover C7 Right side cover E101 Exposure lamp too long E103 Frequency problem E120, 121 Scan home problem E124 Scan drive problem E140 Lens home, or fuse 303 on DC board E141-143 Lens home sensor, fuse 303 on DC board E144, 145 Mirror sensor, fuse 303 on DC board E191 Image density sensor error E302 Charge roller problem or HVT problem E346 Bias loss E351 Image density sensor problem E352 TD sensor error E353 Vsp problem. Dirty or bad image density sensor E354 Vsg problem. Same as E353 E355 Toner density sensor problem E356 Same as 355 E405 Transfer belt or charge roller drive E440 Main drive E442 Drum charge thermistor E501 Upper lift motor E502 Lower lift motor E503 1st tray motor E504 2nd tray motor E505 3rd tray motor E506 Tray main motor drive problem E507 LCTl lift motor E522-525 Jogger sensor E541 Fuser thermistor E542 Fuser temperature too low E543 Fuser temperature too high E544 Fuser temperature too high E547 Fuser lamp won't shut off E548 Fuser temperature too high or too low E620 Communication problem between main board and ARDF E621 Communication problem between main board and sorter E623 Communication problem between main board and paper trays E720 Sorter stapler timing roller sensor E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E724 Sorter stapler error E900, 901 Copy counter U2 Key counter U6 Fuser unit not installed properly U7 Duplex unit
Aug 24, 2009 | Office Equipment & Supplies
Fucntional problem with Savin 4022 sp, SC 120. Did clear mode to get to sp screen but copier still will not turn off..
This is a scanner problem (the part with the lamp) is it crooked as viewed from the orig. glass? No need to reset this code when the movement problem is fixed turning power on and off will reset. -Carl
Jul 15, 2009 | Ricoh Aficio 450 Copier
RICOH FT4022 BIG STREAKS THRU COPY
Most likely you are beyond cleaning. Sounds like either your fuser, or drum is causing problems, and even if it is simply optical, there are a few different service mode adjustments that need to be performed after cleaning to correct the image density, which are too complicated to explain here. There must be a local service company that will help you out on this one. I myself, still work on a few of these machines, and although they are old, they are still worth putting a few dolaars into if it is serving your needs. They were/are an excellent model. Sorry I can't really give you any direction, other than to advise you that you'll be needing a tech to get it working properly.
Mar 05, 2009 | Ricoh Office Equipment & Supplies
E1 ERROR ON RICOH FT4022
Nov 11, 2008 | Ricoh Aficio 1035 Copier
ther is arest of this error code you can get it by pressing (.) key on the panel to read 2 numbers and then report again
Ricoh Aficio 1035 Copier Logo
351 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
